Question about Philips Magnavox 20MT133S 20" TV
I need a Magnavox CDB 650 cd player. ( 1986) The detachable two prong power cord is missing. Where can i find a replacement?
  • 597 Answers
You can get a replacement from any electronic shop.
Mostly shops that deals in cables, cords etc.
Take care
Posted on Oct 07, 2010
I need power cord. It says Walmart on it also but this is the only model # I found. Where can I buy a power cord for it? thank you
good afternoon Thelma.
The answer likely goes one of two ways, depending on whether:
  1. The cord is detachable, with a male 2-prong plug built into the wall of the fryer.
  2. The cord is part of the fryer, with the cord going inside the fryer, probably somewhere around the base.
If the cord is detachable, it's likely a standard cord that you'll likely be able to get almost anywhere that has appliance parts - either a specialty store, or a place like a Sears that tends to stock parts as well as sell appliances. I'd guess it'd be kind of a rectangular head maybe about 1/2" x 7/8" with two round holes to match two pins in the fryer wall. Anything like that should be heavy duty, but you'll want to make sure you get one with heavy enough wire that it can handle the current that the fryer heater will draw during warm-up.
if the cord isn't detachable, but missing, then the answer is similar, except that you'll essentially need to open up the unit and there will likely be a spot near the cord inlet where the hot, neutral, and ground wires are attached to inside wires with wire twist-nuts. In that case, use the gauge on a pair of wire strippers to measure the gauge of the input wire, then replace it with a cord with intact plug that has that gauge, or heavier, of wires. Often, there are knots tied in the individual inside wires. Don't skip making those in the replacement. Those are strain relief to keep cord yanks from yanking the wires out.
Hoping this helps.
Good Luck!
Nov 18, 2015 | Kitchen Appliances - Others
Need another cord to put on dryer as my home does not have the large outlet; only a 3 prong outlet. Can this dryer have a new cord put on?
Yes. Putting on a new cord is simple. There is a plate covering the cord that is on there now. Remove the two or three philips screws holding it on. Get a new cord at an appliance store. Use a nut driver to detach the old cord. Hook up the new cord with the colored prongs in the same places as the old. The green will be the one that is missing. Replace the green screw so it is not lost. Be sure to install the cord protector so the sharp edge does not slice through your new cord. Good luck.
Apr 06, 2011 | Roper REX4634KQ Electric Dryer
After going through every step we found that a prong from the power cord going into the computer is missing, the three prongs inside the power cord. I suppose I need to get another power cord or is it...
yes power supplys go bad, but check the model label of machine for power requirement , you may find it has only 2 "legs" one is ground other power, the third not used.
Sep 24, 2010 | HP Photosmart D7560 InkJet Printer
Where can I buy a power cord for my Magnavox portable cd/cassette player?
use the player direct power from the net other wise you have to buy a adapter with the power out for your device can be used universel
look first up how manny voltage you need 6 or 9 or 12 volt if you now thad buy a adapter with at least 1 or 2 amp how more how solid they are
Oct 31, 2009 | Philips Magnavox MPC421 Portable CD Player...
Replacement Power cord for Durabrand CD-109 player
It is a standard power plug.
Take radio to Tandys/**** smiths or electrical store - they will have one for sure.
You may even have same cord around the house.
Voltage and watts do not matter - should be just a 240 power cord like radios, kettles, TV's, VCR, DVD players use.
Jul 03, 2009 | Audio Players & Recorders
Philips Magnavox 20MT133S 20" TV Logo
121 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
