Question about Bushnell Deep Space 78-9512 (120 x 60mm) Telescope
Need 4 self tapping screws for altitude lock knobs
  • 3,186 Answers
You may be able to get these here by calling their service center:
http://www.opticsplanet.net/bushnell-warranty.html
Or at a well stocked hardware store.
Posted on Oct 07, 2010
I have a craftsman lawn mower item#28885. I have a bagger model #247.240193. the manual is asking me to mount the brackets to the tractor using four self tapping hew screws. I need help in this step...
I don't know what screws you have,but self tapping screws are some what tapered on the end. The taper is to allow the screw to center in the blank hole,( Hole without threads) When you start to tighten the screw it will,cut it's own threads,using a little tapping fluid or WD-40 oil will make it easier to allow the screw to cut better threads and easier to tighten down the screw. Hope this answers your question. Sincerely Brad Locke DTD. 12/04/15
Jul 05, 2013 | Sears Craftsman 46 in Mulching Tractor...
Replacing gear cables on a kia sedona
To change the gear change cables unpop the sliver center shroud un do about 10 self tapping screw. un do 4 13 mm bolts on gear stick bracket. this is all after you have taken gear knob off . which is held on by cable tie. then pop the bonnet remove air box. and disconnect cables red and black one on gear box linkage. and in side un do inspection plate brhind centre console .
Oct 27, 2011 | 2004 Kia Sedona
The screws that hold our doorknob don't hold the knob anymore.They have loose threads and the screws are already too short that they don't hold the knob anymore. Everytime we turn the knob and pull it to...
Get a tap and re-tap the threads to the next screw size up. Then get matching setscrews. You could put a bit of Loctite on the new screws to keep them secure. Use a FINE thread tap so you get more threads in the knob.
Another solution is to clean and fill old screw hole with metal filled epoxy. Let is dry and re-drill and re-tap to original thread. Devcon makes a filled epoxy as well as JB Weld.
Mar 18, 2011 | Garden
I have a lawnboy self propeled mower model #10533. the serial number is 6907889. i do not know where the spring-choke return spring goes. if i had a picture of it installed i could do it becuase i am not...
For getting big view of picture please click on the link below http://www.ask.com/bar?q=lawnboy+self+propelled+mower+model+%2310533&page=1&qsrc=19&dm=all&ab=5&u=http://www.partsandservice.com/html/Lawnboy/Lawnmower/10533.html&sg=jTUCMw17SUPaA/y4FH3G/QzzCbOKvHGnvkxGP%2Bp36m4%3D&tsp=1276102809824 Part number 5 is what you want to see in the fig and fit. 1 1 Housing, Deck (Incl. Ref. #2 & 40)
2 1 Decal, Danger
3 1 Decal, Deck
4 1 Shield, Trailing
5 1 Spring, Extension
7 2 Screw, Hex Hd.
8 1 Ramp, Discharge
9 2 Screw, Shoulder
10 2 Clamp, Hinge
11 2 Bolt, Wheel
12 2 Knob, Arm
13 2 Washer, Flat
14 1 Seal, Door
15 2 Screw, Thread Form.
16 1 Brace, Door
17 2 Pin, Hinge
18 4 Nut, Lock
19 1 Decal, Warning
20 1 Door, Discharge
21 1 Panel, Vertical
22 2 Spring Arm ***'y, Front
23 2 Bushing, Door
24 1 Cover, Access
25 2 Hanger, Shield
26 1 Cable, Door
27 1 Handle, Hood
28 2 Screw, Tapping
29 3 Screw, Tapping
30 2 Seal, Door Side
31 1 Seal, Door End
32 2 Tire & Wheel Assembly, 8"
33 4 Washer
34 2 Arm, Pivot
35 1 Bracket, Discharge Ramp
37 1 Panel, Screen
38 1 Screw, Thread Form.
39 2 Bolt, Shoulder
40 1 Decal, Warning
41 1 Decal, Instructions
42 2 Cap, Hub
43 1 Decal, AppliqueThis are the parts in your mower.Thanks. keep updated for any morequery.you can rate this solution and show your appreciation.
Jun 09, 2010 | Garden
Shift knob fell off
All depends on the fittment type of the gear knob its self, some are screw on, some are simply push on and lock in place. will be able to find a replacement on ebay possibly...simply screw it on or push it on.
Jun 01, 2009 | 1996 Ford F250 Crew Cab
Hoover self propelled U6630900 idler arm lock
Remove the bottom plate (4 screws), remove belts and brush roller. There may be 1 small screw in the center front of the vac under the brush roller. remove this one. If this is a bagless model you will also need to remove all of the back screws (torx) that hold the lower hose on. This needs to be removed to take the hood off. underneath on each side of the power drive assembly you will have 1 screw, remove them. there is a clip on each side that snaps the front on, push them out with a screwdriver. Then the hood is removed.
Feb 28, 2009 | Hoover U6630-900 WindTunnel Bagless...
The Azimuth Dial isn't firmly attached cause altitude cannot be fixed to an angle
Most of the small telescopes setting circles really cannot be used to find anything--- just not accurate enough---
Try using a star chart -- and star hopping --- to what you want to see.
A free monthly star chart is available at :
www.skymaps.com
Jan 03, 2009 | Bushnell Voyager 78-9945 Telescope
Missing Altitude Control Locking Knob
Go to any well stocked hardware store and buy a similar bolt-- get stainless steel so it won't rust.
Nov 22, 2008 | Natural Science Industries Smithsonian 525...
Kenmore 110 timer
the allen head screw should be for the holes. they should tap themselves. with washers the metal is so thin you don't really need selftapping screws. but not know what model you have i can't be 100% sure. good luck
Aug 06, 2008 | Washing Machines
Bushnell Deep Space 78-9512 (120 x 60mm) Telescope Logo
48 people viewed this question
Top Bushnell Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
