Question about Dayton Gas Furnace Heater
Installed new gas valve. Wired according to instructions with valve. Shows 3 wires coming from igniter to gas valve. 2 tabs on valve above pilot. Burners won't come on.
  • 59 Answers
I need more info to help you out. You need to check if there is anything else wrong with the furnace. But a for the gas valve goes you nee to check if your geting 24 volts to the gas valve. The pilot sensor might be bad. What kind of gas valve do you have. are the three wires coming back to gas valve Yellow, White, and Green. If they are most likly its the flame sensor not the gas valve.
Posted on Oct 07, 2010
  • jrdanielson Oct 08, 2010
    answer didn't help. no pilot light or burners either
My Honeywell smartvalve stop opening the gas valve, inducer motor started, glow and pilot happen, just no fire...I replaced said smartvalve and upon installation, the inducer motor wouldnt run, no glo
Double check the wiring connections, maybe you have the pilot valve and the main valve wiring reversed. I had a call one time where the homeowner installed the gas valve backwards, so no flow and of course and the wiring on the three terminals was reversed.
The inducer should start whether or not the gas valve is wired wrong, unless it is wired in parallel with the pilot valve.
Jan 21, 2015 | Honeywell Heating & Cooling
Having problems with 35,000BTU Williams Wall Heater. Have changed thermostats twice using the 986-1R. Heater not coming on when dips down to lower temp and not shutting off when on just keeps runnin
Wall furnaces operate on millivolts of electricity, about 750 mv which is only 3/4 of 1 volt, 1000 mv being 1 volt.
The electricity is created by a pilot generator that is in your pilot assembly, the pilot generator has a hot end in the pilot flame and a cold end that is not in the flame, this temperature differential is how the pilot generator creates the 750 mv or 3/4 volt.
As this is not much voltage, it is very easily disrupted by a patina on the connections, wires and terminals, I would clean them all shiny new, this often will fix it, if not try jumping the 2 thermostat terminals that the thermostat wires are connected to, this bypasses the thermostat and wiring so if it runs you know why it was not before. The pilot generator likely needs to be replaced, you can test the gas valve with a AAA battery with a wire taped on each end, then wire the battery to the gas valves terminals that the pilot generators wired to, this simulates a good pilot generator.
If the system operates via battery do not use it this way it is not safe as no pilot safety exists in case the flame blows out! gas will still flow due to the battery powering the heaters valve, it is for testing only, if it works by battery then the pilot generators bad.
Jan 07, 2015 | Williams Wall Heaters: 35,000 Btu/hr...
I have an older Carrier furnace type 58ss. The main burner will not ignite. Operating look ~ thermostat set @ 78 deg, switch furnace on, inducer fan running, pilot light clicks and ignites, inducer still...
power to gas valve ok .. Replace gas valve after checking gas valve coil for continuity/resistance... with valve removed ...and power to valve ... try blowing thru valve from supply side ... stuck valve.... replace...
Nov 01, 2013 | Heating & Cooling
Installed new wall heater and thermostat and pilot is on but heater will not come on?
What about thermostat wire? What ya got 2 wires right? Touch them together she supposed to ignite the flames then after a few minutes the fan kicks in on fan models. You got the knob on the gas valve turned to the "ON" position?
Nov 07, 2011 | Williams (5009622) Ceramic Gas Wall...
How to change bad thermocouple on reliance gas hot waterheater reliance 606
it is important to turn off
the gas supply to the water heater at the manual gas shut-off
valve. This valve is typically located beside the water heater.
Note the position of the shut-off valve in the open/on position
then proceed to turn it off.
2. On the lower front of the water heater locate the combination
gas control valve/thermostat. Depress and hold
the lock tab located under the gas control knob on the right.
Rotate the gas control knob on the combination gas control
valve/thermostat clockwise until "OFF" aligns with the mark on
the front of the gas valve. Once the gas supply has been shutoff,
remove outer door. 3. Using a 1/4" nut driver or socket loosen the two screws securing
the manifold door assembly until they are free. Do not
totally remove the screws and plastic retainer washers from
the manifold door. The screws and retainer washers will be
needed to reattach the manifold door. 4. In this step, the thermocouple, manifold tube, pilot tube and
igniter wire will be disconnected from the combination gas
control valve/thermostat. Using a 7/16" wrench
disconnect the thermocouple (left-hand thread) and pilot tube
(right-hand thread). Using a 3/4" wrench disconnect the manifold
tube (right-hand thread). Carefully pull the igniter wire from
the igniter button.
