Question about Freezers
Dorema awning` SOS
We are confused folk!!!!
how do we put up the a dorema windsor awning.
well to be more helpful, we dont know which way the poles go.
our only instructions are in Dutch. :(
so any help [and we mean ANY] at all would be welcomed with open arms!
*pictures would be grateful =]
THANKYOU
from....
a teenager trying to help her lost mother!
SOS
p.s- sorry its under this category its just that, well, it is a large appliance AND when ever we camp its always cold so it would be a freezer!
xoxox
  • 828 Answers
Http://www.dorema.co.uk/awnings.html
try the above URL
Love and kisses to you also.
Posted on Jun 01, 2008
I have 2 big old chest freezers--Kenmore 122 and Coronado 193. The doors on both of them will not stay open whenever I put in/take out items. I assume it is in the hinges but how do I fix them?
These models have a spring built into the hinges. You can remove a hinge and take the spring out and try a local hardware store or online @ Graingers
Because replacement parts are hard to find for these I have seen folks us the hydraulic hatchback shocks to assist in opening the lids and holding them open. Other have just made a prop rod similar to a car hood support.
Sorry I couldn't give you a direct link to replacement parts, But I tried my best to find these springs.
Best of luck!
Oct 11, 2013 | Freezers
I have an True t72f bought in late 2005 it as a nema 14-20p plug on the data plate it shows 115/208/230 volts?? how do i know what to hook this unit up to ??
If the plug has 4 poles on it, that means it should be connected to two lines of power, one neutral, and one earth ground. The unit probably has a 208-230 volt compressor, with 115 volt control and heater system. Let me know if you need more info
Jan 26, 2011 | True 72 cu. ft. / 2039 liter Commercial...
No water flowing to ice maker
to see if icemaker is still good pour a 1/2 cup of water into tray and wait for a day. make sure shutoff arm or switch is on or down (arm down) if it makes ice then the icemaker is ok. if it dont then hold up.
if it makes ice then either the water pressure is too low (or no water) or the water valve is bad. (to check water valve you need a volt meter).
ok back to hold up part... the icemaker actuallys controls the water valve so you can have no water but that doesnt mean the icemaker is bad. so here are the three possiblities to your problem:
ice maker
water vavle
not enough/no water
before you buy anything let me know and we can go over this again
hope this was helpful (or confusing sorry)
Apr 02, 2010 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Have lost instruction booklet and do not know how to defrost.
Easiest solution is to get an ice chest and put all your frozen items in it and turn the unit off or unplug it and leave the door open and let it defrost itself. If you really want to speed it along use a hair dryer to speed up the process. Or put a circulating fan in front of it and put it on high facing the inside of the freezer.
Remember folks KISS, "Keep it simple stupid"
And No I'm not saying anyone is stupid.
Mar 23, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
My freezer doesn't seem to be freezing as well as it has in the past. somethings are frozen hard but ice cream isn't as solid as it should be
Try this... unplug...
take everything out and defrost the freezer
(go get a couple bags of ice and a big clean garbage can so you can keep the food cold)
you can defrost the freezer faster with a hair dryer
when you finish turn t'stat to high setting... put all food back in and dont overload and dont block any air vents (if they are located at top dont overlaod)
plugg in wait 24 hrs...
if you dont notice a difference let me know...
Mar 08, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Kenore Elite Freezer is hot on the sides
Sears has a complete model number system that is confusing I know. Sears made it that way. Not sure why but look around the cold food door while open and look near bottom on the frame just above the kick plate. The number looks like this, (model No. 253.64802400 for example) I will need that number to help you solve the sound alert coming from your refrigerator. Find that number and we can go from there, Thanks, Sea Breeze
Jun 16, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Need to know breaker and wire size to run from panel
Compressor 12/3 with 20 amp dual pole breaker. 220 VAC
Freezer 12/3 with 20 amp single pole breaker 120 VAC
May 24, 2009 | Nor-Lake Freezer Walk In Freezer 6ft x...
Freezer,Frost fan does not work,deos not destribute temp in coolr
Confused: You may well have a defrost issue but your description makes no sense.
https://www.repairclinic.com/RepairHelp/Refrigerator-Repair-Help
keep this link handy for future reference
Oct 08, 2017 | Freezers
Red light on not green ...has to be green to freeze up again
Try to unplug it for about 5 minutes, and then plug it back in
Apr 17, 2009 | Freezers
Hotpoint FAZ50 Frost Free Freezer
If this is a frost free unit as I received it posted you may have a problem in that it is not frost free. The cooling coil may be frozen over stopping air circulation. There would be a defrost timer located somewhere in back. Located the clutch head screw and turn it clockwise SLOWLY until you hear one audible click. That should put the system into the defrost mode. Wait about 30 minutes in which time the system should return to the cooling mode (usually 18-22 minutes). If it does not restart the compressor after that time turn the clutch head screw clockwise again and it should restart. If you had to turn the screw the second time it would indicate a bad defrost timer. In this case replace the timer.
Jun 14, 2008 | Hotpoint 4.87 cu. ft. / 138 liter Upright...
Freezers Logo
546 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
