Question about Kodak EasyShare C330 Digital Camera
I bought a sandisk sdhc 4 gb card. When I go to format it, I get an filesys error e00100. What does that mean and how do I get my camera to work? Please help
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Kodak Master
  • 102,366 Answers
The C330 is designed to work with SD cards, not with SDHC cards. You need to use SD cards, 2GB and smaller.
Posted on Oct 07, 2010
Testimonial: "very helpful, thanks"
What does filesys error e00100 mean
Hello and Welcome to FixYa!
Error e00100 means that the card is corrupted or formatted for another digital camera.Format memory card and see the results,Try to format the memory card using a card reader with the PC, if error still exists then it means the memory card is electronically incompatible and won't work The Kodak C310 uses MMC and SD cards and may be you are using SDHC memory card, In this case change the memory card,
I hope problem will be solved, if error still exists then contact to Kodak Cameras service providers.
I hope this solution helps you
Your token of appreciation in the form of Four thumbs and testimonial will be esteemed.
THANK YOU and Keep Visiting FixYa
Apr 11, 2011 | Kodak EasyShare C310 Digital Camera
Inserted 4G memory card...says memory card is full...when I try to format the card, get filesys error e00100.....
The C330 uses MMC and SD cards. Your 4GB card is actually an SDHC card. While SDHC cards will fit into SD slots, they are electronically incompatible and won't work. You need to go with cards 2GB and smaller.
Jan 11, 2011 | Kodak EasyShare C330 Digital Camera
My KODAK C315 Digital Camera displays" Filesys error e00100 " every time i want to format my 2GB SD-Card, so i just can`t use the internal memory
Are you sure this is not an SDHC card? SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
Dec 03, 2010 | Cameras
I have not been able to format SanDisk SDHC 4GB Memory Card on my Kodak Easyshare Digital Camera C530. I am regularly getting the message "FILESYS ERROR e00100. The Memory card is authintic & NOT...
The C530 uses MMC and SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work. You need to use MMC or SD cards, 2GB and smaller.
Nov 01, 2010 | Kodak EasyShare C315 Digital Camera
I purchased a new memory card for my kodak easy share c530 camera and it will not format it. I keep getting an error message filesys error e00100.
Check the specifications of the camera. The card may be an SDHC which may not be compatible with the camera. SDHC is relatively new and will not work with most older cameras
Mar 27, 2010 | Cameras
Tried to format sd card screen reads filesys error e00100 kodak easyshare c330 card is a kingston 4 gb
E-mail your question to this address: http://www.kodak.com/global/en/service/contactKodak/email/consumerDigital_contact.jhtml?pq-path=13452
Jan 09, 2010 | Kodak EasyShare C330 Digital Camera
Kodak camera 2 gb memory card will not work
Format it in a PC using a card reader. Then use in the camera.
Aug 10, 2009 | Cameras
Filesys error e00100 when attempting to format a Scandisk 2.0 gb memory card.
Hi ,Welcome
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • May 02, 2009 | Kodak EasyShare CD33 Digital Camera
    It says the memory card needs formatting but when i go to format it this error occurs, FILESYS ERROR e00100
    The Kodak Z612 only accepts standard SD cards up to 2GB. As you rightly point ot the physical charactreristics are identical, its the internal format of the card that defines SDHC.
    Standard SD cards use FAT - which has a 2GB limit.
    SDHC cards use FAT32 - which has a limit of 32GB.
    Stick with 2GB or smaller standard SD cards.
    Aug 14, 2008 | Kodak EasyShare Z612 Digital Camera
    Kodak EasyShare C330 Digital Camera Logo
    412 people viewed this question
    Top Kodak Cameras Experts
    Tony
    Are you a Kodak Camera Expert? Answer questions, earn points and help others
