18e converted to natural gas water not hot enough
    Problem Solver:
  • 8 Answers
Their is a heat setting knob on it,just turn it up.
Posted on Oct 08, 2010
Can I convert natural gas water heater to propane?
With knowledge of make and model, your manufacturer can supply a retailer who can provide you with proper kit...
info here...
http://www.propane101.com/lpgasapplianceconversions.htm
http://hometips.me/Mar/Convert-water-heater-to%20different-gas.pdf
Sears com
May 06, 2015 | Water Water Heaters
Can you convert the tankless water heater model # RL94in from natural gas to propane?
Contact Rinna
Some water heaters allows changeover by installing new chipboard or changing dip switches... some do not.
Propane burns much hotter with higher pressure than natural gas
Gene
Water Heater Timers Save Money
Feb 14, 2015 | Rinnai RL94i Tankless Water Heater
Can i convert a Rheem ECO 180DVP (LP gas unit) to a natural gas unit ?
Rheem water heaters should not be converted from propane to natural gas. The burners have been optimized for the rated gas and will not work as well after conversion. (Unlike ranges where the gas/air flow ratios can be adjusted when the burner orifices and regulator are swapped, the water heater doesn't have that option.)
I wish I had better news for you. I recommend you get a new water heater for the LNG service; it will be safer and more efficient.
Nov 10, 2014 | Rheem Tankless Hot Water Heater...
Natural gas converted grill will not get hot
Did you put a regulator on the grill when you converted it? Check with your local gas supplier. I St Louis, MO the pressure is low enough to not require the use of a regulator.
Apr 09, 2014 | Brinkmann ProSeries 810-6330-W Grill
Recently i got a hotwater heater installed in my home, i was told it was for natural gas and i believed the "experienced salesman". turns out they rigged a propane hotwater heater into my homes...
Those dirty crooks, Only kidding. They did the same thing to me a while back, except it was a natural gas heater with lp tank out in the yard, bought it from the gas co who services the tank, found out they ordered a dozen heaters, all of them natural gas. I said to the guy, do these need to be switched over or jetted or something? He says why, I said because it says natural gas only. It worked fine, just smudged black smoke out. He brought out another heater and swapped it out, seems you can't change the burner? Don't make sense. Anyway, I would take it back to the place you got it and say get up the coins, It cost $400 to get the plumber back to hook this thing up!! And we have no hot water. And my shotgun has a hair trigger. I would say it is dangerous enough to get his attention on the matter without going to court. Hope this helps.
Dec 21, 2010 | Water Heaters
I just had a noritz tankless hot water heater converted from LP gas to natural gas, and had the hot water heater moved outside my garage. Before the gas change over and the move, I could turn on my garage...
One thing that comes to mind right off is did they use proper size orifices when they converted? L.P. uses a much smaller size then natural gas because it runs at a much higher pressure. Just a thought but I had a water heater from the factory for a mobile home that had the nat. gas sticker on gas valve and I hooked it up in town to nat. gas supply. Unfortunately it had L.P. orifices and I was in a hurry to get to another job ,lit it turned burner on and left. Two hours later my customer called to say they didn't have enough hot water. Didn't take long to discover what the problem was and correct it. Thank god for good customers. Hope this helps you. Thanks
Nov 24, 2010 | Bosch Indoor Gas Tankless Water Heater...
Won't get hot enough or last as long as it used to
You could try to adjust the thermostat to a higher temperature. Let me know the results.
Good luck...
Aduz
Feb 22, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
Bosch water heater won't heat as hot or as long as it used to.
Is it protected by a water softener?
Have you cleaned the inlet screen and flow valve?
Your problem is likely in one of those areas. If not them then you may have to backflush the heat exchanger (if you don't have a softener). The manual tells you how to do that.
Mike
Trouble with waterheater
DO NOT USE THIS HEATER UNTIL IT HAS BEEN CHECKED OUT BY A PROFESSIONAL!
Most all gas appliances can use propane or natural gas, but they ship from the factory with orifices for one or the other.
Propane is rated at 11 iwg, natural gas at 7 iwg (where iwg=inches water gauge. 27 iwg=1 psig) (it takes a different regulator spring to handle this small difference in pressure.
A propane orifice will be smaller than a natural gas orifice.
The store that you bought the water heater should know what they sold you, and know if they have a kit to convert the regulator and orifices.
Jan 15, 2009 | Reddy Heater RLP100 Portable Forced Air...
Low flame
so you stove was converted from natural gas to LP using WB28K10043 KIT-CONVERSION L.P. ? is this correct?
Aug 23, 2007 | Hotpoint RGB745 Gas Kitchen Range
Heating & Cooling Logo
19 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
