Question about Maytag 24 in. MDB6100A Built-in Dishwasher
Model no. MDB6100AWW. Just unloaded the dishwasher. Shut the door and immediately heard clicking (regular cadence). All indicator lights (arrow-shaped) for clean, dry, wash and heating delay were blinking. Opened the door, waited a few minutes, closed the door. Now, just the "Clean" and "6 Hour" arrow indicator lights and "Heated Dry" button light indicator are still blinking continuously. Cannot override. What's going on? Dishwasher came with the house when we purchased it 6 years ago. Probably orirginal equipment when the house was built in '99. Any ideas?
  • 1 more comment
  • njgd Oct 08, 2010
    "Hi-temp wash" is not an option. Buttons, from left to right, are as follows: "Rinse Only," "Light Wash," "Normal Wash," "Heavy Wash," "Accu-Temp," "Heated Dry," "Drain/Off," and "3 Sec."
  • njgd Oct 08, 2010
    Nope. Doesn't work.
  • njgd Oct 08, 2010
    Nothing.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
If still the issue is not resolved then you'll have to replace the control panel. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Oct 07, 2010
  • 1 more comment
  • Rylee Smith
    Rylee Smith Oct 08, 2010
    Press Normal wash-Heated Dry-normal wash-heated dry buttons in sequence.
  • Rylee Smith
    Try the Rinse only
  • Rylee Smith
    The control is bad and should be replaced.
BOSCH DISHWASHER SHV55MO3GB 60CM HOW DO I ADJUST THE DOOR SPRING ON THE MACHINE? AT PRESENT WILL NOT LIE OPEN AND SPRINGS SHUT WHILST TRYING TO UNLOAD.
do you want to adjust the door spring or the door latch?
if the spring is damaged or misplaced you will have to open it and change it
Aug 03, 2008 | Dishwashers
Samsung model number DW7933LRASR wont start.. clean button is staying lit up....
After the dishwasher has completed all portions of a cycle, all other indicator lights are turned off and the "Clean" light is illuminated for 10 minutes. If you open the door when the "Clean" light is illuminated, it turns off immediately. If this is not happening for you the unit may require service.
Online Virus Removal 39 99 Online Virus Removal and Online PC Help
Jan 12, 2015 | Samsung Dishwashers
Salt (PC) light is flashing
Miele dishwashers have a built-in water softener. I suspect the unit is indicating that the dishwasher softener salt is low or needs to be replenished.
Which model dishwasher do you have? http://www.mieleusa.com/products/modelsg5000.asp?cat=2&menu_id=1&oT=125&active=Our%20Products&subm=Home%20Appliances&thirdL=Dishwashers&fourthL=Products lists a number of their dishwashers and has the manuals for them. Click on the model and scroll down. Click on the Manuals tab. (Click on the Retired models if your dishwasher isn't on the first page.)
I hope this helps.
Apr 10, 2012 | Miele Dishwashers
Maytag Dishwasher MDB6100AWW - control panel short??
If you can take the panel out dry it with a blower.You can use the hair dryer to remove the moisture. Do not point the hot air on the components for more than 20 seconds. Repeat it. If you notice any white/green fungus remove it. Check the connectors also.
May 17, 2010 | Dishwashers
Bosch Dishwasher SHX46A latch stuck in down possition.
look at the latch via the hole in the door where it closes to the tank? is the latch faced away from the tank? if so, then grab a paper clip and fold it so you can hook it around the latch then just pull outward towards the tank. you might need to hold that paper clip with some pliers. if it happens more than once then you will need to replace that door lock.
Mar 18, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Door open light stays on when door shut.
sounds like a faulty door switch not sensing that the door is shut. test the switches for continuity to determine the faulty switch
Jan 27, 2009 | KitchenAid KUDS24SE Built-in Dishwasher
Help with dishwasher
What Brand is it?
Dec 31, 2007 | Dishwashers
Maytag 24 in. MDB6100A Built-in Dishwasher Logo
243 people viewed this question
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
