Question about Century New Magnetek Pool Spa Pump Motor 1081 15 hp
Plugged pump in and heard it kick on but it wont turn over. Help!
    Top Expert:
  • Century Master
  • 5,061 Answers
Try spinning motor by hand from back then try again if not replace
Posted on May 25, 2016
2005 pt cruiser wont start replaced fuel pump, is getting spark,and turns over. yet wont start help
Do you have a check engine light, what is the code. Do You have fuel pressure. You changed the fuel pump but is your fuse and relay good to the fuel pump. When you turn the key on do you hear the fuel pump kick on. It should come on as soon as you turn the key on, not just when you try to crank it. If you have a code it would help.
Aug 14, 2017 | Cars & Trucks
Just replaced the fuel pump on my 95 explorerthe truck cut off while i was driving and wont start up again
first you need to find out if the fuel pump is kicking on or not by turning the key forward (without starting the car) and listening for a humming noise coming from the gastank (your new fuel pump) if no noise is heard, you need to check your connections.
Jun 30, 2010 | 1995 Ford Explorer
Washer was running doing load and heard a solid beeping the h and f were flashing on panel heard pump sound like it was working but machine had already drained water unplugged and waited plugged in socket...
This error code means"No water detected entering machine or Pressure switch trip not detected".
Is the machine getting any water? Check that the water supply is turned on.
Press pause cancel twice to clear the display.
Try to run another cycle.
Let me know if I can help with anything else.
Mar 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
03 monte carlo wont start... turn key to AC position, hear electrical motor sound never heard before... turn to ON position, all gauges drop to zero
the noise your are hearing is the fuel pump, you might need a new battery by the sounds of it, or your ground is corroted or your connections arent tight and could be causing the power failure,check your battery system over and down to the starter, if its not grounded right it wont start it will just go blank.
Nov 03, 2009 | 2003 Chevrolet Monte Carlo
1999 GMC Suburban Wont Turn Over
It sounds like you have a security problem, I had the same thing it would fire and run for half of a second and then that was it if anything at all. Had the security system rebooted, now it starts and runs fine.
Jun 07, 2009 | 1999 GMC Suburban
My cavaliers fuel pump wont kick in when the key is turned on
you should be able to find a fuse in the line that triggers the relay
Jun 03, 2009 | 1997 Chevrolet Cavalier
Ktm 530 /08 model has 88-100 miles on it i cant keep it running,wont start wont kick ,some times i can kick and then use electric start, if i turn it off battery seem dead, 3rd battery ,dealer is scra
This is obviously a problem in design of the bike. Weak circuit board design creating a shallow spark or mis-timed spark, OHC timing far too radical, carb design not compatible with the bore of the bike, factory valve angles out of whack, something, or several somethings have converged in this bike. Does your state have a "Lemon Law"? Many states have this and it forces the dealer to refund your money or replace the bike. Contact the KTM Corporate office > > KTM-Sportmotorcycle AG
Stallhofnerstraße 3, A-5230 Mattighofen
Tel. +43 7742/6000-0, Fax. +43 7742/6000-0
May 29, 2009 | 2008 KTM 530 EXC-R
Truck wont restart when it's ran for greater than 5 min.
Will it restart warm if you hold the accelerator to the floor?
Apr 02, 2009 | 2000 Ford Ranger SuperCab
Century New Magnetek Pool Spa Pump Motor 1081 15 hp Logo
85 people viewed this question
Top Century Pool & Spa Experts
Jay Finke
Jay Finke
Keith Poitier
Steve Slater
Are you a Century Pool and Spa Expert? Answer questions, earn points and help others
