Question about Tamiya America Tamiya 14044 Yamaha Virago Xv1000 Motorcycle 112
I have a 1997 Virago 1100 my headlight quit working. I checked it directly to the battery to make sure the headlight is good & it is. The fuse is good but no voltage coming out of headlight receptical. Thank you Jake
  • goodrow1 Oct 09, 2010
    Anybody who has this problem on the virago.It is the starter switch.EXERCISE IT AND SPRAY WD40 ON IT.A simple solution that me pulling my hair out for 2 days. Many people have had this problem with the virago. good luck JAKE
  • 26 Answers
Did you check the ground were the light plugs into the wiring harness ?
strip the hot wire and check before the plug ... also may want to check ground on unpainted surface..
hope this helps
Posted on Oct 08, 2010
  • Holidayhayes Dec 22, 2010
    Had this same problem on another 97 Virago 1100, did as Goodrow1 said and pulled the starter button out and that was it! A shot of WD-40 and it seems to be ok. Turns out that the starter switch cuts power to the headlight ahen you crank the bike to keep from overexerting the battery. Sometimes it gets dirty and sticks part way in. Thanks for posting this! Kevin
The head light is out
Hi, Anonymous if your headlight is not working, keeps burning out, blinking, or is dim the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, that being said the usual suspects are:
1. Faulty ground or power supply wire to headlight bulb socket.
2. Worn, chaffed, or broken wires in the light circuit.
3. Corroded, broken, or loose pins/sockets in wire connectors.
4. Faulty hi/lo beam switch.
5. Faulty ignition switch.
6. Fuse is good but no continuity on both sides.
7. Faulty wiring between battery positive and headlight bulb socket.
8. Weak charging alternator/generator.
9. Faulty voltage regulator/rectifier, overcharging.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
ViragoTechForum com
Yamaha Xv250 Virago light fuse location Google Search
http://www.groussin.com/multi/XV250.pdf
OEM parts for Yamaha
http://www.starmotorcycles.com/assets/service/manuals/2005/LIT-11626-18-21_1000.pdf
Apr 22, 2014 | 1997 Yamaha Xv 250 Virago S
1997 Honda VT 1100 C2 Shadow Sabre headlight not working
Hi, Anonymous if your headlight is not working, only one beam works, keeps burning out, blinking, dim or surges from bright to dim to bright the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, then check your head light bulb socket ground wire for a clean tight connection, that being said the usual suspects are:
2. Worn down solder contacts or loose fit of the bulb base in the socket due to vibration.
3. Worn, chaffed, or broken wires in the light circuit.
4. Corroded, broken, or loose pins/sockets in wire connectors.
5. Faulty hi/lo beam switch.
6. Faulty ignition switch.
7. Fuse is good but no continuity on both sides.
8. Faulty headlight relay.
9. Faulty wiring between battery positive and headlight bulb socket.
10. Weak charging alternator/generator/lighting coil.
11. Faulty voltage regulator/rectifier ground or overcharging.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Headlight problem
Installing HID light on Honda Shadow
Honda shadow vt1100 Owners Workshop Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda VT1100C2 Owner Manual Page 3
Nov 24, 2013 | 1997 Honda VT 1100 C2 Shadow Sabre
Headlight out 1983 yamaha virago
Headlights not working The FZR Forum
Electrical fault 1982 Yamaha Virago 920J
Yamaha XV 535 DX Virago Service Manual
http://www.starmotorcycles.com/assets/service/manuals/2000/LIT-11626-13-16_110.pdf
Aug 02, 2013 | 1993 Yamaha XV 535 Virago DX
Hi I have a 93 Virago 1100. Troubleshooting the Headlight. Fuse is good, the bulb is good. Whats next?
Do a contunity test on the power wire and the ground. The ground is suspect here but test both lines.
Feb 25, 2013 | Motorcycles
Headlight keeps blowing out 1996 yamaha virago 1100
Hi, Anonymous if your headlight is not working, only one beam works, keeps burning out, blinking, or is dim the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, then check your head light bulb socket ground wire for a clean tight connection, that being said the usual suspects are:
8. Faulty wiring between battery positive and headlight bulb socket.
9. Weak charging alternator/generator.
10. Faulty voltage regulator/rectifier ground or overcharging.
Headlight globes keep blowing
Yamaha Virago XV535 1100 1981 1994 Service Manual
Yamaha Virago XV1100K Owner Manual
Jul 22, 2012 | Yamaha Motorcycles
1995 yamaha virago 1100 headlight wont work
ViragoTechForum com
Headlight stopped working
Jul 13, 2012 | Yamaha Motorcycles
The headlight low beam went out, a few days later the high beam went out. I replaced the bulb, the headlight still dosent work. What do I do now? 1996 Yamaha Virago xv 1100
have you checked your fuses? next thing is to check for voltage at your connecter. if now voltage start tracing wiring back to fuse block.
Jul 25, 2011 | Yamaha Vino Motorcycles
Headlights quit ,were working fine and just quit,checked the fuse,it's ok,do not think plug is getting power.running lights work,taillight works?
Using a multimeter check for voltage across the headlight fuse if yes then follow headlight power wire to the connector under the tank, if power is present then check for power at the headlight plug
It is quite common for wires to split inside the harness where they go around the headstock. This is because of chafing & stretching as they move with the handlebars
Hope this helps
Please mark as helpful if it has been
Ride safe
Bike-doc
Oct 27, 2009 | 1994 Yamaha XV 535 Virago DX
No power to headlight or headlight switch.
Hi, Dutchmen73 if your headlight is not working, keeps burning out, blinking, or is dim the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, that being said the usual suspects are:
Headlight has no power fuse does
Mar 16, 2009 | 1997 Yamaha XV 535 Virago DX
Tamiya America Tamiya 14044 Yamaha Virago Xv1000 Motorcycle 112 Logo
520 people viewed this question
Top Tamiya America Toys Experts
ray gallant
Are you a Tamiya America Toy Expert? Answer questions, earn points and help others
