Question about Advent 4211c Notebook
I have a File: \Boot\BCD error but have no windows installation disc. What should I do?
  • dhutchie80 Oct 07, 2010
    There is no disc drive on this notebook
    Master:
  • 388 Answers
You will have to get one from somwhere pc world or maplins even try ebay. carry out a re-instal. hope this helps.
Posted on Oct 07, 2010
  • David Bottomley Oct 07, 2010
    you can plugin an external dvd or cd player unfortunatly this is a big problem with netbooks.
Accer aspire 5715z problem file boot/bcd
It seems that the Boot Configuration Data (BCD) is corrupted.
Microsoft has completely reengineered the boot environment for Microsoft Windows Vista to address the increasing complexity and diversity of modern hardware and firmware. One aspect of this reengineering is a new firmware-independent data store that contains configuration data that influences the boot process. This paper provides an overview of this configuration data - called boot configuration data (BCD) - and describes how to use the related tools to manage boot options.
Step 1
Perform chkdsk which will repair the bad sectors of the hard drive.
To do this, follow these steps:
1. Click Start, click All Programs, click Accessories, right-click Command Prompt, and then click Run as administrator.
2. Type chkdsk/ f, chkdsk/r, chkdsk/i, chkdsk/c in the commands listed below i.e. (/f, /r , /i, /c).
Step 2
Try to load BIOS to default and check if you have similar issue.
Step 3
I would suggest you to rebuilt BCD. To do this, follow these steps:
To run the Bootrec.exe tool, you must start Windows RE. To do this, follow these steps:
  1. Put the Windows Vista or Windows 7 installation disc in the disc drive, and then start the computer.
  2. Press a key when you are prompted.
  3. Select a language, a time, a currency, a keyboard or an input method, and then click Next.
  4. Click Repair your computer.
  5. Click the operating system that you want to repair, and then click Next.
  6. In the System Recovery Options dialog box, click Command Prompt.
  7. Type Bootrec.exe, and then press ENTER.
8. Type bootrec /RebuildBcd , and press Enter.
Aug 06, 2012 | Computers & Internet
File: \Boot\BCD Satus: 0xc0000098 Info: The windows Boot configuration data file does not contain a vaild OS entry. I have a windows installation disc
boot to the Windows DVD, select the option to REPAIR, If this is only a software issue, that should resolve.
If it doesn't then run diags on the HDD is it may be failing
Jan 15, 2011 | Computers & Internet
Windows boot manager for TOSHIBA PRO L300
You will need an original windows installation disc and not a recovery disc. If you do not have one, then you have the option of taking to a shop that does and have them run the repair utility. Or, if you can find someone who has burned a copy of the windows ultimate boot disc, that will also help in repairing the boot manager and files.
May 23, 2010 | Toshiba Satellite A135-S4527 Notebook
What is file error 0xc000000e
File: \Boot\BCD
Status: 0xc000000e
Info: An error occurred while attempting to read the boot configuration data.
Windows Boot Manager
Windows failed to start. A recent hardware or software change might be the
cause. To fix the problem:
1. Insert your Windows Installation disc and restart your computer.
2. Choose your language settings and then click "Next"
3. Click "Repair your computer"
If you do not have this disc, contact your system administrator or computer
manufacturer for assistance.
ERNZ
Feb 03, 2010 | Toshiba Sattelite A105-S2051 Notebook
Ntoskrnl 0xc0000098 error
To Solve the problem refer to steps below
  1. Put the Windows Vista installation disc in the disc drive, and then start the computer.
Note To start the computer from the Windows Vista DVD, the computer must be configured to start from the DVD drive. For more information about how to configure the computer to start from the DVD drive, see the documentation that is included with the computer or contact the computer manufacturer. uparrow.gifBack to the top Bootrec.exe options loadTOCNode(2, 'moreinformation'); The Bootrec.exe tool supports the following options. Use the option that is appropriate for your situation.
Note If rebuilding the BCD does not resolve the startup issue, you can export and delete the BCD, and then run this option again. By doing this, you make sure that the BCD is completely rebuilt. To do this, type the following commands at the Windows RE command prompt:
  • bcdedit /export C:\BCD_Backup
  • c:
  • cd boot
  • attrib bcd -s -h -r
  • ren c:\boot\bcd bcd.old
  • bootrec /RebuildBcd
/FixMbr loadTOCNode(3, 'moreinformation'); The /FixMbr option writes a Windows Vista-compatible MBR to the system partition. This option does not overwrite the existing partition table. Use this option when you must resolve MBR corruption issues, or when you have to remove non-standard code from the MBR. /FixBoot loadTOCNode(3, 'moreinformation'); The /FixBoot option writes a new boot sector to the system partition by using a boot sector that is compatible with Windows Vista. Use this option if one of the following conditions is true:
  • The boot sector has been replaced with a non-standard Windows Vista boot sector.
  • The boot sector is damaged.
  • An earlier Windows operating system has been installed after Windows Vista was installed. In this scenario, the computer starts by using Windows NT Loader (NTLDR) instead of Windows Boot Manager (Bootmgr.exe).
/ScanOs loadTOCNode(3, 'moreinformation'); The /ScanOs option scans all disks for installations that are compatible with Windows Vista. Additionally, this option displays the entries that are currently not in the BCD store. Use this option when there are Windows Vista installations that the Boot Manager menu does not list. /RebuildBcd loadTOCNode(3, 'moreinformation'); The /RebuildBcd option scans all disks for installations that are compatible with Windows Vista. Additionally, this option lets you select the installations that you want to add to the BCD store. Use this option when you must completely rebuild the BCD.
http://support.microsoft.com/kb/934540/en-us
Mar 22, 2009 | Sony VAIO VGN-NR180EW Notebook
Advent 4211c Notebook Logo
163 people viewed this question
Top Advent Computers & Internet Experts
Lee Durbin
Lee Durbin
Computer Links
Are you an Advent Computer and Internet Expert? Answer questions, earn points and help others
