Question about Dewalt Air Tools & Compressors
How much 30w oil does a D55155 hold - Dewalt Air Tools & Compressors
    Scholar:
  • 146 Answers
The compressor takes 4 ounces of oil to change the oil.
http://shoppingcart.msservicecompany.com/msservice_net/product_files/D55155/D55155_OM.pdf
Posted on Oct 07, 2010
I have a Briggs stratton 14 hp ohv I/c quiet model 287707. I had a guy change the oil & he put 10W30 synthetic oil in it. Now it smokes white smoke really bad. I think he put the wrong oil in
There is a very real difference between 30W and 10W30 oil. Whether it's synthetic or not probably doesn't matter. If you have the literature that came with the mower, it will tell you the recommended engine oil.
If they put in the wrong oil, they should make it right. You shouldn't have to pay twice for an oil change. It could be burning oil, since 10W30 is a lower viscosity than 30W. I would have them change it again, and see if it stops smoking.
Nov 24, 2014 | Garden
I want to know where the oil goes on this machine?
ON a d55155 compressor, you will find the dipstick on the left side as you are facing the control panel. Notice a small black knob on the end-bell of the pump. Pull out the dipstick and notice the oil level line just up from the tip of the stick. Over-filling will cause oil to leak. Use 30wt non-detergent oil or compressor oil. Good luck
Apr 02, 2013 | Dewalt D55155 Emglo Air Compressor
Dewalt d55155 compressor runs to 60 lbs then acts like not enough power and shuts down
Looks like it's an oiled style compressor. Is it getting pretty hot by the time it hits 60psi? Might be low on oil, or the oil has been contaminated with water from condensation. If that's the case then what is happening is the compressor is causing too much resistance for the motor to turn it because of the excess friction. This is could be what is causing it to shut down prematurely.
Nov 23, 2012 | Dewalt D55155 Emglo Air Compressor
What grade oil do I use to change out on my Chicago Pneumatic RPC-561VNS? The manual says a compressor grade non-deturgent oil should be used, but does no specify a grade.
Hi and welcome to FixYa, I am Kelly.
Compressor grade oils are basically SAE30 W oil. Read this:
Rol-Air OILCOMP30W34C Air Compressor Pump Oil - 30W Quart features ,
Specially engineered and tested to match the requirements of Rol-Air air
compressors , Provides superior rust and corrosion protection.
I.e SAE 30W oil / the same thing you would use in an older lawn mower engine or generator.
What they don't tell you is because they have re-labeled the 30W oil to OILCOMP30W they can charge you big time for SAE 30W oil. The only difference is the label.
Thanks for choosing FixYa,
Kelly
Sep 22, 2011 | Chicago Pneumatic 60Gallon TwoStage Air...
Dont know what type off oil to put in the bar and chain tank on the chainsaw
All Bar oils are SAE 30W non-detergent oil. Go down to the local auto parts supply and buy the cheapest SAE 30W you can find.... SAE 30W is SAE 30W regardless of what brand is on it and for bar oil it is not an issue.
Kelly
Aug 08, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
I want to change my EMGLO D55155 compressor oil. What type and how much oil should I use? Thank you!
The compressor tanks 4 ounces of oil.
You want to use a synthetic oil in this unit. We like to use Mobil 1 full synthetic 10w30 oil.
Here is a link top the owners manual:
Oct 07, 2010 | Dewalt 2 Hp 4 GAL Air Compressor
I have a mtd 6 hp push mower,what type of oil should i use for it?
Lawn mowers with engines smaller than 10 hp use a "splash" oil system for lubrication. Therefore you should use a standard SAE 30W non detergent oil. Per most user's manuals oil changes are every 25 hours of use. Every 4th oil change you can use a detergent 30W oil. Doing this will clean the inside of the crankcase and all components to the point the look brand new. It will not hurt the motor or the seals in the motor. However after this cleaning 25 hour period with the detergent oil, you should go back to SAE 30W oil again.
Kelly
Jul 20, 2010 | Mtd 22" Yard Machine Push Mower
Dewalt/Emglo D55155 compressor screeching and breaker blown
Sounds like it isn't getting oil on the bearings. Take it apart yourself,after you get a diagram of it and find a parts source.
Mar 22, 2010 | Black & Decker Dewalt #D55155 2HP 4GAL...
Best oil for my 2002 2.7 sonata
10w-30w or 5w-30w depending were you live, in a hot climate go with 10w-30w, any major brand, don't use any higher viscosity oil, modern engines are designed for lighter oils to improve fuel mileage and increase bearing life. I like Valvoline or Castrol, if you plan to own the car a long time then synthetic oil really prolongs engine life.
Aug 31, 2008 | 2001 Hyundai Sonata
Air Tools & Compressors Logo
206 people viewed this question
Top Dewalt Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Dewalt Air Tool and Compressor Expert? Answer questions, earn points and help others
