Question about Gateway FPD1530 15" Flat Panel LCD Monitor
Trying ti fix a gate way fpd 1520 flat panal monitor i can see the image lightly but looks as if maby a bulb may be out any sugguestions on how to fix
  • Gateway Master
  • 5,381 Answers
LCD monitors use a fluorescent backlight system. A 15" probably needs just one. These are sandwiched on the perimeter of the monitor (usually under some tape that holds the lamp, reflector and other parts together. You need to order by length and width and get ones for your monitor size. Separate the panel from the bezel. Remove the tape, and separate the reflector (make a note of how things are put together) then you have to Dremel (or use another rotary tool) to remove the plastic to get the backlight out. (They are often molded into the frame.) Some backlights are sold without the wires. In that case, desolder the wires from the old backlight and solder them to the new one. Then put in the new backlight and reassemble everything. (http://www.lcdparts.net/howto/default.aspx) but for an overview: http://www.inventgeek.com/Projects/BacklightFix/overview.aspx Then push the new backlights into place, reconnect the wires and close up the sandwich of tape and other parts around the screen. Then replace it in the bezel.
Sometimes the inverter will fail but since you see the image that is likely not the case. However, you should consider testing the backlight with the inverter before installing it. (Unplug the old backlight (similar to a molex connector) (or desolder the wires from the old backlight and resolder them to the new one, depending on your backlight replacement), connect to the inverter and plug in. If it lights, you are good to go. Inverters can be tested with a high end multimeter (that can read frequency) or an oscilloscope. They cause an induced current which changes sign around the unit. Depending on the age of the inverter this can be 60 Hz or 50kHz. Hold the multimeter probes a fraction of an inch apart about an inch above the inverter. If a multimeter reads zero or near zero, the inverter is bad or the multimeter can't resolve the frequency. If you see a value or 1., then the inverter is good.)
I hope this helps.
Posted on Oct 07, 2010
Gateway fpd1530
If you have the appropriate cable to connect the output port of the computer to the input port of the Flat Panel TV every thing will be OK. For optimum performance you might have to install the drivers for the replacement flat panel.
Nov 01, 2013 | Gateway FPD 1520 15" Flat Panel LCD...
Power saver mode appears on the screen and then shuts off display, after limited use leaving it blank. How do i fix it. using Windows XP?
You can open control panel and select power options in which you can preset the time necessary for screensaver, hibernate and switch off in battery as well as in power mode.
Once you ahve made the settings save and quit.
now check if the fault clears.
Sep 24, 2010 | Gateway FPD 1520 15" Flat Panel LCD...
I have a FPD 1830 flat screen monitor not displaying picture
Send the monitor. It's a power supply problem. My 15.4" LCD has the problem, too, whenever I move the monitor down, it powers off, and the menu disappears as well, but I'm going to fix the screen.
Jul 08, 2009 | Gateway Computers & Internet
Cable for Gateway FPD 1520 15in. flat screen monitor
live in remote area of Nevada were can i find power cable for FPD1529 monitor???
Dec 01, 2008 | Gateway FPD 1520 15" Flat Panel LCD...
Gateway FPD 1830 LCD Monitor
User "noclew1"
Your problem is the back lights are not being powered. There is a signal going to your FPD because the power light remains on, but the back lights are what helps support an image from the Front Panel Display.
The only way to fix this is to open it up.
If its got 3 boards inside((logic-->video, Inverter, Power)) The problem is the Inverter. Replace it.
If its got 2 boards inside ((Logic-->video, Power)) The problem is the power supply. The inverter is embedded onto it.
Simply replace the part with a known good one, and you got a spanking new monitor.
As for User Guest
Your issue is nearly the same issue when it turns off on you. But the doubling effect is from the power being supplied by an old or weary power outlet to an FPD. That can be the cause. Try different locations.
Well I wish you both luck and I hope this solution can help you with the problem.
Thanks
Victorsinferno45
Aug 30, 2008 | Smart Modular PYXSCAPE SV1170 17" Flat...
Dark screen of Gateway FPD 1520
If you can see the screen display an image upon close scrutiny, it could be that the florescent back light is burned out.
Aug 03, 2008 | Gateway FPD 1520 15" Flat Panel LCD...
Screen going black, green LED staying on
Check to see if the image is Dimmed. Chances are the power supply on the FPD is either dead or not supplying power to the back lights.
Your problem is the power supply or the inverter on your board, you can replace it and it will be fixed.
Easy Fix REALLY EASY FIX
(inverter is what supplies power to your backlights. A lot of the times the reason a monitor goes black and the green power button is on, is because the backlights shut off. in most designs of the 1730 the inverter is embedded on the power supply. That is most often the case on this problem. Power supply/Inverter=Replace it and you will have a spanking new looking nice monitor working again. :)
Jun 19, 2008 | Gateway FPD 1730 17" Flat Panel LCD...
Gateway FPD1520 won't swith on
Try connecting to another computer or laptop to see if there is a signal issue.
Apr 23, 2008 | Gateway FPD 1520 15" Flat Panel LCD...
Gateway FPD1530 15" Flat Panel LCD Monitor Logo
293 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
