Question about Toshiba 37HL67 37 in. LCD HDTV
I want to remove the bast - Toshiba 37HL67 37 in. LCD HDTV
Is the Kenmore sewing machine 15343 able to do a baste stitch? If so, how?
A baste stitch is basically setting the machine to a straight stitch with the longest stitch length available. Loosen the top tension slightly if you want to remove the basting later.
May 12, 2017 | Kenmore Sewing Machines
How do you machine baste on a brother PE 830DL I am wanting to embroider on stretch material and I was told to float the stretch material and baste it to the tear away in the hoop thanks
A basting stitch is just a matter of setting the stitch length to very long. If you want to remove the basting stitch after your project is complete, you can also loosen the top tension so the bobbin thread will pull out very easily.
Wondering if a wash-away fabric spray adhesive will work just as well.
Apr 07, 2017 | Brother Sewing Machines
What are the correct settings for basteing on an elna excellence 730
Here's a manual for your machine:
ELNA eXcellence 730 Instruction Manual
If your machine does not have a "basting" stitch selection, you make your own basting stitch by:
* Setting the stitch length to the maximum
* Loosen the upper tension so the bobbin thread lies flat under the fabric
Then to gather or remove the basting stitch, it is easy to pull on the bobbin thread.
Mar 12, 2017 | Elna Sewing Machines
Help, I inherited a wonderful Bernina 930.The needle won't go up and down.Tried rethreading,feed dog is fine and oiled.I have a feeling it's something simple. Thanks
Try to: 1. Remove needle. 2. Remove the bobbin case. This is the most likely problem due to being inserted wrong. 3. Place a drop of oil on the race (where the bobbin case sets) 5. Check machine for free movement with the hand wheel. 6. Reinstall bobbin case. (Move the hook to the closest place where the feed dog is located) This will be tricky.
7. Once you have this done so the machine will move easily by your hand wheel try to slowly use the foot pedal. It should be ok. 8. Set the bobbin tension. The tension must be equal to the upper tension at four (give the upper tension a pull at four to get an idea of what to expect) 9. Put new bobbin and needle in and start sewing.
Also check for any garbage stuck in the bobbin area that would maybe cause problems.
Mar 07, 2017 | Bernina Sewing Machines
How do I set the machine to do a basting stich
if the machine can do a basting stitch the information should be in the sewing machine manual, if you don't have a manual, add a comment with the name and model number of the machine and someone should be able to help you find one.
or you can also try youtube for a video
May 11, 2016 | Sewing Machines
How can I do basting stitch for machine embroidery?
Some machines have a built-in basting stitch. If yours doesn't have it, the closest you can get is setting the stitch length to as long as possible. To make the basting stitch easy to remove, loosen the upper tension. Then to remove the thread, just grab the bobbin thread and pull.
Jan 28, 2016 | Sewing Machines
Where are the gathering and basting stitches located?
I put them just inside the 5/8 inch seam line so they will not show on the outside of finished garment. You don't have to remove them then, but you can if you want to if they are easy to remove. Of course if you have to re-fit you may need to pull some or all stitches out. I usually do the basting stitches by hand (depending on the item) and they are easy to pull out. If you use the machine for either, be sure to use a long stitch.
Mar 07, 2015 | Sewing Machines
What is a basting brush?
This is used for cooking, in particular for basting. Basting is when you add liquid to food to have it remain moist and add flavour . The brush is used to baste the liquid onto the food.
Jan 14, 2013 | Home
My brother ce8080prw machine will not stitch in reverse and is stuck in abasting stitch. how do I reset?
My machine was also not sewing in reverse and stuck in a basting stitch. It was a simple fix. Unscrew the plate and remove any pins stuck in there. All fixed
Nov 04, 2012 | Brother SE-270D Computerized Sewing...
Toshiba 37HL67 37 in. LCD HDTV Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
