Question about Husqvarna Designer I
The machine is pulling the fabric into the bobbin case when embroidering. Just picked up brom repair center where they had it for 4 weeks to get the part to repair it from doing this. Still doing just like it was before the repairs where done
  • 201 Answers
Firstly, phone the repair shop and let them know their work was not done properly. Talk to them and see what help they can offer.
Secondly, is your project properly stabilised and secured in the hoop? Every project should be done with stabiliser to support the stitches. It needs to be hooped taut without being tight i.e. do not stretch the fabric out of shape, but the fabric should be held securely.
If the fabric is being pulled down into the bobbin during ordinary sewing, check to be sure the feed dogs are raised. Check also that you are using the proper needles with regard to the correct size and type for your project and that it is a new needle (a blunt needle will not go through the fabric cleanly).
Posted on Oct 15, 2010
Bobbin thread is coming to top when embroidering
When embroidering, the upper tension should be looser than when doing regular sewing. Test it first on a piece of scrap fabric that is the same fabric and stabilizer you will use on your project.
Mar 24, 2016 | Sewing Machines
How to adjust bobbin case for proper movement.
  1. Using a doubled piece of fabric similar to what you have in mind for your project, sew a seam on the diagonal-pulling the fabric on the diagonal to break the threads. (Ideal tension would either break neither thread or break both threads. So, a single breaking thread signals that the tension needs adjusting.)
  2. Snap out the faceplate to remove it & to gain access the bobbin area below the sewing needle.
  3. Remove the bobbin case & bobbin-lifting the hinged latch that you would to wind a new bobbin-leaving the bobbin in the case. (You need it in there to feel the tension as you adjust it.)
  4. Using a small screwdriver, very slightly turn the screw on the side of the bobbin case clockwise to increase tension; counterclockwise to decrease tension.
  5. Pull the bobbin thread while you hold the bobbin in its case & feel the thread's tension. Too tight of tension would prevent the thread from dispensing (& possibly break), but too loose of tension would allow the bobbin to fall out of its case.
  6. Return the bobbin case to the sewing machine & close the faceplate.
  7. Repeat this whole routine from Step One on the doubled fabric. Stitching should run along both the top & the bottom in the same way-locking in the center. A diagonal pull of the fabric should show which thread(s) break(s). Repeat Steps Two through Four to only adjust the screw aside the bobbin case in order to allow the threads to lock in the center of the fabric with both threads having the same break or no-break result.
Nov 29, 2014 | Singer 2732 Mechanical Sewing Machine
How to adjust bobbin when using embroidery machine, bobbin thread bunches up
Check your bobbin case if it looks like it has and feels like there are barbs on it they catch the thread time for a new bobbin case. I had mine less than 2 months and had to get one my machine sews and embroiders great now
Nov 25, 2013 | Singer Futura Xl-400 All-In-One Sewing And...
I have a new Brother se400. Recently, when I am embroidering, the machine is picking up the white bobbin thread and either stitching the entire design in the bobbin thread or putting colored thread in the...
Sound s like top tension too high, bobbin tension too loose, or a needle issue - dull or incorrect one for the fabric.
Change the needle, check tensions.
Have you stabilised the fabric?
Oct 15, 2013 | Brother Sewing Machines
Husqvarna viking, scandinavia 400: bobbin issues
try decreasing the tension to 3, if that doesn't help I would suggest to have it checked if it's still under warrenty
also is the fabric & needle & thread compatable?
Feb 27, 2012 | Sewing Machines
Machine jammed and pulled bobbin up out of it's case
since the machine jamed, I would suggest changing the needle incase it got bent or damaged
the reason for the birds nest under the fabric, the thread came off the thread take up lever, if it does it again you can try a piece of tape over it so the thread won't come off of the thread take up lever again
I use to have trouble with mine doing that.
Feb 09, 2012 | Sewing Machines
I have an husqvarna #1+, While doing normal sewing It stitches perfectly.however when I try to use the embroidry the machine refuses to pick up the bobbin thread.I've changed bobbins, bobbin...
Are you using a different bobbin when you try embroidry? The machine forms the stitches the same exact way when you either sew or embroider. It's just that the hoop moves the fabric. Maybe your bobbin thread in not flowing out of your bobbin case freely. Maybe the type of stabilizer your using is the problem. Maybe your not hooping your fabric tight enough.
Apr 28, 2011 | Husqvarna Sewing Machines
Fabric stuck in hole where bobbin is underneath
Turn off the machine and remove the needle.
Lift the presser foot and remove the inner hoop and then the rest of the hoop.
Move the fabric to one side and cut the threads with a seam ripper.
Open the needle plate.
Remove the bobbin and bobbin case.
Clean away any thread or lint in this area.
You should repeat the last three steps routinely as lint and thread snips can accumulate in these area and cause mis-stitching.
Replace the bobbin case, bobbin and needle plate.
Use a new needle.
Jun 29, 2009 | Simplicity SE3 Computerized Sewing Machine
Needle thread will not pick up bobbin thread
Needle may need to be changed. Be sure it is the correct needle for the machine.
Feb 18, 2009 | Singer 7462 Mechanical Sewing Machine
Sewing Machines Logo
53 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
