Question about Bosch Nexxt WTMC 3300 Electric Dryer
All lights are on but pressing the start button nothing happens, a repair guy came before and said that the control panel would need to be replaced but can I do this myself
  • Bosch Master
  • 2,605 Answers
Welcome to FixYa.
In respone to your post..."all lights are on but pressing the start button nothing happens, a repair guy came before and said that the control panel would need to be replaced but can I do this myself " I`ll begin with saying it is most likely a component you could change by yourself...with a little guidance you can find here of course.
I also would like to question the issue of the unit needing the control board though. I say this for two reasons, One...in my experience as an authorized Bosch service tech. it is very rare...secondly, it is all too easy to point to the electronic controls in modern appliances as the problem.
I don`t disagree the controls do fail, just that it is typically only a symptom to another problem and replacing the control may only fix it temporarily or not at all.
Here`s what I`d suggest you do before dishing out nearly $200 - $350USD for a control you may or may not require.
**Unplug the dryer from the wall or turn off the breaker before servicing the dryer...safety first of course**
If you`re mechanically inclined at all it won`t be too bad...if you`re reluctant or have doubts, you can email me at macmarkus@live.ca and I can send you brief "how to" windows media videos to service the dryer.
You`ll need to remove the top and the back panel of the dryer to check the components which may cause these symptoms, the hi-limit cut out and the emergency shut off switch.
The emergency shut off is this...( it`s designed to shut the dryer off in the event of overloading or a broken belt )
make sure the black button is pushed all the way to your right...from the back.
As for the hi-limit safety/cut out...
Try resetting the red button in the center of the hi-limit/safety and try the dryer.
Both of these are shown here but require removing the rear panel as I alluded to previous.
There is also a possibility of a wire broken or loose at the second hi -limit thermostat at the lint screen housing...it also requires the back to be removed as well as the drum assembly.
Try the first two suggestions before we move forward in regards to the alternate issues of wires etc.
Let me know how you make out or what you find. Thank you for choosing FixYa and good luck.
Regards,
Macmarkus :)
Posted on Oct 08, 2010
Pro action dishwasher wqp129250g lights flash on but will not start
Sounds like the main control panel has issues. Maybe a replacement might cure your problem but if not sure, call a repair shop.
Feb 08, 2017 | Dishwashers
Model FEQ1442ES0. I press the start button and all I hear is a click, nothing happens. What's wrong?
I appreciate your inquiry, Cody!
I see that your Frigidaire dryer is not operating after you hit the start button and it clicks. It is possible that your control panel or wiring harness could be causing this issue with your dryer. You may need to perform a reset on your dryer and you can do that by disconnecting power from your dryer for at least ten minutes. If this does not correct your issue I would seek assistance from a professional technician for a proper diagnosis and repair. I hope this information is helpful to you. -Matt
Jun 15, 2015 | Frigidaire Dryers
Control panel off
Did you try unplugging it and plugging it back in? Is there a power button? If so plug the unit in and try to press and hold it for 5 seconds and see if then it powers on.
Oct 15, 2013 | Amana NED7200TW Electric Dryer
On my GE Profile Microwave the led is lighted and shows the time correctly and displays the led buttons. When I press on the led buttons nothing seems to happen. Also, after some idle time, the led panel...
The touch panel has malfunctioned, Suggest replacing microwave unless you want to attempt repair. If so you will need a replacement touch panel for it.
Jun 14, 2017 | GE Microwave Ovens
Repair tips for Logik 74cm
Look for any jammed buttons on control panel and/or on remote control.
Aug 12, 2012 | Televison & Video
I have power to the dryer. The control panel lights up. I hear beeps and clicks. However, nothing else happens when I press the start button. The motor does not come on, the door latch feels like it is...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 26, 2011 | Dryers
Turn on ok. Press start and spin light blinking and beeping.
Several problems were found
1. the touch panel PCB board had tracks which were damaged by moisture and had it repaired for $50 (Aus); this affected the advance function on the washing machine.
2. Controller motor was replaced with a rebuilt one (since the touch panel kept on shutting down).
3. Make sure that the wire holding the harness reed switch is tight (this I think controls the level in the washing machine).
Apr 13, 2009 | Fisher Washing Machines
Dishwasher does not turn on
I believe if you look closly, you will see the G is actually a Q. So the valid model number is DU980QPDQ3.
This model has a controller module (CNTRL-ELEC $188.00 US) that includes the buttons in the door panel. The logic/control begins there and communicated with the display and the timer/timer motor.
Depending on the age of the unit, you need to choose between repair or replacement. Good Luck!
Mar 29, 2009 | Whirlpool 24 in. DU980QPD Built-in...
Printing troubles
Paper jam:
Clear the paper jam. If the printer does not start printing, press the control panel button.
No paper:
Put paper in the printer. Then press the control panel button.
Misfeed:
Put the paper back in properly, and then press the control panel button. The printer will start printing again.
Mar 24, 2008 | Brother HL 1440 Laser Printer
My dishwasher control panel does not light-up
This is a common problem. I am about to replace my second control panel in two years. First time was under warranty and I hope this time will also e under warranty.
Jan 21, 2008 | Maytag MDB9750AWS Built-in Dishwasher
Bosch Nexxt WTMC 3300 Electric Dryer Logo
342 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
