Question about Maytag Neptune FAV6800AW Top Load Washer
Waher is reading out LR what does this mean?
  • 15,935 Answers
The LR error on your non-spinning Maytag Neptune is usually, though not always, accompanied either by a burn spot or a blown fuse on the Motor Control Board.
Maytag upgraded the motor and motor control board because this problem was so prevalent. Big rash of these a few years back... and insludes replacement instructions with the kit.
The LR code means "locked rotor" - the control is not seeing the motor turning.
The image below contains the wiring diagram for this washer as you requested but there are some other things to consider.
Usually when the LR code is displayed the motor has stopped turning for some reason.
By definition the LR code means the control has tried to turn the motor but was unable to.
The error code can be caused by to large of load, to much soap/suds in the water or a problem with the spin bearing.
The cause of the LR message can be little problem like suds or a major problem like the spin bearing and sometimes it's difficult to pin down.
You don't mention in your question if the LR code occurs every load or once a week.
Try running a rinse and spin cycle empty and see if the washer completes the cycle.
The 2nd image contains the information on how to enter and run a diagnostic cycle which may help pin the source of the problem down.
This test completes all functions of the washer is a short time. It will fill, tumble, drain and spin all is a few minutes.
At the end of a successful test cycle a PA should display which means "Passed" and is what you want to see.
Image 1: http://media.fotki.com/1_p,sqwrrqkkqkstsftxgtqsskgwtqkq,vi/kkwrfdskkxkgbffwfww/1/1303472/5961857/image53872img-or.gif
Image 2:http://media.fotki.com/1_p,sqwtrsgdwsqtqsqxgtqsskgwtqkq,vi/kkwrfdskkxkktggsfsw/1/1303472/5961857/image53908img-or.gif
From another source...
"Installing replacement motor, motor control harness, and motor control circut board.
Pretty easy install. On a scale of 1 to 10 I'd call it a 3.5.
If you can use a screwdriver, a wrench, and have played with legos before, you can probably do this job.
It took me about 3 hours to do, but this was with inferior tools, and two smoke breaks included.
Minimum tool requirements: Adjustable-head cresent wrench (8 or smaller handle), phillips head screwdriver, utility knife.
Recommended tool equirements: Small ratchet with socket set, ratcheting screwdriver with phillips head and small socket attachments, brew.
The instructions are pretty clear.
Once you pull the front panel off, there are two braces at 45 degree angles on the lower corners of the washer.
The instructions don't ask you to, but I would remove the brace on the left to make life easier.
This gives your arm more room to work and makes it easier to pull the motor out the front.
They ask you to remove the wiring harness from the motor first and then pull the harness out with the control board.
My wrench was too big to get to the bolt to remove the harness from the motor.
All I did was cut the harness - since they supply a new one - then pull out the control board, then pull out the motor.
As far as getting the pulley off, slip it on and off at the large wheel, this is much easier than taking it off at the small motor drive shaft.
The only other thing of note is to make sure you look at the diagram for the conectors a few times before you snap it together.
There are a few ways you could hook it up wrong so pay attention. There should be no loose ends when you finish.
Also, I couldn't get the flange back on on the rear acess panel when closing it up, but it doesnt seem to serve muc purpose besides asthetics, so I tossed it.
The $200 for the parts and shipping was well worth it. I saved about $150-250 to do it myself...."
Thanks for using FixYa - a 4 THUMBS rating and positive testimonial is appreciated for answering your FREE question
Posted on Oct 07, 2010
3 Suggested Answers
milten1
  • 1304 Answers
SOURCE: code lr ?
hate to interject
but lr stands for locked rotor
your motor control has blown a fuse or heat sync.
you can verify this by removing the door and front panel,
the motor control is on the bottom right front
inspect this board with a flashlight
im almost sure you will find some sort of burning
if you do and would like to repair the unit im including a link
that will show you the part you will need
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=47812
make sure you oder the part that comes with a new motor is actually cheaper AP4010145
Posted on Oct 18, 2009
Sheikhtijani
  • 1284 Answers
SOURCE: lr code on waher display panel,what does it mean?
Hi, Lr is the error for a locked rotor. The machine is trying to run the motor but is unable. Usually this the motor control board that is at fault. The first thing to do is make sure the belt is on. After that some tests are have to be made to determine what is going on. Im going to lay out some instructions in case you want to get into this thing. You will have to remove the door by removing the screws holding the hinges on. Same thing for the spacers on the other side. Lift up and remove the door. Pull the front panel forward and lift off. Once the panel is off, set the door back on and close it. Unplug the washer. On the motor control board, bottom right, pull the JP4 harness connector from the board. Plug the washer back in and make sure the door is closed. Press delicates and heavy soil 3 seconds to activate the service mode. Now press the rinse key. Make sure the door is locked by pressing the max extract key. Now press the stain cycle to start motor control test. The motor should run rotating the drum at 50rpms. If the motor doesn't run, check for voltage at the 3 wire harness, MN4, should be 120V. If you don't have the voltage, problem is in the main board. If you have that voltage, then the problem lies either in the motor control, or motor itslelf. On the motor harness, 7 pin connector on the board (middle). Between the brown, white and black wires should all read 6 to 7.5 ohms. Between the 2 grays 150 to 195 ohms. If that checks, then it's the board. If it doesn't check, it's the motor. Ohm checks should be done with the power off.
Take care
Posted on Jun 13, 2010
P1775 code in showing up on my 2008 jeep wrangler x. How do you fix that?
we can not answer what you can do or fix.
only how to diagnose, or is this just a please guess for me post?
got tools, got a real scan tool?
is this a 5 buck code reader that misses most codes.
or a real one (ask for good tools)
if a real tool, it will show all codes, and you must know them all
or go astray. P0841? present? too>?
