Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
MODEL WTW600SW2 I NEED A OUTER TUB SEAL FSP ATP-1-4 (6545956)
  • 1122 Answers
SOURCE: outer tub seal
you must first remove the agitater,then remove the inner tube,you'll need a spaner wrench,you now can see the tub seal,how you need to remove the 3 bolts around the bottom of the outer tub,now you can remove the outer tub and replace the tub seal,or use some 3m gasket seal,up to you,you can get a new tub seal on line for $10,let me know how you do-mike
Posted on Nov 04, 2008
SOURCE: Outer tub bearings are gone
My bearings went out too and I found this site http://www.neptunebearing.com/ Ordered the bearings and the Tony Tool. My son and I replaced the bearings in about 2 hours!
Posted on Apr 03, 2009
  • 311 Answers
SOURCE: Maytag Dependable LAT8824AAE. Main tub seal leaks
The part number for the mounting stem and seal kit is 6-2095720 it cost about 85 bucks retail. You will also need to buy a special maytag spanner wrench to remove the inner tub. Its NOT an easy job the inner and outer tubs and hoses all need to be removed. The seal kit comes with no instructions. If you had a service company do the job it would be probably around 250 maybe more. We charge 104.95 labor for the job. Good luck _MJ_
Posted on Mar 04, 2010
  • 121 Answers
SOURCE: Have Maytag washer model # lat9416aae. Continuous
THere is a video on this page that shows how this is done http://www.appliance-repair-it.com/Maytag-tub-seal.html
Posted on Sep 03, 2010
kel1guy2002
  • 3740 Answers
SOURCE: Kenmore Oasis washer--model#11027082604 is leaking
As far as I can remember there is supposed to be a lip seal for this motor. I must apologize because I am not sure this is 100 % correct... but this number 425009P is on one of my old invoices. I am NOT sure that seal is for an Oasis. I am sure it is for a smart drive machine.
I did a net search for that number and it only shows up on the Fisher and Paykel machines that are similar to the Oasis. See for your self and feel free ask / seek another expert.
Kelly
Posted on Jun 02, 2011
WTW600sw2 change keeps going into drain pump. Is there a way to adjust the drum seal to prevent this?
There is no adjustment. There may b e coins still stuck in your filter that might make their way to the pump. To clear it out, you have to remove the basket from the tub. The filter will be in the back center of the tub. Remove the 2 screws and clean it out.
Dec 31, 2012 | Maytag Bravos MTW6600T Top Load Washer
I'm trying to find a part for my whirlpool washer mod#wtw6200sw3. It is the outer tub shaft seal. fsp 6545958
Hello Robby, welcome to FixYa.
I'm pretty sure I know what you're referring to and unfortunately it isn't good. Many times this is associated with the basket drive assembly, in fact I don't think you'll find that part as a stand alone component.
Where did you get that number, on the actual part perhaps ? Many times the manufacturer will stamp parts with identification numbers as they are built, but they do not become available for individual part sales, only assembly line.
To obtain that seal will require the purchase of a complete a tub assembly unfortunately...unless you can match the seal specs. to an aftermarket seal manufacturer (though the seal has likely worn for reason's of shaft or bearing wear/failure).
Depending on the age of your washer you should inquire about warranty. (you will likely require a proof of purchase and your owners manual)
**I'd suggest contacting your local Whirlpool service/warranty provider as these have a two - five year (parts only...check your owners manual for confirmation) warranty on the tub and bearing components**
I'll watch for your reply and certainly help you in any manner I can. Thank you for visiting FixYa today and good luck.
Regards,
Macmarkus :)
Sep 06, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Model #AWM392W when water is filling tub, water is coming out from around the bottom
the outer tub seal is bad,you need to remove the inner tub then outer tub to replace this seal
Aug 07, 2011 | Speed Queen AWS52NW Top Load Washer
Hi, My Frigidaire Clothes Washer, Model FES445RF, which has developed a leak around the shaft seal where it enters the outer tub. Is it possible to repair and can I get to it by removing the outer tub from...
Hi, what you are experiencing is problem with the Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
You can get the parts by contacting appliance help on 1-800-470-7119
Oct 06, 2010 | Kitchen Ranges
Its leaking water while the washer is washing
Hi
If your washer leaks every time you run it, then check these:
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make.
Please rate the solution if you find it useful and helpful.
Thanks
Rylee
Oct 16, 2009 | Whirlpool Washing Machines
I have a frigidaire affiniy front load washer. After I washed a lightweight blanket i heard a laoud noise from the machine and water was below the drum not behind from the hose. The next time I used it...
check these:
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further detail
Sep 18, 2009 | Washing Machines
My estate washer is leaking water when we turn it on. It is not holding any water in the tank. Any suggestions what I should look for and fix myself. Thank you
If the washer leaks when you turn on check these:
* Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
* Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
* Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
* Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Sep 02, 2009 | Whirlpool Washing Machines
Small amt of water drips into tub after washer stops fisher payke
If the washer leaks all the time, check these:
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
  • thanks and please do not forget to accept the solution
Apr 03, 2009 | Fisher Washing Machines
Outer tub seal
Nov 03, 2008 | Kenmore 24032\24036 Top Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
527 people viewed this question
Dan Webster
Dan Webster
Sal De
