Question about Samsung Refrigerators
Samsung side by side fridge freezer sr-s2028css. having seeked advice from refridgeration engineer was told compressor was not working, had a new compressor fitted by another engineer but still existing problem remained, that is a clicking sound when compressor trys to start. having called out original engineer diagnosed faulty compressor again. As this seems unlikely to me and engineer that fitted the compressor, i would like a secondary opinion. Many Thanks Barry
  • 254 Answers
Did they change the start relay as well as the compressor? On Samsung refers the start relays do not come with the compressor. If they didn't its possible that the start relay is clicking.
Posted on Oct 07, 2010
Samsung American fridge freezer SR-S2028CSS keeps beeping and randomly turning the fast freeze on and off.
quite possibly it needs some freon added to the system and only service people can do this
Jan 06, 2016 | Samsung Refrigerators
Samsung sr-l3426bs fridge not getting cold
you would need your fridge defrost sensor replace, check for ice build up within the vents of fridge section,
best to a tec to come and replace it for you,you would need the sensor to be reset on your fridge computer board
cheers
Nov 04, 2012 | Frigidaire FRS26R4A Side by Side...
For Samsung Refrigerator SR-L629EV my freezer
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Please check the link below for tips to remove the panels/parts:
http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Jul 19, 2011 | Samsung RF265AA Bottom Freezer French Door...
Hi. I own an older Samsung SR-S2028CSS fridge/freezer. The temperature control setting and ice mode selection buttons were ineffective and the fridge and freezer had increased in temperature, but...
blank display with segment flashing is a fault code samsung appliances use this method for displaying faults ...
samsung fridge freezer trouble shooting videos are available on youtube ..
have alook at this video and see if its the same segment that you have
Jan 20, 2011 | Samsung RS2534 Side by Side Refrigerator
Samsung SR S2028CSS Fridge Freezer - Fridge temperature problems
Try setting it to lower temperature. If that don't work the thermostat is bad.
Jun 28, 2009 | Refrigerators
I have a Samsung SR-S2028CSS side by side Fridge Freezer with an icemaker water dispenser. The freezer is run at -23 degrees and the fridge at 2 degrees. Recently the ice, having been made in the icemaker,...
Are you sure about these temps C or F? At 2 deg on either scale, food would freeze! And -23 is unreachable.
Water running down the door sounds like a seal leak, check by putting a dollar bill between the seal and the frame. It should NOT pull out easily. Or there may be an air leak in the ice/water dispenser. Look at these parts closely. Or the "stile heater", a heater in the door frame to prevent condensation, may be broke. This is expensive to fix.
Apr 08, 2008 | Refrigerators
Samsung Fridge Freezer (Freezer on top)Model SR-52NXA wont cool
Depends a bit on whether the compressor really is running, or if it's just humming because it's got power on the run coil, but not on the start coil.
Have a careful listen to the compressor. If it's making the trilling or gurgling sounds that go with a working compressor, then your problem is probably one of lost gas. Fixing this is not a do-it-yourself job.
If the compressor sounds like it's stalled, the problem may lie with the starter. Replacements are usually cheap enough for it to be worth fitting a new one just to see if it works.
A.
Feb 28, 2008 | Refrigerators
I am having problems with my samsung fridge model - SR-S2028CSS
does it freeze at all? you may have a problem with the coolent in the back of the fride which if so (depending on the cost of the fride) may be cheaper to replace, also the dial you use for selecting the freeze level could be faulty
Feb 19, 2008 | Refrigerators
Samsung SRS2028CVW fridge freezer
check out this samsung diy repair channel on youtube ... some great stuff on samsung
samsung fridge freezer problems
Nov 02, 2007 | Refrigerators
Refrigerators Logo
428 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
