Question about Mission M73 Main / Stereo Speaker
I just got some mission 73 speakers how do you know if they are blown ..thanks gary
  • Mission Master
  • 5,158 Answers
Just connect a 1.5 volt battery to the plus and negative terminals. You should hear a pop in each driver.
Posted on Oct 07, 2010
Sony STRDH510 has a hiss coming from the speakers when listening to FM stations, however, there is no hissing sound when watching tv and listening to the sound through the same speakers. Is there an...
This has nothing to do with the speakers.
Page 38 of the manual describes tuner operation. FM hiss usually indicates a weak FM signal or it's not tuned precisely. If the "ST" indicator is blinking and you select Mono does it get any better?
A 75-ohm FM antenna oriented horizontally will help bring in a stronger signal (page 29 and 73).
Dec 08, 2010 | Sony Audio Players & Recorders
Mission 753 spares / tweeters hi can you help me please ? my tweeters from my mission 753 floorstanding speakers have blown.. been in contact with mission, and have been told that they no longer have...
Hi Ricky...saw your post re the 753 Mission tweeters. Your post goes back some months ago but I wondered if you got fixed up with replacement ones or a workaround ??
Regards
Wayne
urban494@hotmail.com
Jan 29, 2010 | Audio Players & Recorders
Blown fuse in mission 700as subwoofer
if you have access to a multimeter, you should test you impedance (ohms) Ω, check to make sure the speakers reads higher than the amplifier needs; this will result in less strain on your amp and diminishement of sound...For example: if you connect two 4Ω
speakers in series it results an 8Ω circuit (least strain). and if you'd take the same two speakers and connect them in parralelle it would result in a 2Ω circuit (most strain).
Jul 24, 2009 | Mission 700 Main / Stereo Speaker
Replacement base soeaker for mission 782
I have the same problem too, can anyone know where we can get a replacement of the woofer?
May 11, 2009 | Mission 782 Main / Stereo Speaker
Need to Replace the drivers on Mission 782 speakers.
Unless the company that made the speakers machined the allen screws themselfs, I'm sure any standard or metric allen set will work. Just becareful of the bracket because it may be glued to the speaker frame or there might be a gasket between the 2.
There will be a some wires coming from the crossover that will lead to the tweeters and to the woofer. They are terminated with female connectors that will slide on to the male end on the speakers. If the speakers that you are getting are from the same manufacture, then they should have the same fittings. If not, you may have to replace the females to match. It's a simple strip and crimp process.
Just make sure to mark the wires so you know which one is pos and neg. If you mix them it will throw your speakers out of phase and they won't sound right.
Hope this helps.
Mar 24, 2009 | Mission 782 Main / Stereo Speaker
Mission 752F blown driver
I would try ebay first. If not follow this link to see if they can help you out. Mission ltd is located in the uk. http://www.mission.co.uk/
Nov 28, 2008 | Mission MS752F Speaker
Mission 780 speaker...Is it blown
i had the same thing it is a problem with the flux that was used on the drive cone to connect it to the outer case had this with both speakers change the drive cone.
Jun 22, 2008 | Mission 780 Main / Stereo Speaker
Mission speakers...i think i've blown one of them...
I'm guessing you mean one of the bass drivers (as standmount or floorstanding speakers don't have subs as such). Place your hand lightly against the driver when playing some music at normal volume, there should be some vibration (this increases the louder you play). If there's no vibration, you're probably right.
Contact Mission, who can send you a new driver, contact a Mission dealer to see how much it'll cost to go through the dealer network. I'd recommend going down the latter route if you are unsure of what to do yourself.
Just noticed you posted this in March, in which case, I hope you got it fixed (or are enjoying your new pair instead!).
Mar 18, 2007 | Mission 702 Speaker
No Woof
If these are Mission 780s your talking about, you're not the only one. The woofers supplied with the speakers originally have a known design/manufacturing flaw causing them to go "open circuit" after a few years use. The good news is that IAG (who now own Mission) can supply you with a pair of replacements for about £45 plus postage. (You'd be forgiven for thinking they should supply the replacements for free given the cost of these speakers new and the fact this is a design/manufacturing fault). Replacing your woofers is easy. Take off the front baffle. Remove the four rubber plugs that the baffle attaches too, and take out the 4 screws you'll find behind them. Now ease off the plastic moulded front pannel. Remove the four screws holding the woofer in place. Pull the spade connectors from their tags on the back of the speaker. Put the new woofer in by following this proceedure in reverse.
Aug 03, 2006 | Mission 780 Main / Stereo Speaker
Mission M73 Main / Stereo Speaker Logo
266 people viewed this question
Top Mission Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Mission Audio Player and Recorder Expert? Answer questions, earn points and help others
