Question about Canon PowerShot SD800 IS / IXUS 850 IS Digital Camera
Where can i buy the outer ring lens cap for a sd800
    Problem Solver:
  • 13 Answers
Try this link hopefully you will find what you are looking for http://www.darntoothysam.com/products/Canon-Powershot-SD800-Camera-Lens-Ring-Trim-Repair-Part.html
Posted on Oct 08, 2010
Where can i buy the outer ring or lens cap for a sd800
http://www.partmaster.co.uk/cgi-bin/home.pl
try this link they seem to have spare parts for just about everything and promise next day delivery if you order early.
Oct 07, 2010 | Canon PowerShot SD800 IS / IXUS 850 IS...
Sunpak 52mm Adapter Ring
Either remove the step-up ring, or get a lens cap to fit the new size.
Jun 09, 2010 | Sunpak 52mm 67mm StepUp Ring T46829
Dropped lense, hit the outer ring, now won't
No quick or cheap fix, but definately a lens worth fixing- send it to Canon
May 11, 2010 | Canon EF 70-200mm f/2.8L USM Lens
Canon SD800 will not turn on.
If youve had it under a year you can try sending it back for warranty and see if they can fix it. However their warranty service sucks if its not actually something wrong with the camera. Maybe try and find a local store that fixes cameras and see if they can clean it out?
Jul 14, 2009 | Canon PowerShot SD800 IS / IXUS 850 IS...
Panasonic DMC-TZ3 Damaged lens rings
i think the colours have gone behind the screen can it be repaired lumix tz7
Jun 20, 2009 | Panasonic Lumix DMC-FZ20 Digital Camera
My Canon Powershot SD800 IS, has had its lens stuck as if it were zooming out.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 10, 2009 | Canon PowerShot SD800 IS / IXUS 850 IS...
I have a canon powershot sd800 IS and the  lens appears not to want to close! The camera is just over a year old and rarely used!
Jan 24, 2009 | Canon PowerShot SD800 IS / IXUS 850 IS...
Want to buy a dx6490 outer lens
if you cant swap one yourself from a dead camera it would be beyond economical repair.
If you are adventurous you could buy a faulty one of ebay and swap the lens or if the faulty one has a broken screen or mode dial swap yours over to the faulty one..
there are a couple of "tricks" do getting this camera open drop me a line if you decide to proceed...
best of luck
Apr 10, 2008 | Kodak EasyShare DX6490 Digital Camera
FZ18 Lens Cap error message with telephoto converter
I have the same camera, and had the same problem. Make sure the camera is switched off. Then take 2 hard pieces of plastic with sharp ends. Carefully try & jam the outer ring with one, and try turning the converter with the other. I used a mini screwdriver, and left some marks on my camera. Thats why I recomend using plastic of some kind.
When you use the converter, switch off the battery saver in the camera. That way the converter won't jam again, as the camera won't switch off automatically. There is also a programme in the menu that is used for converters and external lenses. It also prevents the lens from retracting completely.
Hope I have helped you.
DaveSA
Mar 21, 2008 | Panasonic Lumix DMC-FZ18K Digital Camera
Lost lens cap
I would sugest using an adaptor ring. You can reduce the size of your lens opening down a common size lens cap that will fit your camera. If you can't go this route then give me the make and model number and I will see what I can do for you. LJ
Sep 18, 2007 | Konica Minolta DiMAGE Z20 Digital Camera
Canon PowerShot  SD800 IS / IXUS 850 IS Digital Camera Logo
77 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
