Question about RoadPro Road Pro 12 Volt Dc Portable Battery Jump Starter & Air Compressor 12V Dc Portable Battery Jump Starter & 260 Psi Air Compressor
Do not have owners manual! dura last jump starter bpdl
I have a 350 amp Black & Decker jump starter model JUS350B.Why can i not get power across the clamps with a test light
First: the Jump-Starter power switch must be in the "On" poistion, or no voltage will be delivered to the clamps to light your test light.
Second: from the Black & Decker JUS350B owners manual (http://servicenet.blackanddecker.com/documents/English/Instruction%20Manual/90553956,JUS350B.pdf?_ga=1.9223413.1518759147.1438019791)
This product has a sealed lead acid battery. For maximum battery life, we recommend the Jump-Starter be kept
fully charged at all times. Recharge before first use, immediately after each use, and once a month if not used.
Failure to do this may reduce the battery life dramatically. To check the battery charge status at any time, press
the Battery Charge Level Pushbutton.
When the battery is overly discharged and if the green LED is lit when the charger is plugged in, this indicates the
battery is at a high impedance stage.
In this event, recharge the unit and leave the unit on charge for a period of 24-48hrs before using the unit.
Also, the product reviews by consumers about this (made in China) product are abysmal:
http://www.blackanddecker.com/en-us/product-repository/products/2015/02/01/01/15/jus350b
Jul 27, 2015 | JUS350B 350 Amp Jump Starter
Where do I plug in the cord to start charging the jump starter (Black & amp; Sage ) 900 peak ,350
Google for an owner's manual. I can't find anything on this jump starter, but first they need to be charged, usually by plugging into a wall socket for 12-24 hours. Then plug into the cigarette lighter for 10 min or so to give the car battery a boost charge.
Dec 04, 2014 | Cars & Trucks
Where can I get a Manual for jump-starter 300
Battery Jump-Starter 300TM - All Power Supply
allpowersupply.com/Productlib/manual-PKC0AO.pdf
Translate this page Conserve este Manual del Propietario para referencia futura. P/N XXXXX, 3/09. 1 . TM. Battery Jump-Starter. 300TM. Model No.: PKC0AO. Owner's Manual.
Jul 24, 2014 | Peak Compact Battery Jump Starter 300 For...
Have a Husky yth180 mower. Battery was going bad and wouldn't start so I jumped it to finish mowing. Replaced battery and still won't turnover. Jumped starter and does turnover. All switches...
hi there dolson894
here is web site for owners manual
http://lawnandgarden.manualsonline.com/manuals/mfg/husqvarna/yth180.html
download owners yth180 manual it has a wiring diagram in it - may help
sounds like a starter solenoid problem, check for good grounding of the negative bat cable and grounding of the solenoid to the frame , check for 12 volt at the solenoid tab ( not the heavy contacts)
this wire solenoid tab wire comes from the S marked terminal from the main switch and power from the battery is taken from the HOT post of the starter solenoid up to the B terminal of the main switch, from there when contact made between B + L + S @ SWITCH voltage sent to solenoid for start
basic connections for switch in start mode is B + L + S
run / light B + L and Makes A + Y
run B + L off G+ M +L
check seat switch and brake switch - bypass with jump wire if need
across white to wjite wires on brake switch
see what hapens , the try a jump wire across the seat switch wires green to green and retry
if stil no good - replace solenoid as you mentioned with a jump cable straight on start motor turns over good
check out website
cheers hope it helps pauly46
dont forget the thumbs rating
Jun 07, 2011 | Husqvarna Garden
I have a duraheat 125,000 btu auto start (salamandar) with thermostat that was used once time last spring. it won't start and my husband tossed the box and yes..insructions in the fall. starting...it...
Here is a link to the Owners Manual for your Dura Heat Model DFA-125 forced air kerosene heater.
In addition to how to properly operate it and perform routine maintenance, it has a trouble shooting guide, which should be of great assistance.
You can download and print this manual for future reference.
http://www.worldmkting.com/documents/DFA4560125_EN_SP_FR.PDF
Hope this helped you. Please let me know. Thanks.
May 05, 2011 | Heating & Cooling
We lost the owners manual to our Vector 300amp jump starter. Is there one online that we can access?
http://www.baccusglobal.com/bd/manuals/NEW%20MANUALS%20FOR%20WEB/VEC012POB%20MANUAL.pdf If this one isn't the one you need you can go to their site to get the correct one
Oct 15, 2010 | JUMP START SYSTEM
I need a manual for a Everystart jump starter 400 amp
try this website and keep it as a favorite on you webpage if you have google
they have tens of thousands of free owners manual including for vehicles
http://www.manualnguide.com/
Mar 08, 2010 | Black & Decker Jump Start System 450 Amp...
RoadPro Road Pro 12 Volt Dc Portable Battery Jump Starter & Air Compressor 12V Dc Portable Battery Jump Starter & 260 Psi Air Compressor Logo
351 people viewed this question
Top RoadPro Air Tools & Compressors Experts
Lawrence Oravetz
ray gallant
 Bob Oppenheimer
Bob Oppenheimer
Level 1 Expert
Are you a RoadPro Air Tool and Compressor Expert? Answer questions, earn points and help others
