Question about Kodak EasyShare V1003 Digital Camera
Camera dropped in a kiddie pool (NON-CLORINATED)
The camera barely went under the water but for electronics water doesn't mix well. We put it in a bag of rice and the next day it turned on but the flash won't work and the menu buttons on the back aren't working right. I am sure water is not covered under warranty.... so... do you have any suggestions on how to get it functioning again? Maybe a new battery? The camera was off when it him the water.
    Scholar:
  • 66 Answers
Well you are right , water and electronics don't mix but you may be able to save it. I did this just the other day with my digital recorder that fell out of my pocket and into a tub ow water. chances are 50-50. i quickly grabbed it and removed the batteries. Opened op the case as best I could and let it sit for a few days. Moister rises. If you place a plastic sandwich bag in an area of humidity, say outside, it will collect moister. people say to place carpet in the garage to stop moister but this just collects it as it drops from the car as it rises in the air. Anyway, a hair drier will speed things up also. It may or may not work again but it is worth a try. Be careful, the electronic flash device will give you a shock you will never forget if the photo flash capacitor is still charged. My digital recorder works great after taking it apart and letting it dry out. If using a hair dryer put it on the lowest setting. Wait a few days and re-charge or re-place the camera battery and give it another go.
I hope this helped some and let me know the outcome.
Kevin
Posted on May 29, 2008
My camera fell in the pool
Put it in a bag with dry uncooked rice and contact a repair centre that is specialised in repairs of electronics that fell in the water.
Feb 06, 2014 | Canon EOS 550D Rebel T2i Digital Camera
Ph level and clorine level too high
get in the pool companies to adjust the levels to correct and remove the alge growing in the water
Nov 04, 2017 | Intex Automatic Salt Water System for ...
It got wet on the beach. water went into the camera and it won't start anymore.
The best way to try to recover items that have had water damage is to place them in a container with the gel packs you find in new shoes. If none of those are available to you try putting the camera in a ziplock bag with rice. This will absorb any moisture left in the camera. Take out the battery and memory card before trying either of the prior options.
After you have let the camera sit with the gel or rice overnight or for several hours, remove the camera from the bag and blow off any dust from the rice. Make sure that the inside of the camera is clean and dry (where the battery goes) Then put the battery and memory card back in. Make sure that the battery is fully charged and try turning it on.
If that doesn't work try going to a specialty camera store such as B&W. They can help you further and instruct you on how to procede.
It is advised not to get any digital electronic wet as most are not water proof and will be damaged by any exposure to water.
Jul 02, 2011 | Cameras
My pentsir clorinator seems to not be working, my pool keeps clouding up
There can be a couple of reasons for this issue. First, have you had your water tested lately? In the manual, there are specific levels of chemicals that need to be watched so the unit will work more effiecently. Another item is have you cleaned the unit lately? If not, try to clean it. First with the garden hose on high pressure, if you have tried this, then it is time for a chemical bath.
To do one of these, you will need muriatic acid, water, two buckets, and a freezer bag and rubber band- if you do not have the chemical cleaning accessory kit. You will need to mix the acid and water in a 1 to 4 part mixture, 4 parts water to 1 part acid, in one of the buckets. Then turn off the pool system, if you have the check valve in front of the IC, close that also. Then remove the unit from the piping, on one end you will see a metal piece-looks like a flap hanging down- this is the flow meter for the unit. On the end with this, take the freezer bag and lay it across the opening, put the rubber band around the bag, this will make the cleaning MUCH easier. Once that end is sealed, place the unit, with the sealed side DOWN into the other bucket. Then pour the acid mix into the cyclinder, make sure to cover all the inside of the unit. You can wait five minutes, or until the bubbling stops, before pouring the mixture out of the cell. Rinse the unit with the garden hose and reconnect it. See if this helps, but I would DEFINATELY have the water levels checked first.
If you can give more details, like are there any lights on, or off, on the unit? How long have you had the unit will help also.
Jun 28, 2009 | Pentair 1 1/2" Chlorinator Chlorine...
My water turns green when we shock it I have drained twice now Please help!!!
start with testing your chlorine and ph add liquid shock and conditioner to water dont use algecide you have to get clorine to open up this is critical ph clorine and conditioner you should get a good clorine reading or you have to add more shock
Jun 16, 2009 | Intex Automatic Salt Water System for ...
Too much salt in pool (4,100)
the leslies employe is right the only way to get rid of the high salt level is to drain the water i would say drain a 3rd and fill pool and check salt level some salt genarators can not make chlorine at high salt levels or when the water is cold
May 19, 2009 | Jandy Aqualink Rs4 One Touch Control...
Water damaged n95
try this :
This works on most mini electronic devices like cellular phones and degital cameras etc .
it sounds crazy .
Remove the back (or Cover ) of the phone( or Camera ), battery, and SIM if your phone ( or Device ) uses one , DIRECTLY
Then, with a q-tip (or something similar), dab the connection points (shiny, goldish) on the battery, SIM, and phone. This should aid in drying.
Finally, place all contents in a bag of uncooked rice (separately, do not put back together just yet). it sounds crazy , but it draws the moisture out.
It normally is working after just 7-8 hours, but I would wait 12 hours or even 24 hours before attempting to use (just to be sure).
beware the water damage, despite being dry now, will void any warranties. Also, the phone's hardware is now weakened and if you drop it, the green mother board and circuitry could shatter - so be more careful.
This does work on electronic devices aside from phones as well. Simply tailor it to your device. If you do not have a SIM (Verizon phones, cameras, all others), remove only the battery. If you have an iPhone/iPod or GPS and cannot remove the battery, simply make sure it is all the way off, then put it in the rice bag. All electronic devices react the same to the rice trick.
related link is here : http://www.youtube.com/watch?v=0-Otjgd48nY
rate if useful please !
Dec 29, 2008 | Nokia N95 Cellular Phone
Dropped camera in pool
If it does not fire up, I would dunk it again - this time in warmed, distilled water, moving it around a bit, then putting it in a warm (not hot) place to dry but I would probably give it a week.
Distilled water is non-conductive whereas pool water is . . . who knows?
Jul 10, 2008 | Canon PowerShot A520 Digital Camera
Open camera and place in a bag of rice for a couple of days to absorb moisture.It's worked before on cell phones.
Jun 30, 2006 | Canon PowerShot A70 Digital Camera
Kodak EasyShare V1003 Digital Camera Logo
52 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
