Question about Maytag Bravos MTW6600T Top Load Washer
Code F 51 comes up - Maytag Bravos MTW6600T Top Load Washer
  • 15,935 Answers
The F51 error code indicates that the control is not sensing proper motor movement through the signals from the RPS (rotor position sensor) circuit.
This can be caused by several different problems.
Make sure that you are not overloading the washer.
Overloading can cause this problem.
A toy or foreign object could be under the washer that is interfering with motor rotation.
With the washer empty, spin the basket inside the washer tub to see if it spins relatively easily.
If not, you could an item caught between the spin basket and the tub.
You could have a wire harness problem causing signals to not be transmitted properly between the RPS and the machine control board.
A failed RPS sensor or a failed control board could also cause this problem.
Thanks for using FixYa - a 4 THUMBS rating and positive testimonial is appreciated for answering your FREE question
Posted on Oct 07, 2010
How to repair if engine cannot race up when vehicle is running in Toyota Model KDN190R-CRPSYT vehicle?
If it is a Tercel or MR2, it is T and E1 terminals. Code 21 is main oxygen sensor signal fault. Code 51 is A/C signal on; DL contact off (in transmission shifter with diagnostic connector jumped). I have no idea what that 51 means.
May 28, 2015 | Toyota Cars & Trucks
Code 34 and 51
Code 34 is for the MAP sensor voltage being low which means the sensor is unplugged or faulty. Code 51 is for a problem with the memory chip inside the computer.
If the engine computer is failing it could set the code 34 even if nothing is wrong with the MAP sensor.
The computer and MAP sensor would need to be checked out.
Jul 15, 2013 | Chevrolet Cars & Trucks
SRS code 51... how do I fix it?
code 51 comes up as
seat belt restraint or air bag clock spring
if code 51 is cleared and comes back
the sensor or clock spring has to be replaced then code cleared
Apr 16, 2017 | Cars & Trucks
What is that mean code f 51 on my wash machine
1) motor RPS failure, this mean SENSOR faulty between the motor vs board.
2) clean the sensor from oxide, dirty, and tight the wires connector very well.
3) This is a difficult process for to access him. If you do not have enough experience, you must call a service tech.
God bless you
Jun 29, 2012 | Maytag Washing Machines
What does fault code 51 mean?
Error code 51 usually means a faulty diverter valve. Try and run a wash cycle, and observe the drain hose. If water comes out, the diverter valve should be fine, if no water comes out you should take your diverter valve out and check for debris, or continue to read through the following possibilities of why your washing machine is acting up, and the actions to take.
1. Diverter valve
Action - Check diverter valve continuity. If open circuit, replace diverter valve.
2. Motor Controller Board (drive circuitry blown).
Action - Replace Motor Controller Board
3. Diverter valve harness/connectors.
Action - Replace wiring harness
Jul 13, 2010 | Fisher and Paykel GWL11 Top Load Washer
Check engine light code 51
there is a code 51 first of all, try putting octane boost in the tank, there has been several completes all across the country of watered gas, i have a 96 and a 95 neon and within days of filling both up the code 51 came up. the boost helped 1 and the MAP sensor had to be replaced on the 96. hope this helps
Aug 09, 2009 | 2005 Dodge Neon
Panasonic PT-51HX41 51 inch
If the power led blinks its an error code such as 3 blinks means convergence failure which is the most common error for your model.Let me know the error code and I will assist you with what you need to do.
May 28, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Maytag Bravos MTW6600T Top Load Washer Logo
808 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
