Question about Air Tools & Compressors
I own a Fini air compressor Tiger MK 245 made in Italy. I would like to service the machine and fix an air leak. I have looked at the air compressor brands and I not able to locate it. Do you have a manual for this machine?
  • Edward Roy Iwanowski Oct 08, 2010
    I have looked on the Fini website and cannot locate any manuals. Can you locate a manual on the Fini site or make other suggestion to assist me with my problem?
  • 10,865 Answers
Hello. Here is all of the contact information for the Fini Office in the USA
ASSOCIATE ENGINEERING CORPORATION
606 SOUTH LAKE STR. PO BOX 346
53034 HUSTISFORD WI
U.S.A.
Phone : 001 9203493281 Fax : 001 9203498861 E-mail cherylb@rolair.com Web www.rolair.com
Contact Cheryl and ask her to provide the manual you are seeking. Joe
Posted on Oct 08, 2010
  • 15,935 Answers
Head over to the manufacture's website.
Typically - they have a SUPPORT section that you enter your full model number in, and you can download the manual for free.
Thanks!!
Posted on Oct 07, 2010
Triumph Tiger 885 rough idle
Hi, Margret and the usual suspects are:
1. Idle speed improperly adjusted.
2. Air fuel mixture screws not properly adjusted.
3. Inlet system air leak.
4. Leaking accelerator pump.
5. Loose low-speed jet.
6. Plugged low-speed jet.
7. Contaminated or plugged low-speed circuit.
8. Enrichner valve/choke not seated or leaking.
9. Multi carburetors out of sync and need to be balanced.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Tiger rough idle
1999 Tiger 885i Fix build Help
Triumph Tiger Service Manual
http://www.worldoftriumph.com/triumph-motorcycle-parts.html Triumph Tiger Handbook
Jul 05, 2017 | Triumph Tiger Motorcycles
1996 Triumph Tiger leaks fuel heavily when running
Hi, Phillip and the usual suspects are:
1. Damaged or restricted fuel tank venting system.
2. Loose float bowl screws.
3. Damaged float bowl o-ring.
4. improper fuel level in the float bowl.
5. Worn or dirty inlet valve or seat.
6. Damaged or leaking float assembly.
7. Particle contamination in inlet fitting cavity.
8. Damaged petcock diaphragm allowing fuel to flow through the vacuum line into the combustion chamber.
9. Contaminated fuel tank.
Gas leaking 97 Adventurer Mikuni carbs
Carbs leaking Here is how to fix it
http://www.triumphestore.com/
Jun 21, 2017 | 1996 Triumph Tiger
My 4.3gal.air compressor runs then trips the breaker.it's a fini 2005 lot90.
From your picture it looks like the compressor has had some hard use and subject to moisture.
  1. Moisture can cause the compressor end to have more friction and overload the motor, especially if it doesn't have a good air filter on the inlet.
  2. Moisture can weaken the motor windings and cause internal short circuits that can cause the breaker to trip.
  3. Moisture can attack the motor and compressor bearings causing the motor to overload.
  4. The pressure switch may malfunction and not turn off at the proper pressure. Too much pressure will overload the motor.
  5. The tank check valve could be clogged
  6. Too long of an extension cord or low voltage can cause this
Feb 08, 2015 | Heating & Cooling
I have a divilbiss pro 4000 model RA65K80V1D looking for the compresser head torqe thanks
I have a Rolair two stage air compressor of similar design (5~7 hp range) has metal headvalve plate, aluminum head and cast body. The head bolts are torqued to 243 fp. May use as ballpark guide. Your compressor may have been made by Fini. Good luck.
Aug 10, 2011 | Dewalt Air Tools & Compressors
Compressor is leaking oil from bottom looks like where case is put together
DEPENDING HOW OLD IS YOUR MACHINE IT WILL START COMMON LEAKS DUE TO HARD WEAR, BUT YOU CAN FIX IT IF YOU DO A MOTOR OVERHAUL BEFORE MORE WEAR AND MORE MONEY TO SPEND TO REPAIR.
Nov 09, 2010 | Hitachi EC12 Portable Electric 2hp Air...
My amana abd2533dew purchased in 2005 has stopped cooling.Woke up with the freezer blowing warm air,all food thawed. refrigerator temp falling fast.Service can't come for 3 days? I have an extended...
If the freezer compartment is blowing warm air, then you either have a problem with the compressor (or a freon leak) or a problem with the fan located next to the compressor (at the back of the machine).
Attached to the compressor is an overload protector, which is most likely what broke, but if you are covered by a service contract your best bet is to wait it out and let them fix it. One thing that might have caused the overload to break is too much dust on the condenser (the radiator looking thing underneath the machine, accessible from the front).
Jan 01, 2010 | Amana ABD2533DEW / ABD2533DEB / ABD2533DEQ...
Clicking sound from rear of Jenn Air Premier Line Fridge
Simple relay replacement, if you do it yourself you are looking at about 65 dollars max, you call a repair company you are looking at 245 or more
Feb 09, 2009 | Jenn-Air Premier Line Energy Star Cabinet...
Air Tools & Compressors Logo
1,075 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
