Question about RaidMax 350W Power Supply (NEWITEM36787964) Power Supply
How can i repair a power suply - RaidMax 350W Power Supply (NEWITEM36787964) Power Supply
    Master:
  • 388 Answers
9 times outa ten there is a small 2.5 amp fuse inside.
you will have to desolder it and er-solder a new one in.
Posted on Oct 07, 2010
  • 4,234 Answers
Power supplies can fail for many reasons. Typically with the cost of replacements being so low, it is not worth the attempt to repair these. On rare occassions, a filter capacitor will fail on the output side and cause the entire unit to shutdown, but other than that, I would just invest in a new supply. The controller ICs used inside these units are not readily available in small quantities.
Dan
Haw to fix this tv power suply
Fixing power supply problems is a skilled work. It will be not so easy for a newbie; and will be dangerous to him/her too. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact any experienced service technician, or the nearest service center.
Mar 01, 2013 | Soyo Televison & Video
My hp L1506 Lcd monitor power suply is out can i repair it
Yes, if you have knowledge, circuit diagram etc.
I suggest you take it to an electronic repair shop, power supplies are dangerous if they are not fixed properly.
Aug 02, 2012 | HP 15" L1506 LCD Monitor Silver/Black
After a lightning stike, the TV will not turn on at all. No lights. Is it the power supply? Is it worth fixing?
is 30% chances that only the power suply is broke, and after a lightning ...is beter to go to a profesional repair shop and check it there.
if the power suply is external before u go to a serice u can try whit a power suply that got same V and A
best regards.
P.S.
i dont wana upsad u but prepare for worst
Sep 22, 2011 | Sony KP-57HW40 57" Rear Projection...
Power Suply not connecting
This is usually caused by a failed component in the power circuit within the camera and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I
Jan 28, 2011 | Panasonic HDC-DX1 DVD Camcorder
When i push the power buton the powerled go on and few secons off again i used the powercord suply and the battery suply. Could i be the power suply I.C wiht best regards Andre
Hi
Try this. Remove Battery. Hold power button for 10 to 20 seconds Insert Battery and switch system on. Let me know if this works
Oct 01, 2010 | HP Compaq nx6125 Notebook
My akai lcd 32.5" tv will not stay on and all it does is flash the blue screen with akai then turns right back off and i was thinking power suply might be bad. what could it be?
You could be right it sound like the power suply, has it got a AC adaptor power suply,bit like a laptop charger? goes from mains to a black box then from box to the TV?
does it stay on at all?
Oct 01, 2010 | Akai LCT3285TA 32 in. LCD Television
Doesnt turn on anymore.
Hi..there,
It's seems your backlight inverter is burnt out... need to be replaced with a new one or you can repaired yourself by testing all the capacitors to see which it has been burnt out or has a leaked. After that just replaced the bad caps... Good lucks, Have nice a day!
Aug 16, 2008 | Fuji FP-988D 19" Flat Panel LCD Monitor
My picture is really snowy
Capasitors on the power suply are failing or they have a cold solder joint. Take the back cover off and run a fan on the power suply to see if this problem stops. If it does the run smaller fans to track down the bad capasitor. There durt cheap to replace!
Jan 22, 2008 | Televison & Video
RaidMax 350W Power Supply (NEWITEM36787964) Power Supply Logo
131 people viewed this question
Top RaidMax Computers & Internet Experts
Mohammad Abumuailek
Mohammad Abumuailek
gaucherre
Are you a RaidMax Computer and Internet Expert? Answer questions, earn points and help others