42RLE box.::: one code only, my guess.
i have this car, (m/t) and full FSM, on it,
Ill decode this and tell you what page to read in the FSM
it shows what to do next and the tests to prove this out.
P= power train
P1 means factory code ( so dont read ford codes)
SOLENOID SWITCH VALVE LATCHED IN TCC POSITION
TCC means torque converter clutch. lock up device. failure.
that means transmission, (id didnt say its bad)
the transmission on your car is automatic, unlike my stick
it has a TCM brain, hidden in the PCM brain
but its real and there. for sure. inside.
and it shifts for you, this brain,. in DRIVE
here is the 1st page on this code. in fsm book.
The Solenoid Switch Valve, an internal, hydraulically operated valve, controls the direction of the transmission
fluid when the LR solenoid is energized. When the solenoid switch valve is in the downshifted position and the
LR solenoid is energized, fluid is directed to the LR element for 1st gear. When the solenoid switch valve is In
the up-shifted position (2nd, 3rd, and 4th gear) and the LR solenoid is energized, fluid is directed into the
Lockup Switch Valve which controls the Torque Converter Clutch. When shifting into 1st gear, a special
sequence is followed to insure solenoid switch valve movement into the downshifted position. The LR pressure
switch is monitored to confirm switch valve movement. If the solenoid switch valve movement is not confirmed
(i.e. no LR pressure when the LR solenoid is energized), 2nd gear is substituted for 1st. No 1st gear (2nd gear is
substituted). The transmission Torque converter FEMCC operation is inhibited. MIL on after 5 min. of
substituted operation.
Monitor Conditions
When Monitored:
Prior to a shift into 1st gear.
possible causes:
RELATED DTC P0841 PRESENT?
(T16) TRANSMISSION CONTROL OUTPUT CIRCUIT OPEN
(T50) L/R PRESSURE SWITCH SENSE CIRCUIT OPEN
(T50) L/R PRESSURE SWITCH SENSE CIRCUIT SHORT TO GROUND
(T50) L/R PRESSURE SWITCH SENSE CIRCUIT SHORT TO VOLTAGE
INTERNAL TRANSMISSION
POWERTRAIN CONTROL MODULE
the book says have the dealer
do a full transmission check using there (unique) fancy tool..
seems to be good advice.
below is the interface tcm.<> box.
solenoid and read back switches.
if the trans is not bad, then this switch is bad (fibbing)
or the wires rusty there... re-seat them yet?
Jul 20, 2015 | Jeep Cars & Trucks
Maytag Neptune front loader, model # MAH5500BWW had a digital error code reading Lr. Will not agitate or spin out.
the LR code means "Locked Rotor". when this happens the cause is one of two items. 1) the circuit boardat the top of the unit has lost connection to the motor and its controlboard at the bottom (connector loose) or 2) the motor and or controlboard at the bottom have trashed and need to be replaced (P/N12002039).
Hope that helps,
Thanks,
Lee
Jul 11, 2008 | Maytag Washing Machines
I have a 2005 dodge caravan the ingine light came on today the codes read p1776 and p0700 what does the codes mean
i'd go with the Transmission Control Module being the cause , either loose connection or worst case needs new unit
Oct 14, 2014 | 2005 Dodge Caravan
What does error code Lr mean
The LR code means "locked rotor" which is just a way of saying the control is not seeing the motor turning. Usually when the LR code is displayed the motor has stopped turning for some reason. By definition the LR code means the control has tried to turn the motor but was unable to. The error code can be caused by to large of load, to much soap/suds in the water or a problem with the spin bearing. The cause of the LR message can be little problem like suds or a major problem like the spin bearing and sometimes it's difficult to pin down. could also possibly be the Water Inlet Valve w/Thermistor #22003834 needs to be replaced due to having Well Water with lots of sand, in the water it is not closing the valve properly allowing water to continue filling the tub, causing it to read the load being too heavy and also leaking out the front door
Nov 27, 2010 | Maytag Neptune Washer
My washing machine now reads lr and wont spin or wash
The lr fault code simply means Locked Rotor.This indicates that the main motor is not being detected as running by the control board in the console.This could be a wiring problem between the motor control board in the right hand base area and the main control board up top.Itmost likely is a failed motor control board or drive motor.
Aug 20, 2010 | Maytag Neptune MAH5500B Front Load Washer
Lr code on waher display panel,what does it mean?
Take care
Jun 13, 2010 | Maytag Neptune MAH5500B Front Load Washer
My maytag neptune reads "LR" when its supposed to spin but doesn't spin what doe this mean
HI, the (lr) represent a Motor malfunction. this is commonly caused by a faulty Motor Control Board. you can confirm by inspecting the wiring harness that connects the MCB to the main control. if the harness is in good condition, replace the MCB.
Jun 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
Display error code of Lr on control panel
L means "Lid or Door Lock" problem
r probably means 'release' I couldn't find it anywhere... so I'd guess that Lr means the machine did not detect that the Lid Lock released and cycle end (which means either the sensor is bad or the Lid Lock dosen't lock the Lid).
Either way, something with the Lid Lock system ais not right. Be glad it releases ;-)
Mar 27, 2009 | Maytag Neptune MAH5500B Front Load Washer
MAYTAG NEPTUNE LR CODE
LR usually means that the the signal from the board is not getting to the motor either because of a bad connection at either the motor or the board or the motor itself is no good. Need to check the connections first.
May 13, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
82 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
