Question about HP Color LaserJet 2600n Printer
HP 2600 ghosting
My HP 2600n laserjet has started showing ghost images running down the left side of the page. I have tried cleaning but it does no good. Any help?
  • 1 more comment
  • surlyjoe May 29, 2008
    I tried changing the toner cartridge. That did not improve the image ghosting.
  • Anonymous Nov 13, 2008
    down the right side of the page....only with the black though
  • Anonymous Jan 27, 2009
    The supplies status report only lists the amount of toner left.
    This printer seems to be notorious for poor performance with card stock especially. Blobs and ghost shadows everywhere.
    Good printer for standard paper, but if you are planning to print on card stock...don't buy it.
It is a massive pain but a solution that worked for me is to run a 'clean' after every card stock sheet. I know it's wicked awful but it actually worked and I had to run 100 times (one for each good color card stock)
First put plain paper in tray 2
Next
Hit left arrow until you get to 'system service' and press green check
Next
then go to 'clean' and press check
Now it should print a clean image without ghosting
Posted on Jan 25, 2010
  • 300 Answers
Change the toner cartridge
Posted on May 29, 2008
  • wayne churchill May 29, 2008
    Sorry didn't read the problem properly, this is normally caused by a faulty transfer belt. Print a supplies status page and check the life of the consumables
HP 2600n Laserjet Ghosting. Prints multiple, faint repeats down the page. Changed all toner cartridges, still happening
Perform fuser cleaning procedure. If not helpful, replace the hot fuser roller. When worn out it collects toner and may lead to repetitive image.
Mar 09, 2017 | HP Color LaserJet 2600n Printer
Ghost images of the same printing repeated down the page
Run a half test. While printing a few pages, open the cover, pull out the toner and look down at the paper. If you see the ghost images replace the toner. If you don't see the ghost images, replace the fuser.
Sep 11, 2010 | HP LaserJet 1020 Printer
HP 2600n is printing ghost which distorts text and objects
Using the left and right arrow buttons on the printer select the main menu 'service' press the green tick button in the middle of the arrows and now you are in the service menu press the right arrow once and you should see 'cleaning mode', press the green tick once and your printer should clean itself. If you are still getting ghosting you might need a new toner or maybe a service.
May 06, 2010 | HP Color LaserJet 2600n Printer
My printer is leaving faint marks of other words down the side of the page...any way to fix that?
Yes, It sounds like a ghosting issue. Several components can cause a ghosting issue. The distance between the first occurance(the one on purpose) and the second occurance(ghost image) can determine the part of the machine causing the image problem
56.6mm - Fuser
54.5mm - Transfer Belt
75.4mm - Drum unit (1 of toner carts)
Dec 11, 2009 | HP Color LaserJet 2600n Printer
HP 2600n - Maintenance of the transer roller sheet
You can clean it using piece of paper (not printed). time for replacement - your image is very ghostly and you cant get better image after cleaning lasser/scanner assy :)
Oct 22, 2009 | HP Color LaserJet 2600n Printer
I get ghost images every 2-3 inches down both
run the "cleaning" cycle is the first thing that you should trying.
The Fixing Film Assembly is worn-out. it is a frequent problem.
Fix this with a new FUSER Assembly for HP Colour Laserjet 2600/n (200/240v) Part Number: RM1-1821-240CN or Fusing Assembly – RM1-1820(110/120v
Oct 05, 2009 | HP Color LaserJet 2600n Printer
Ghosting
fuser could be faulty
Jun 12, 2009 | HP Color LaserJet 2600n Printer
Double printing, especially down the left hand side of page
replace fuser,if still happening replace transfer belt
Apr 30, 2009 | HP Color LaserJet 2600n Printer
Hp laserjet 2600 ghosting
You are most likely correct. this is called fuser offsetting, to check it out, stop the paper being printed MID CYCLE open the front door just when you think the paper is behind it..., pull the paper off the transfer belt. Is the ghost there? Probably not, and if it isnt, then it is your fuser. I can lead you to a reputable supplier. You can buy QUALITY rebuilt fusers with great warranties at prices well less than new OEM.
Mar 11, 2009 | HP Color LaserJet 2600n Printer
HP LaserJet 1012 Printer prints ghost images
I ran the hp toolbox "cleaning" mode too and it did not help the problem at all. I still have a dark smear concentrated in the middle of the page, and ghost images repeated lighter all the way down the page.
Aug 21, 2008 | HP LaserJet 1012 Printer
HP Color LaserJet 2600n Printer Logo
1,894 people viewed this question
Ben Johnson
