Question about Black & Decker Husky 750w Power Inverter
How to eliminate high pitch whine from Husky 750 W ???? Driving some people crazy ......??????.... WW3JC@YAHOO.COM Lee Robinson Jr
High pitched noise in Shark Navigator
Hello, this is Ava with Think Crucial.
To fix any noise issues that your Shark vacuum gives, a proper maintenance will do the trick. Most of the time, cleaning the filters, checking for blockages and clearing the passageways will eliminate the noise. Please refer to your Shark's User's Manual on how to do this.
You can purchase a wide variety of high-quality Shark replacement parts for your Shark vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=shark
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Jul 27, 2012 | Shark Vacuums
High pitch whine when tv started then it lowers in pitch
That could be either the color wheel or one of the fans. try listening to which area of the set its coming from.
Apr 04, 2012 | Televison & Video
My Honda CRV (1998) is making a high pitched whine sometimes when I'm driving. It seems to happen when the rpms are high before shifting (I own a standard transmittion CRV). It whines between 2.5 and 3...
Does the high-pitch whine exist when the engine is just running? Not moving (transmission is not in gear)? Running but with transmission in neutral (coasting down hill)?
Mar 26, 2011 | 2000 Honda CR-V
Same problem: a high pitch whine after extended driving
Sounds like a dry/failing bearing or power steering pump noise. You first need to try to track down where the noise is originating, and the most likely place is at the front of the engine.
I would start by listening with the hood up while parked with the engine running and the noise present, and seeing if it is coming from there. If so, the most likely cause is something connected to the belt - e.g. AC compressor clutch, tensioner, power steering pump, or generator. Can also be caused by the belt just slipping (warn out belt, tensioner not working properly).
Mar 31, 2017 | 2001 Chevrolet Venture
High pitch whine
sounds like your one of your hubs on the front axle are staying engaged when you turn off the 4wd. By reselecting the 4wd high and back to 2wd hi it is causing it to release. Get it looked at these can get expensive if damage is done.
Jun 18, 2009 | 2004 Chevrolet S-10
High pitched buzz/whine during wash cycle only, spin fine
1) Make sure valve is open all the way 2) some machines have a screen inside of the hose hook up which could be clogged. 3) last check to see if it is the hot or cold by switch your selector switch on your machine to hot then cold. If one of these positions eliminate the noise then the valve in the machine is bad.
May 16, 2009 | Maytag Atlantis MAV8000
My 2000 Monte Carlo ss is making a high pitched whine
it could be your power steering pump or the pump in the trany
Feb 03, 2009 | 2000 Chevrolet Monte Carlo
RECOR COLOR TV dead high pitch whining noise
you have a short in the horizontal ckt,look for diodes,horizontal output it might be damage or a bad cap, if not the fly-back transformer is gone.
good luck
caypianan@yahoo.com
Oct 20, 2008 | RCA F32650 32" TV
High pitched buzzing...
noisey yoke? Listen thru an empty paper towel roll cylinder to isolate---
Nov 17, 2006 | Sanyo DS27910 27" TV
Black & Decker Husky 750w Power Inverter Logo
47 people viewed this question
Top Black & Decker Electronics - Others Experts
PNiss
Are you a Black & Decker Electronics - Other Expert? Answer questions, earn points and help others
