Question about LG LFC25760ST 25 Cu. Ft. Panorama French Door Refrigerator w/ Glide N' Serve Drawer & Internal LED T...
LFC 25760St Refrigerator displaying a code FF Er what is going on
  • 254 Answers
Er FF code is a freezer fan motor error. Check too see if there is a loose connection to the freezer fan. If not you may need a new fan motor.
Posted on Oct 07, 2010
  • 15,935 Answers
This is an error code that pertains to the evaporator motor but could also be the main board.
If the evaporator motor is running, the main board will probably need to be replaced.
It could be a wiring problem but it's not very likely.
If the motor is not running, some voltage checks will need to be made, at the motor and board, to determine which component has failed.
These checks require a meter and can be difficult to make, even for a technician.
Thanks for using FixYa - a 4 THUMBS rating and POSITIVE TESTIMONIAL is appreciated for answering your FREE question.
The code ER CO keeps coming on, on the display panel. The fridge and freezer still work but the code keeps coming up. Any info on that?
LG Bottom Freezer Refrigerator Error Codes Sears PartsDirect
Select
Use our model number finder
Choose your product type
Common model number plates
Close
LG Refrigerator Error Codes
These error code explanations can help you diagnose a problem with your LG bottom-freezer refrigerator. For repair how-to help, visit the PartsDirect repair help section, which includes repair help for washing machines, other major appliances, lawn and garden equipment, garage door openers, vacuum cleaners and more. You can also search for owner's manuals, get advice from an expert and find refrigerator replacement parts. Error Code
Er FS Error Code
Er rS Error Code
F dS Error Code
r dS Error Code
Er HS Error Code
Er IS Error Code
Er SS Error Code
Er rt Error Code
Er It Error Code
Er gF Error Code Error Code
r dH Error Code
Er IF Error Code
Er FF Error Code
Er CF Condition
Condenser fan motor is defective Check/Repair
Condenser fan motor, wiring or the control board Shop Parts
Condenser fan motor, Power control board, Wiring harness Error Code
Er CO Condition
Communication error Check/Repair
Communication error between main board and display board Shop Parts
Display control board, Power control board, Wiring harness
Jul 16, 2015 | LG LFX25974ST 24.7 cu. ft. French Door...
Kenmore model 795.71306 refrigerator is displaying an ER FF code on the frigerator temperature control
This error code Er FF indicates a problem with the main control board. When the power cord is disconnected for 30 seconds and then reconnected, it resets the board. Sometimes this procedure corrects the problem and sometimes it does, for only a short period of time. Usually in this case, the main board will need to be replaced.
Here is the board to order.
Dec 03, 2012 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Error on display er ff
Hi, here are the error codes and meanings for your Refrigerator
Error Code, All Error Codes will have an ER on the left side, followed by the error on the right:
Er IF - Icemaker Fan Error - This can be caused by frostaccumulation on or around the icemaker fan. Unplug the unit for 3-4hours to allow this to melt off. If error code persists, call CustomerService.
Er FF - Freezer Fan Error - This can be caused by frost accumulationon or around the freezer fan. Unplug the unit for 3-4 hours to allowthis to melt off. If error code persists, call Customer Service.
For remaining error codes, try unplugging the unit for a couple ofminutes to reset the unit. If the error code persists, call CustomerService
Er FS - Freezer Sensor Error
Er rS - Refrigerator Sensor Error
Er ds - Defrost Sensor Error
Er dH - Defrost Heater Error
Er CF - Cooling Motor Error
Er CO - Communications Error
Thank you.
Jun 06, 2012 | Refrigerators
Refrigerator displaying error "ER FF".
Error Code "Er FF" indicates a problem with the unit's freezer fan.
The freezer fan controls the temperature in the freezer. The source of this error is most likely ice buildup. As with the Er IF error, allowing the unit to thaw should resolve the issue.
Hope this helps.
Jun 10, 2011 | LG LRFC25750 Refrigerator French Door
My lg refrigerator model GM-F228JTKA is displaying the message ER FF
The common service code ER FF is
Abnormal freezing
BLDC motor
Motor defect, hooked of lead wire
to fan, contact of structures with
fan, short or open of lead
wire(there is no signal of BLDC
motor more than 115 seconds in
operation of fan motor)
It appears you have a fan problem.
Feb 09, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
ER FF code
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 12, 2009 | Kenmore 77719 Side by Side Bottom Freezer...
LG refrigerator lrsc26944tt error code ER FF
I'm no major appliance repairman. However, after reading several posts, I investigated the issue further since I received an ER FF on the front panel. I have a LFX25960SW refrigerator. I pulled the top and bottom baskets out, and was able to take the back panel out from inside. There was a solid block of ice built up around both fans and wires. I took a blow dryer and gradually melted the ice around the fans and wires. Then, as I was able, I pulled the remaining ice chunks off of the wires. I put the thing back together and it cleared the message. My wife says no more LG appliances for us. :)
DAS
Jan 25, 2009 | LG LRSC26944TT 36" 25.5 Cu. Ft....
I have an LG LRSC26923TT Refrigerator. The display shows "Er" in the freezer temp area and "FF" in the refrigerator temp area. Nothing happens when I press any of the buttons. However, the refrigerator...
ER FF is a freezer fan error. Basically the mainboard is not receiving a feedback signal from the freezer fan motor within 65 seconds. When this happens the error code will come up and then none of the buttons will work.
You can clear out the error code by unplugging and plugging the machine back in. The error code will come back if the problem persists. Check around the freezer fan motor fan blades to see if ice buildup is interfering with the operation. Clearing out this ice may fix the issue.
If the problem comes back, then the fan motor may be getting ready to go out or the unit may not be defrosting properly.
Hope this helps, please rate my solution.
Jan 09, 2009 | LG LRSC-26922 Side by Side Refrigerator
Kenmore ELITE error code ER FF
ER FF error is malfunctioning evaporater fan
hope this helps
Oct 18, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Error Code ER FF
FF is your freezer fan. You may need to defrost the unit.
Feb 28, 2017 | LG French Door Cabinet Depth Refrigerator...
LG LFC25760ST 25 Cu. Ft. Panorama French Door Refrigerator w/ Glide N' Serve Drawer & Internal LED T... Logo
252 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
