Question about Cobra 29 LTD CB Radio
Never will get caught , everyone should crank it...
  • yadayada
    yadayada Oct 07, 2010
    what is your question here?
    Guru:
  • 773 Answers
FCC no longer monitors CB communications. As well they want little or nothing to do with issue reported about CB radios. The FCC has less then 16 field offices in the US today. They do not have the funding to police CB radio. Its also in the 27 MHZ band, which is only used today by CB radio, and toys.
Every thing else today is going up in frequency. Cell phones are in the 800mhz range etc. There is no money in the 27mhz band.
The FCC rarely fines any one with CB radio's runing illegal equipment. Nor do they even rarely make appearances at people dwellings who run illegal equipment when reported. At most they send a letter telling them to stop using illegal equipment.
And by no means would they even attempt to pay attention to some one running a barefoot radio that has been peaked and tuned and doing some where around 20 watts.
You would have to be running multiple kilowatts and have half of a town reporting you interfering with all of their appliances before they would be knocking at your door.
Never will get caught? Heh, Never will be paid attention to is more like it.
Posted on Oct 08, 2010
Replaced intake gskts sprayed crbs replaced kill tarter cntrl cranked engine sprayed wd40 in carbs. doesnt want to fire chirping sound coming from carb area on L side bought the bike non running help
1st make sure the fuse is good under seat near battery !! then take out one spark plug and rest it near metal (don't hold it !! ) and crank engine over (key on) do u see a blue spark on end ?? if so you have fire , if not you need to go further to see why , connectors on plugs I find are the \\biggest problem on bikes now , seems they don't make em water proof !! and everyone tries to avoid it but they allways do get caught out in the rain sometime !! the rain doesn't effect em right away takes a few days then the little pins in there get what looks like "baby powder" on them that's the bad stuff it all needs to come off !! bike don't run till there clean and bright again !!
Dec 13, 2016 | Motorcycles
How to replace crank sensor
Look for it's location from a picture
on the internet & remove one bolt to
replace
If it starts & runs okey & you have spark
& injector pulse, only the proper testing
with an oscilloscope will caught a failed
part
Only replace tested parts that fail a test
Codes have nothing to do with parts replacement
Jul 30, 2014 | 2003 Isuzu Ascender
Irobot roomba won't work
This message sometimes happens when it\'s jammed or caught. I would open it up and really clean everything out to make sure the brushes are not jammed. Also pop out the ball white/black wheel at the front and remove all the hair around the axle for this.
This almost sounds like something caught in the wheels and gears. String and the like can get caught in there. The easiest thing is to find the end of the string and try to unwind it in the direction reverse to what it caught in. I tried taking the whole Roomba apart one time, it was tough, so I don\'t recommend it unless you are very mechanically minded. FYI to everyone with a Roomba, I knew someone who expected theirs to pick up random dry cat and dog poop around the house. No vacuum can do this.
May 13, 2014 | iRobot Roomba 530 Robotic Vacuum
Iana mini rewind crank not spinning when advancing film
If the film is advancing you do not have a problem. It may be that the rewind button does not actually spin when you advance the film, because if it did and you have something caught on it when you are trying to do so you could really mess things up. Really, the rewind crank may only visibly spin in one direction.
Apr 17, 2014 | Lomography Diana Mini Camera & Flash...
Car will turn over but wont crank what could be wrong
If the motor turns over with the starter,
then the motor is said to be cranking
You have two situations only
You have a no crank or a no start
The rest is slang & nonsense everyone uses
Check for Spark
Check for Injector Pulse
Check for Fuel Pressure
Check the Battery
Check for Compression
Aug 29, 2013 | 1999 Mercury Sable
Check engine light doesn't come on at key up
i have a 98 esteem and the same thing happened to me..must have caught a rock or ice or something ...connection to crank position sensor was smashed...crank all day no code no start...new end ...new sensor...no more problem
Feb 19, 2013 | 2000 Suzuki Esteem
Turns over but wont crank...horrible screeching noise
To clarify, if the engine cranks or turns over but won't start, look for a stuck pulley on the engine. You may be hearing the belt slipping on that pulley. Take the belt off and try turning each pulley - also try starting the engine with the belt off.
Jun 24, 2012 | 1998 Buick LeSabre
Wep key for nokia 9500 communicator
wep key is the password you give when you own the connection, so that not everyone can connect to the net and do nefarious acts on the net and get you caught. so, for wep key, you must ask the owner/administrator of the connection/phone that has the WLAN.
Aug 30, 2009 | Nokia Cell Phones
Cobra 29 LTD CB Radio Logo
90 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
