My Trane heater won't come on. Only air but no heat, what can be the problem?
  • 59 Answers
There is a lot of things that can be wrong with the furnace. If you have access to the furnace that is where you need to start. You need to open the front door of the furnace and look at the control board to check if there is any error codes on the board. If your furnace dose not have a control board you will need a testing tool to check if any of the sensors are bad, and will need to check if the gas valve is still working properly. I need more info to help you more.
Posted on Oct 07, 2010
Brand New 2 weeks old 4 ton Trane compressor leaks a lot of water onto pad
If the unit is running in cold weather than there is ice building up on the coils located outside. This is normal in that the unit is running in heat pump mode heating inside and cooling outside, After the unit detects the ice build up it briefly reverses the cycle heating the outside coils melting(defrosting) the ice which you observe as water on the pad.
The video gives you an example of the defrost cycle!
2012 Trane XL15i Heat Pump Defrost Cycle Steam Show
Dec 21, 2015 | Heating & Cooling
My Trane XE1100 air conditioner won't start at all, worked fine one day and the next it wouldn't come on
check breakers in breaker panel,I need more info.is it blowing air inside
Jul 01, 2013 | Heating & Cooling
My trane XE80 will only blow cold air. The fan
It sounds like the problem is a tripped limit switch. Look in the burner compartment and on the blower assembly for a switch that looks like the one below. It will be about the same size round as a quarter. Press the red button on any of the switches you find, then re-try furnace.
Mar 23, 2010 | Heating & Cooling
Trane xe 1200, can i use the heat blower with out a working compressor, i need heat not air, thanks
you can switch the thermostat to "emergency heat" which will turn the outdoor section off and the thermostat will control the electric heat elements in the air handler if it has them.
Oct 19, 2009 | Omega Trane Furnace Draft Inducer Blower ...
TRANE 1984 Home A/C Where are How to Clean Coils inside House
the best thing to do it with airhandler shut down at breaker. 1st soften dirt and crud with 409 or different brand. 2nd take a wire brush and clean in up and down motion following the fins on coil.3rd rinse with spray bottle . this is the best you can do without coil removal.
Jul 02, 2009 | Heating & Cooling
Programmable T stat
your trane heat pump energizes the reversing valve with O - orange y - is to turn on the unit make sure you have your orange wire hooked up and the tstat programming set to heatpump otherwise your reversing valve might be bad
Jun 30, 2009 | Honeywell Electronic Programmable...
Say me certain reliable brand gas air conditioning for home
Goodman, Trane, and Amana are all pretty good manufacturers of heating and air products with some of the best warranties available.
Goodman: www.goodmanmfg.com
Trane: www.trane.com
Amana: www.amana-hac.com
Hope this helps.
May 27, 2009 | House Brand Heating&Air Conditioning...
Trane weathertron thermosatat
OK. Here is a Trane Weathertron BAYSTAT240 thermostat wiring picture. This heat pump w/ electric (emergency) heaters is running right now. Notice the G terminal has green wire, the R terminal has red wire, the white wire is jumpered from W to X2, etc. The black wire loop you see in the center hole is unconnected.
This unit is adjusted by leveling the base - loosen the screw to the left of "R" and the one to the right of "F". Twist the base clockwise to RAISE the indicator. This makes the mercury in the switch turn ON at a different temperature. Remember to tighten those 2 screws again.
You will have to experiment several times to make the unit read exactly right. If the tech installed the base exactly level, the unit would read right (it says here).
Mar 20, 2009 | Heating & Cooling
Home heating system question
Hello meglong what type of trane model is it? In the service package that was offered to you was one removing the exhaust fan for cleaning and a minor tune up every year? Because normaly the exhuast fans can be cleaned just by blowing out the fan with some air or even a vaccum cleaner.
Oct 29, 2008 | Heating & Cooling
Heating & Cooling Logo
198 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
