Question about GE DVL223EBWW Electric Dryer
I have a ge model # DVL223EB4WW dryer. i want to replace just the coil can you help
4 Suggested Answers
dmftrucker
  • 1922 Answers
SOURCE: I have a Ge dryer (model# DVL223EB4WW) and it runs
check to make sure you have 240 volts input to dryer,then check for burned off neutral power wire ,power terminal board,hi-limit switch,thermal switch,heat cycling switch,bad heat element
Posted on Nov 09, 2009
hunter19_46m
  • 7482 Answers
SOURCE: ge dryer model DVL223EA0WW service manual to replace heating coil
Try this website, they will have everything you need.
http://www.repairclinic.com/SSPartDetail.aspx?PartID=2512&Acc=1&PPStack=1
Good luck,I hope this helps
Posted on Nov 13, 2009
hunter19_46m
  • 7482 Answers
SOURCE: how do you take apart the ge dryer model
Hi bprobst660...
Here is a little more than you asked for but, I thought that once you have it apart you might as well do a little service to it to save having problems in the near future.
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place, some seals are furnished with the cement to glue it in place.
Note: This method works for most front loading machines.
Remove the electrical console that holds the timer switch,start switch, etc. from the top of the dryer if necessary. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the two screws that hold the filter housing to the top of the dryer lid.
Then remove the top of the dryer by inserting a screwdriver between the top and frame on each side of the dryer lid in the front to pop the lid up from the retaining clips.
Note: Some of the tops tilt backwards on a type of hinge and do not have to be removed completly.
Remove the front of the machine by disconnecting the door switch and removing the two screws located on either side of the dryer frame.
Move the door and front of machine forward to remove.
This will expose the belt,idler bracket and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
Note:The way the belt goes back on is, as the belt comes off the drum has to be doubled (pushed together to form a loop) and goes under the idler pulley then to the motor pulley.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil or a vasoline type of lubricant. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
This is a FREE answer, Please take time to rate me
Posted on Jun 29, 2011
How do I replace heating coils
Most GE models goes like this....
Remove top cover.
Remove front door panel
Remove belt.
Remove drum cyinder.
You will see the heating element.
Jul 31, 2014 | GE DBSR453EBWW Electric Dryer
Ge dryer Model # DPSR473EWOWW coil proper installation
once you get the dryer apart & remove the drum its very simple
a 10 minute job if that & if your not sure get a service tech so you dont do more damage
Apr 21, 2014 | GE Profile DPSR473EW Dryer
Just put a ignitor for my ge gas dryer it ignites the gas after 2 min flame goes out
This is usually the dryer coils have failed. They tend to fail as they heat up. They are inexpensive and easy to replace. Here is a video on replacing the dryer coils.
Mar 03, 2011 | GE Dryers
I have a Ge dryer (model# DVL223EB4WW) and it runs but doesn't heat up. The breaker is on and I inspected the chord and it is in good shape. What do I do from here?
Nov 09, 2009 | Frigidaire GSGQ642A Gas Dryer
Dryer stopped heating
Sounds like your problem may be with the heating coil.
Remove the back of the machine and try to locate the air duct going from the blower to the drum. Normally inside the air duct you will find the heating coil and the thermostats/thermistor.
Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the safety of overheat from the machine.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
Hope this helps
Nov 03, 2009 | GE DSXH43EF Electric Dryer
GE gas dryer will work intermittenly
coils will get warm then stop working. change them all 3....have seen this many times!
Aug 07, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
MY GE GAS DRYER WILL NOT HEAT UP
check an pop the lil plastic cover on the front of the dryer an then turn the dryer on an see if the igniter glows after 30 secnds if it glows........** you probably have bad coils****if it doesnt then check the thermal fuse for continuity if is not checking ok replace it , that is one of the most common causes,
steps
1 check igniter for glowing
2 check thermal fuse for continuity test
3 if they both check ok an still no heat change the coils
good luck!
May 26, 2009 | Frigidaire GSGQ642A Gas Dryer
Timer only works on Timed Dry Setting
Check your heating element. If one coil of the heating element is burnt out the dryer will heat on the remaining coil, but the timer will not advance in automatic dry.
Nov 13, 2008 | GE DBSR453EBWW Electric Dryer
Heater coil
have to remove drum to acess hater coil ..all ge dryers are behind drum ck continuity first also ck for burnt wires
Sep 04, 2008 | GE Dryers
GE DVL223EBWW Electric Dryer Logo
212 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
