Question about Philips GOGEAR SA6045 MP3 Player
Song information not transfered correctly
I have the SA6045 (8g) player: The problem - When I transfer songs from Win. Media player not all the information is transfered. So, it becomes ..unkown.. (Artist, genre, song title [maybe there, may not be]). I've also notice that sometimes when I look at the 'unknown' there is a list of songs "// " or it is Chinese characters.
Any ideas why?
  • 8,596 Answers
Corrupt dB - get the latest firmware and try again. If the Philips Device manager does not load the firmware or does not recognize that your player is plugged in:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on May 30, 2008
I need some instructions on how play it
1. Use Windows Media Player to put songs on your Coby MP3 player. Download songs in MP3, WMA, or OGG format from a legal downloading website. If the file is not one of the previously mentioned files, you must download a converter to convert the file to one of the correct files that can be played on Windows Media Player. Rip a song from a CD by inserting the CD and then click on the option to "Rip" the song to your library. Some Coby MP3 players do not need Windows Media Player to add songs, so be sure to check your user manual to see if there is an even simpler method.
2. Connect your Coby MP3 player to your computer using the USB connector that came with your MP3 player. The player will show up under the "Devices" option on your Window Media Player application.
3. Click on the "Library" option to view all of the songs stored on your Windows Media Player library. You can drag the song to the MP3 player in the "Devices" section, or you can right-click on the song and choose the option to transfer the song. In the pop-up box choose your MP3 from the drop-down menu and then click on the "Transfer" button.
4. Right-click on the MP3 player in Windows Media Player and choose the "Eject" option. Disconnect your MP3 player from your computer and turn it on. The song will now be available on your MP3 player. Press the bottom button to play or pause the song.
5. Add videos and pictures to your Coby MP3 player if it supports those files. The process is similar to transferring audio files. Plug your MP3 player into your computer. Open the photo file on your computer and drag pictures into the player. You can create folders to organize the pictures.
Sep 30, 2009 | Coby MP-C552 MP3 Player
Limewire 5.0 sucks!
There are several things that I can see that might be driving your mp3 player haywire:
A) About 1/3 of Limewire songs contained some type of writing in the "Comments" section of the songs' ID3 Tags before version 5 - it may be up to 100% now, and your player obviously doesn't like it. This is going to be a real bear, but I would take one of the songs you just downloaded, open it in Windows Media Player, and right-click the song title within Windows Media Player. Select "Advanced Tag Editor," and delete any writing that appears in the "Comments" section of the ID3 tag. Then try transferring that song to your player and see if it plays correctly. If it does, repeat with all of the songs you just downloaded. It will take you forever.
B) If you use iTunes to transfer songs to your mp3 player, version 5 will not work with iTunes - it simply pastes a data file into iTunes which is not the actual song, so it may appear to transfer correctly, but in fact you have not transferred the actual song file. Use Windows Media Player to transfer instead.
C) The bitrate on songs in version 5 is higher - most mp3 players have a maximum bit rate that they can handle, and ver. 5 might exceed this upper limit. The solution would be to convert all of your mp3 files to a lower bit rate using free software such as Media Monkey.
Without dragging this explanation out any longer, I think your best solution would be to revert back to Ver. 4.1 or so.
-Tha Mp3 Doctor
Mar 31, 2009 | Nextar MA933A MP3 Player
I cant get songs from Limewire 5.1.2 onto my Sanso music player. I used to be able to on 4.1.2 idk whats wrong -Music fan
-Tha Mp3 Doctor
Mar 30, 2009 | SanDisk Sansa Clip MP3 Player
Sansa c250
Make sure the songs are in the correct format - not every music svc song has "transfer rights" that allow you to transfer them to player
Convert them to mp3 format, and you'll never have a problem
Jun 20, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Problem in loading song in device
Tracks must be transferred using the Musicmatch Jukebox software supplied with the player. You cannot drag & drop from Windows, even though the player shows up as a removable drive. Musicmatch transfers the tracks, and alkso updates the file list on the player. If the tracks aren't on the file list, the player will ignore them.
Also, you need to have Windows XP and Windows Media Player 10, as Musicmatch uses drivers from version 10.
If you have Windows Media Player 11 installed, you will need to uninstall it to roll back to version 10.
If Musicmatch still doesn't transfer correctly, click on options / tools, and make sure that the device is recognised as "GoGear" , and not "Removable drive"
Apr 03, 2008 | Philips PSS110/17 MP3 Player
Notification "Cannot play"
The songs are in the wrong format.
The format of the songs are wrong in one way or another. Each Mp3 player has a product spec sheet that lists which type of music file it is compatible with (Mp3, WMA, WAV, AAC, etc). You can't play iTunes songs, which are AAC format, on a player that only accepts Mp3 or WMA format.
The second formatting issue has to do with the DRM license on the songs you have downloaded. Right click a song that gave you an error, click on "Properties," and click on the "License," "Media Usage Rights," or "Digital Rights Mgmt" tab (wording varies by configuration). Not every song allows unlimited or even one-time transfer to a "portable device" (code word for "Mp3 player" in this case). Also, some songs are fixed-term - they expire after a while - sometimes in as little as 24 hours.
To get around this, convert every song to Mp3 format. Either that, or upgrade your music service subscription to the highest pkg they have available and never cancel (Napster's basic music svc, for instance, does not let you transfer to an Mp3 player, but their "Napster To Go" upgrade does allow transfer).
-Tha Mp3 Doctor
Mar 18, 2008 | Sony NW-E107 MP3 Player
I can't transfer any song
Try using windows media player to transfer the songs or if all else fails, use explorer.
Feb 13, 2008 | Sony Network Walkman NW-A1200 MP3 Player
Transfering songs
-Plug in your mp3 player
-Go into 'Limewire', select a song and go 'Locate file/Open Containg Folder', you should be in your folder with all your songs. or go 'My Music' and find your music files.
-Either select all your songs, open them with 'Windows Media Player' and transfer them that way.
-Or 'Open My Computer' then open 'Sansa e200' and drag the songs from where your songs are located [My Music] to the 'Music' folder in your Sansa e200 folder.
[MyMusic] Song.mp3 >drag to> [MyComputer/Sansa] Music.
Dec 26, 2007 | SanDisk Sansa e200 MP3 Player
Basic Transfer of Songs on my computer to White 4GB MP3
http://www.askdavetaylor.com/how_do_i_put_music_on_my_apple_ipod.html
Dec 01, 2007 | Apple iPod nano
Rca H106A 6GB player
Sometimes all you need to do for that is profile the songs. This organizes the songs into the correct catagories.
Nov 27, 2007 | RCA Lyra RD2763 MP3 Player
Philips GOGEAR SA6045 MP3 Player Logo
155 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
