Question about JVC GR-D770 Camcorder
My video camera will turn on, rewind, fast forward, pause, stop, record- but it won't PLAY! I don't know why, I've tried turning it on and charging it but it just won't play! I have a video tape in it with video on it, it just won't play the video for me.
    Genius:
  • 1,812 Answers
Tape mechanism problems are quite complicated but they can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be diagnosed by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on Oct 10, 2010
Sony Handycam CCD-TRV37 8mm Analog... 2 Problems, maybe more unknown at this time:
This does require disassembly to remedy the problem. There are various possible fixes. The most prevelant I have seen is cold solder connections of the board connector for the fpc cable from the top operation switch block ass'y. All you need is someone who can handle this task, like a professional. The controls that you are experiencing problems with are all linked with one cable and connector. One bad solder joint can cause serveral operation faults. Good Luck, magic seadog
Aug 18, 2007 | Sony Handycam CCD-TRV37 Camcorder
I do not know how to use it, i have the manual, but i do not find it
The recorder takes 2 AAA batteries. Press Menu/Folder (on the right above the jogdial (Stop, Rewind, Fast Forward, Play)) to select the folder to add a new recorded item. (The folders are A,B,C, or S. Folder S will come up with a date and you can select another date for the recording.) Folders A, B and C can hold 100 files each; Folder S has 365 dates which can hold 15 items each.
Press and hold the Menu/Folder button for a second or longer. The Screen should show the Mode menu. Press Play and then the Fast Forward and Rewind buttons to set the recording quality. HQ is the high quality recording and will fill up the available storage on the organizer more rapidly. LP will record for the longest period.
Set the Microphone sensitivity by pressing and holding Menu/Folder. Then press the Fast Forward or Rewind button until Mic appears on the display. Then press Play and use the Fast Forward or Rewind buttons to select Low or High sensitivity. (An external mic often gives better results.)
Once you have set the folder for the next recording and the recording quality and microphone sensitivity, press Rec (center above the jogdial) to start recording. Press Stop to end the recording or Rec to pause it. (It will stop if the Pause is longer than 10 minutes.) Press Display to see how much longer you can record before using up the available storage space.
To play back a record, locate the item in the folder then press Play.
The manual for the Olympus VN-1800 is available from the Olympus support site: http://www.olympusamerica.com/cpg_section/cpg_support_manuals.asp?id=841 . The direct link to the English version of the manual is http://www.olympusamerica.com/files/oima_cckb/VN-900_VN-1800_VN-3600_Instructions_EN.pdf .
I hope this helps.
Aug 30, 2011 | Olympus VN-1800 Digital Voice Organizer
How can i watch video from Samsung s1050 in my computer?
Hi, Here is the procedure on how to play the video clip on your camera. Play mode If you have turned on the camera by pressing the POWER button, you can press the PLAY MODE button once to switch to Play mode and press it again to switch to Recording mode. You can turn the power on with the play mode button. The camera is turned on in play mode. Press the play mode button again and the camera will be turned off. You can set up the PLAY mode function by using the camera buttons and LCD
monitor. Playing back a still image
1. Select the PLAY mode by pressing the play mode button.
2. The last image stored on the memory is displayed on the LCD monitor.
3. Select the recorded movie clip and press the Play & Pause button to play back.
- To pause a movie clip file while playing it back, press the play & pause button again. ac0dd93.png
- Pressing the play & pause button again will cause the movie clip file restart.
- To rewind the movie clip while it is playing, press the LEFT button. To fast forward the movie clip, press the RIGHT button.
- To stop playback of the movie clip, press the play & pause button, and then press the LEFT or RIGHT button. 0e83d9c.png
Apr 13, 2010 | Samsung S1050 Digital Camera
Erasing recorded tapes
While holding the 'Erase' button down, press the 'Rewind' or "Fast Forward' button. It will erase the tape while it rewinds or fast forwards.
Apr 20, 2009 | Philips Desktop 720-T Desktop Cassette...
Won`t Rewind
Do you still have the remote control? Try with the remote. If this works, the button of the camera is broken and have to be replace by a qualified technician. Good luck!
Sep 27, 2008 | Sony Handycam CCD-TR517 Camcorder
Incompatible Tape
try a cleaning tape first - best not to rewind the cleaning tape because it will put back the crud previously removed ? into your heads and guides ( last tape to play is prime suspect ) ; - - digital heads wear faster than analog so a new set of heads is next possibility but if the cleaning tape works . . . retire your library soon as possible .
Jul 26, 2007 | Panasonic PV-DV400 Mini DV Digital...
Help! Stopped Recording
Do you have a remote? Some camcorders you have to hit the record pause button on the remote and then hit pause. It then begins recording. I hope this works for you.
Jul 13, 2007 | Samsung VP-D10 Mini DV Digital Camcorder
Help it's going to fast
Your camera has a capstan servo problem which is more than likely being caused by the capstan motor itself.Nothing you can do youself,would suggest bring to service but reccomend getting estimate before repairing.
May 23, 2007 | Panasonic PV-GS31 Mini DV Digital...
Recoding and viewing
sir , the lcd flap of the camera has been spoilr\ed due to this the image is not coming on lcd , only u have to take the image through view fider , lcd fpc has to be changed / repaire u can contact me also omaxphoto@yahoo.co.in
Mar 28, 2007 | Sony CCD-TRV228E Camcorder
JVC GR-D770 Camcorder Logo
26 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
