Monitor 41 will not light and shows for bar then shuts down. ckeck flow of fuel fine
    President:
  • 2,777 Answers
What is the make of this Monitor 41? And it shows "four" bars you mean, on the display and then shuts down? And you say you did check the fuel line? Does the fuel line appear fine?
Thanks
Tim
Posted on Oct 07, 2010
  • 1 more comment
  • Tim Grayson
    Tim Grayson Oct 07, 2010
    Ok let me research this for you for a bit here.
    Thanks
    Tim
  • Tim Grayson
    No problem still working on it here.. if you don't hear from me within an hour or so please post another comment, until then though please hold off because it I don't respond fast enough it will close out the question automatically.
    Thanks
    Tim
  • Tim Grayson
    Tim Grayson Oct 08, 2010
    Ok it looks like the control unit of your system is the culprit here, it is the main "brain" of the unit so to speak. You are going to need to call MPI for the part... and / or have them service the unit. Their number is 800-524-1102.
    Thanks, sorry about the delay,
    Tim
Car idles fine, but sputters, bogs and dies if gas pedal is pressed.
new spark plugs this decade. (a tune up?0
the filter is part of all 60k tuneups. letting it clog wrecks good pumps.
my wild guess, its lack of fuel flow, do to old filter.
or low fuel pressure.
car is identical to a Corolla. so is not unique or rare as some Geo cars are.
the cam belt not changes, invites valve kissing piston tops. BOOM
end of engine. (costs more to fix then worth of car)
the word is bogging, my engine bogs
if if bogs WOT (wide open throttle) and dont catch up < ITS NOT THE TPS. ever.
tps bad causes short bogs, called hesitations.
The map sensor , is what measure air flow and the ECU matches fuel to this air flow.
my guess, is it does that, but fuel pressure is like 15PSI, bad.
Apr 14, 2015 | 1995 Geo Prizm
Check engine light came on vehicle shut down,Nissan Wingroad Y11,on checking with tech it showed Air flow censer, changed it drove about 50metres light came back on car stutter shut down. help
First inspect the boot from sensor to the intake manifold for cracks,inspect all the vacuum hoses to the intake.
second unplug the connector and inspect the terminal.Sometimes the plastic is burn and the wire pusht out of terminal. insert the wire all the way in or replace the pigtail.
plug scanner and monitor the air flow and air temperature on live data.
inspect the wire harness for damage to engine ground.
good luck
Apr 07, 2014 | Cars & Trucks
Dell optiplex 170l screen problems on shut down
Disconnect the monitor cable from the computer and power on the monitor. It has a built-in diagnostic program. If you see color bars floating around the screen then you monitor is O.K.
Jul 24, 2012 | Dell Computers & Internet
Problem with monitor
Since the monitor is working normally other than turn off, I suggest plugging it into a power bar with switch. The pad switch is probably defective in the monitor.
Mar 11, 2012 | Dell Computers & Internet
30 hp yamaha outboard
ckeck where it is leaking then pull the carb off sounds like you need new gaskets
Jun 09, 2009 | Boating
What would cause the monitor to show safe mode?
when you press all keys of key board or when you press unwantedly
from nischal
nisc
Mar 28, 2009 | E-Machines eMachines Desktop PC
Monitor 41 20 years old rebuilt 3 years ago. out of fuel
Hope you got this fixed. Sounds like you were having fuel flow problem.
Jan 17, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
Sensor dry timer problem
Clean off the moisture sensor bars. They are the silver curved strips about 4 inches long inside the drum near the lint fitler. If you use fabric softner sheets, a waxy build up will coat the bars. The dyer can no longer sense the damp clothes, so it goes into the cool down and then shuts off. Time dry bypasses the moisture sensor.
Nov 30, 2008 | LG DLE5977 Stainless Steel Electric Dryer
MPI kerosene Monitor Heater
need to bleed air out of filter at oil tank crack open the screw on top it will bleed out air wait until oil starts to run out then tighten back and bleed at heater on right side lever inside hole push and let off slow 4-5 times and restart
Nov 02, 2008 | Rinnai Toyostove Direct Vent Heater: Laser...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
