Question about Lexmark X5470 All-In-One InkJet Printer
Right cartrage incorrect
Each time i insert new ink, my machine don't accept it and will not work. PLEASE HELP!
    Genius:
  • 1,847 Answers
Your printer cartridge should be
Black: 32, 34 High Yield ● Color: 33, 35 High Yield ● Photo: 31
else it will not accept the cartridge.
hope it will help..
Posted on May 29, 2008
Inserted new ink cartrage, but printer saying remove tape from the ink cartrage. I've done that but it still say error. Also the not printing correct. I've had the ink cartrage for a while could that be...
Clean the contacts of both the cartridge and the print head with some alcohol. Reinsert the cartridge.
Power off the printer and wait 1 minute. Power if back on and then make it go thru calibration cycle if it
has one.
Mar 23, 2011 | Office Equipment & Supplies
Installing ink cartrage in a royal 435dx cash register
1. Open the printer compartment by lifting the black, plastic printer cover.
2. The ink roll is found in the front of the printer compartment, just behind the print
head, and is mounted in a plastic cartridge.
To remove, grasp the small clip on the left of the ink roll (where the words "PULL UP" may
be printed on the ink roll cartridge) and pull up.
The ink roll will easily pull up and away from the print head.
3. To replace a new ink roll, insert the ink roll according to markings "L" (Left) and "R"
(Right) by pressing downward to lock it into position, then close the printer cover. No tools
are necessary.
For best performance, store unopened ink roll package in a cool, dry place until installed.
NOTE: Replace with ROYAL Ink Roll, Part #013109.
Nov 16, 2010 | Office Equipment & Supplies
Changing the cartridge
most new machines will not work with refiled cartridge`s the samsung and the lexmark ar the two that play up the most, because refild cartrages now have an electronic chip in them , the cartrage is telling the machine that it is empty and thus the machine is not accepting the cartrage
Apr 12, 2010 | Samsung SF-565 Laser Fax
Replaced the magenta cartrage. arror check Ink
The Error "Check INK U140"
Causes : Possible causes are as follows :
* The ink tank may not be installed properly (The lamp on the ink tank is off).
Install the appropriate ink tank.
* The ink tank not be compatible with this machine. (The lamp on the ink tank is off).
Install the appropriate Ink tank.
The machine will not print of the wrong type of ink tank is used or if it is installed incorrectly.
Be sure to install the ink tanks in the proper order. The proper arrangement from the left to right is Black - (CLI-8BK), Black -(PGI-5BK), Yellow - (CLI-8Y), Magenta (CLI-8M), Cyan (CLI-8C).
Replacing Tanks
1) Ensure that the machine is on.
2) Raise the Scanning Unit (Printer Cover) until it stops.
The Paper Output tray will open automatically and the Print Holder moves to the center.
Impoprtant : If the Scanning Unit (PRinter Cover) is left open for more than 10 minutes, The Print Head Holder moves to the right. Close and reopen the Scanning Unit(Printer Cover) to return the Print Head Holder to the center.
3) OPen the Inner Cover.
4) Press the Open button to open the Paper Output tray if it does not open automatically and remove the ink tank whoe lamp is flashing red fast. Do not touch the Print Head Lock Lvever. Remove only the ink tank.
Important : * Handle the ink tanks carefully to avoid staining clothing or the surrounding area.
* Discard empty ink tanks according to the locakl laws and regulations regarding disposal of consumables.
Note : Be sure to replace ink tanks one by one when replacing more than one ink tank.
5) Prepare a replacement tank.
a) Remove the new tank ink from its packaging, then pull the orange tape so that the protective film does not remain on air hole. Then remove the film.
b) Remove the orange protective cap from the bottom of the ink tank and discard it.
6) Install the ink .
a) Install the ink tank into the Print Head.
b) Press on the Push button on the ink tank until the ink tank snaps firmly into place.
c) Ensure that the ink tank clicks into place and then its lamp lights red.
Important : Make sure to install all the ink tanks to enable printing. The machine cannot be used unless all the ink tanks are installed.
7) Close the Inner Cover.
Note: Ensure that the Inner Cover is closed, Printing will not occur if the Inner Cover is open.
Hope this help. PLease rate my response.
Thanks
have a good day.
Nov 23, 2009 | Canon PIXMA MP530 All-In-One InkJet...
How to refil Cannon LBP2900 cartridge
you do not have to take the whole printer to the shop to fill the ink cartrage if you have the manuel to the printer it should tell you how to remove the ink cartrage and replace it with a new one and also they may have a refill kit at one of your local computer stores or where they sell ink and they should be able to tell you how to get the ink cartrage out to replace it
Sep 02, 2009 | Canon LASER SHOT LBP-2900 Printer
K7100 black cartrage error (unrecognized)
push and hold the reset button for several minutes until it works again
May 27, 2009 | HP OfficeJet K7100 Photo inkJet Printer
Wont read ink cartidrige
first try taking out the cartrage and try uninstalling the printer off your computer then reinstalling it. before putting in your cartrage make sure your computer detects it and your computer should tell you that it detcets no ink then try replacing it. if the problem consists make sure youave the right cartgae for that printer. Then check that nothing (paper, pen, anything) is stuck or jamming the computer blocking the cartage sensors,
Jan 17, 2009 | Epson PictureMate Photo Printer
Lexmark x1190 no black ink comeing out
you may need to reinstall the cartridge once again and test
Sep 27, 2008 | Epson Stylus 880 InkJet Color Printer
Lexmark X5470 All-In-One InkJet Printer Logo
133 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
