Question about Lasko High Velocity Space-Saving Blower Fan HVB - 4924
How do I fix my fan from shaking so badly? - Lasko High Velocity Space-Saving Blower Fan HVB - 4924
  • 447 Answers
Did you just clean the fan? If while cleaning, you bent a fan blade, even a hair it will shake. Blades are perfectly balanced. Moving one just a hair, will cause the fan to shake. Trying to re=balance the blade(s) is futile, you can get it close, but it will take somr patience. If the fan has built up dust on the blade(s) will begin to shake if some blew off unevenly
Posted on Oct 08, 2010
2007. Check Engine light is off. When I Accelerate to 40 mph to 60mph, why does the engine start to shake?
Bad motor mount? Sure that the shake is not coming from an unbalanced wheel with a corresponding shaking in steering wheel?
Sep 05, 2015 | Ford Expedition Cars & Trucks
The fan and pulley are loose on my '99 dodge durango which is shaking my belt off into the fan, what would cause this and how can I fix it
You have a bad water pump. Have it fixed ASAP, it can suddenly get worse and send your fan through the radiator! Pretty easy to replace, should cost you around $200 total
Oct 04, 2012 | 1999 Dodge Durango
I jus brought and 1995 nissan altima. One of the radiator fans does work and I was wondeing if that could make the car shake? It only shakes midly but when i turn on the ac it shakes bad.
If the air conditioner is overcharged it can cause this to happen. Also that fan will need
to be replaced because it helps the condenser for the air conditioner to cool the air.
someone may have overcharged the a/c to try and compensate for it.
The lack of cooling will cause overheating of the engine without that fan replaced because it is also the radiator fan.
Hope this is useful.
Jul 23, 2011 | 1995 Nissan Altima
Evap fan noisey. this is the 2nd one I put in.
The fan can not be allowed to vibrate (firmly attached). The motor shaft must be straight. Every blade on the fan must be of the same weight and pitch. Every blade on the fan must be equidistant from each other.
In the event a fan begins to shake, the shaking will cause problems in the other. ie: A bad blade will quickly cause a bad motor. A bad motor will quickly cause a bad blade.
Did you replace both the motor and the blade simultaneously?
:o).
Jun 04, 2011 | Refrigerators
I have 2005 subaru forester. my engine shakes all the time especially when it is idle. when driving i dont feel the shake but when i stop it shakes. i have replaced my plugs but still shakes. also when i...
First step is to access the Engine Control Module (ECM) using diagnostic equipment connected to the data link connector of the car, in order to pull out all Diagnostic Trouble Codes (DTC) memored. Even if engine Malfunction Indicator Lamp (MIL) goes off after engine starting, it's possible to find out temporary DTC codes memored in the ECM. Then you will be full informed about bad components (e.g. bad heated oxygen sensor(s), cylinder(s) misfire(s), bad injector(s), bad ignition coil(s), ... etc). Therefore you will be able to repair & replace bad components and reset the ECM.
In the most cases when you smell something like rotten egg there are bad oxygen sensor(s).
Feb 01, 2011 | 2005 Subaru Forester
How to fix the heater?
is it full of antifreeze? is your engine fan working? does it get hot with no cooling down? even when you turn engine off? with engine off!!!open hood, grab fan see if it has back and forth play,if so,,,fans bad or water pumps bad. some camaro's have an electric fan,you may only have a blown fan fuse,or a bad fan.check fan fuse 1st then if it does'nt work after you run the motor nad the temperature guage goes up, check the electrical connections, if you have a mechanical fan,you should be able to shake it, front to back, if there is play or wobble in the fan,it's bad! replace the fan and that will repair your problem. if not that,and it turns out to be electrical, fuses 1st connections next, thermostat next,,hope this helps,merry christmas,and as always please repost your question if your not happy with the solution i've supplied.
Dec 26, 2010 | 1995 Chevrolet Camaro
Shaking mazda mpv 2003 in idle and loud radiator fan
Hello there, As far as the check engine light I would think since you mentioned it shacking that your light will probably be on for a misfire, Meaning most likely you have a spark plug wire going bad. I would stop by somewhere such as Autozone for a free check to tell you why your light is on just to double check.
Your fan issue could be several different things such as the fan motor going bad or the blades could be rubbing something, that one is a little tricky without hearing it.
Good Luck and I hope this does help you some. Allen
Oct 04, 2009 | 2003 Mazda MPV
2004 dodge durango overheating...fan shaking making loud noise
Fan shaking? not a good thing... you need to find out why...fan itself or water pump...change whichever is bad.
Jun 14, 2009 | 2004 Dodge Durango
Car has excessive all-over vibration - especially when fan motor engaged
Does the car stall on hard stops or turns? when it is in park does it shake less than when it is in gear.. If it shakes more while driving, it may be the tensioner, which is the bracket that is with the belt next to the alternator. sometime when driving it may squeak, then stop completly. If it just shakes, then it is your motor mounts. try tightning them and see if they are corroded. you may need to replace them
May 20, 2009 | 2002 Kia Rio
Lasko High Velocity Space-Saving Blower Fan HVB - 4924 Logo
309 people viewed this question
Top Lasko Dryers Experts
Shehu Pro
Shehu Pro
Jay Finke
Jay Finke
Are you a Lasko Dryer Expert? Answer questions, earn points and help others
