This problem should be removed because:
Problem with PC Desktops
action failed for file avgwdsvc.exe: starting service...
Error 0x800736b1
Solutions (13)
Best Solution
Error 0x800736b1 AVG - resolved by START-RUN-services.msc - WINDOWS INSTALLER -make it automatic and start it.
Okay this is probably the best solution you can get right now. I am a IT tech and well it took me a good couple days of tryin different steps and well this webpage has the best solutions to follow. it gives you steps and all. try it all and you should find your answer. Its under 1623: Message "Application failed to start". http://free.avg.com/faq.num-1623?srch=Action|Failed#faq_1623 is the webpage
Having had the same problem I did the following to resolve the issue:
Run SERVICES.MSC from the start menu
Find the AVG Watchdog service, open it up and set it to disable
Reboot
Run REGEDIT from the start menu
Click Edit and Find then search for 'Watchdog' (excluding quotes)
Check the permissions for the key found to make sure 'administrators' is listed with read/write access
If 'administrators' is missing, add 'administrators' as a user and tick read and write and click ok
Press the F3 function key to repeat the search and find every instance of Watchdog and check the permissions for each.
Once you've changed the permissions (I found 3 missing administrator entries) you can re-run the installer and choose 'repair' which should now complete and go through the standard setup questions, reboot and you're done.
starting service failed because of file avgwdsvc.exe
error 0x800736b1
Be sure that your Windows Installer is not disabled or turned off. In Start>Run type gpedit.msc and click OK. The Group Policies window opens. In both Computer Configuration and User Configuration go to Administrative Templates>Windows Components and find Windows Installer. In both places, be sure that it is not disabled or turned off.
This solved the AVG install problem for me. Good luck
I had the same problem on WIndows XP 32-bit trying to reinstall AVG 8.5:
Error 0x800736b1
AVG 8.5 was running fine before I did a System Restore, then it stopped working. I suspect it was due to a corrupted .NET framework 2.0. I finally fixed this by updating the .NET framework to 2.0SP2, fully uninstalling AVG with the avgremover tool found on the web (regular uninstall woudn't work), plus I installed and ran CCleaner (also found on the web) to clean out all of the remaining AVG keys that avgremover missed. I then removed the old Program Files/AVG directory and reinstalled AVG 8.5.
my pc have virus and i know what i can do for this problem
you most likely need to reinstall the avg internet security program. whenever you get errors like this, it usually means that the software has gotten corrupted for whatever reason. either through a bad update or some other type of bad luck. reinstall and your problem should be gone.
agent 10708
action fail foravgwdsvc.exe file.i have this problem .what can i do.?pls give me ans
action failed for the avgwdsvc.exe starting service
please help me to instal the avgwdsvc.exe
This is whenever I get an update from AVG .
pl. keep windows xp firewall on to solve this problem.
Suggested Solution (2)
Try avast av go to avast.com and download the free version. It's very good. You need to sign up with an email address they will send you a key to copy and paste and it will be good for 14 months then you will need a new key. I've used it for years for free.
I bought a new HP
I bought a new HP 2133 mini note pc which has Windows Vista on it. I have been trying to download the avgfree 8.0 antivirus program. It...
I have a virus on
I have a virus on my laptop and can not get past XP2008 anti virus software without them wanting me to buy it. I have downloaded AVG virus...
AVG
how di I fix this problem? Local machine: installation failed Installation: Error: Action failed for file avgwdsvc.exe: starting...
desktop has serious problems with
desktop has serious problems with no antivirus program installed. Am trying to install AVG free 8.0, and keep getting Error: Action failed...
Add Your Solution
Hi, I have a desktop computer, when you switch it...
Then I was change the RAM,and HDD.
when i enter my pes 2012 dvd it doesnt appear in...
when i enter my pes 2012 dvd it doesnt appear in my dvd rom ,i have windows xp sp2 pentium dual core 2.5 ghz ,2 gb ram...
Fix-O-Meter
35,518
35,518 people viewed this problem
- 28 people found this problem to be helpful.
- 0 people are following this problem. Be the first!
Top PC Desktop Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