5. Grasp the manifold tube and push down slightly to free the
manifold tube, pilot tube, and thermocouple from the combination
gas control valve/thermostat. when installation is complete and gas is back on, You should be able to relight the pilot and the functionality of your gas hot water heater should be restored.
Nov 27, 2010 | Reliance Natural Gas Water Heater Control
I installed a do it yourself direct vent wall heater. All is complete. Pilot is on now. Problem, when I turn the williams theromstat from off position to even slightly on, i hear a click sound and it...
Hi, yes for a heat only you will have 2 wires red and white. On the knob, you should have an off, pilot, and on position. It should be in the pilot when it is lite. Once the pilot is on you say you slowly turn it to on and you hear a click and off it goes? Turn the pilot screw back down some, about 1/2 an inch. Did you wire the control wires to the gas valve itself? This sounds like what is happening, the wires from the stat and if it has a pilot generator with a red and white wire that connect to the screws are in the wrong place and shuts it down as soon as you turn the valve to on. It is doing this for safety as it is not wired right. It should have come with a wiring diagram to show how it is wired. For all I know it may have come prewired, is this true? Did you do any wiring at all? Can you describe to me how many wires are there and the markings on the gas valve such as th or tr and so on? It sounds as though the 2 stat wires are on the wrong terminals and will shut down everything. Double check this and it should have a diagram showing you how it should be. Let me know. This should be very easy for us to get going.
Sincerely,
Shastalaker7
PS, does it have a ground wire that's not connected?
Feb 25, 2010 | Williams 3003622 Ceramic Wall Mounted...
Dayton Heater M/N 3E227E
Hard to believe they sell a retrofit kit for a Gas furnace to a Customer....This is ahrd to advise you on with out seeing the schematic and if it is indeed intended for that furnace....the Spark mounting location is CRITICAL for safety so make sure that is correct above all.....OK The wire coming off the transformer and tied to the red wire going to the heat excghanger would most likely be a High Limit switch...cuts the gas off if the blower doesnt work etc or you would have a fire...so this switch must be in series with the transformer to cut power when the switch opens....the wire MV/PV coming from the "Electronic control box" needs to go to the New Gas Valve you should have which will have a termional marked MV/PV (Main valve/Pilot/valve) as your old one was for a standing pilot application and when you have electronic ignition you req a Gas valve for Intermittent pilot .....you should also have 2 more terminals on the valve MV and PV which will have seperate lines from the ignition control as well....basicvally there will be another wire coming from MV/PV going back to the transformer...make sure all wiring is correct and I would strongly advise you have a technician check your work before you attempt to use it....if wired incorrectly you could have a serious delayed ignition as its possible to power the main burner instead of the pilot if you wire it up wrong below is a typical spark wiring diagram....may not apply totally to your system but it will give you the general idea79f9627.gif
Oct 31, 2009 | Heating & Cooling
I have Dayton space heater 3E 229, pilot wont stay on,I have install new gas operating valve and checked transformer ( 30V) . Pilot lights up but wont stay on even if I hold button down for 2-3 min. please...
The thermocouple is likely defective...(Copper wire heated by the pilot) or the pilot itself is too small or dirty....the pilot must be BLUE , not yellow like a candle...and it must envelop the top portion of the thermocouple....you could also have an auxiliary limit or ECO wired in series with the thermocouple circuit that could be open.....also make sure the thermocouple is inserted all the way and is in the pilot flame as mentioned above
Oct 25, 2009 | Dayton Gas Furnace Heater
Coleman Presidential II Heater won't come on
You should have 3 wires going to the gas valve - MV(mainvalve), PV(pilot valve) and MV/PV (or Common). Make sure all of these are properly wired and tight.
You also may have a dirty FLAME SENSOR on your pilot/ignitor assembly. You may need to remove the pilot tube and the pilot assembly to clean the sensor with sandpaper.
Be careful not to damage any parts while cleaning them. Be careful not to crossthread the gas line when re-installing it.
Jan 03, 2009 | Coleman Propane Forced Air Heater...
Dayton Gas Furnace Heater Logo
339 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
