Question about Gateway MX3560 Notebook
Gateway mx3560 wireless (yellow exclamation mark) on device manager
Dear Sir or Madam:
I reloaded my operating system and drivers, but a yellow exclamation mark on the wireless device manager prevents me from access internet wirelessly. Gateway says I need the factory recovery CD. All I need to do is get the intel(R) wireless 2200bg network connection to have success.
Any ideas/
  • Anonymous Mar 16, 2014
    need a wireless network driver for Gateway Nv51 B08u Laptop
None of this works as this is a driver problem and the gateway website provided driver does not work.
HELP
Posted on Jun 20, 2010
  • 137 Answers
Obtain an ethernet cable and connect to the Gateway Support site using wired network temporarily to download and install the proper wireless driver.
Posted on May 29, 2008
Try to disable and enable it.....2. uninstall and reinstall from cd or recovery manager 3.do a bios default and a update ..4.or do a reseat of the wireless card 4. do a recovery again
Posted on Jul 22, 2008
Just got a wireless modem from telstra. now the computer is making static noise?
you will have to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled or
you could click start control panel administration tools computer management device manager look for network adapters + expand Ethernet driver if you see a yellow question exclamation mark or a red X you will need to update/reinstall the driver for the device if you computer came with a motherboard disk the driver could be on it
hope this helps you
Oct 09, 2011 | Dell WL6000 Computer Speakers
Connect via wireless router, but when i click on internet explorer it says internet explorer cannot display webpage
this could be a driver problem or it might be firewalled
you will have to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled or you could click start control panel administration tools computer management device manager look for network adapters + expand Ethernet driver if you see a yellow question exclamation mark or a red X you will need to update/reinstall the driver for the device if you computer came with a motherboard disk the driver could be on it
also
the drivers might be installed for this device
click start control panel administration tools computer management device manager scroll through all of your devices if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver if you computer came with a motherboard disk the drivers could be on it
hope this helps
Sep 18, 2011 | Computers & Internet
Hp in built web cam not working. the web cam drivers are installed,but wen try to on cam...it gives mgs cam not found....
I would still look at it as a driver problem. go to your computers device manager and check whether you have any yellow exclamation marks. if you have, then fix that first. reload proper drivers according to your camera and Operating system.
Nov 22, 2010 | HP Computers & Internet
Neither the Acer supplied wireless mouse or wireless keyboard work with my new Acer Aspire M3300 PC. I inserted the supplied batteries the correct way round and the blue led come on for a few seconds,...
make sure you have the right keyboard and mouse selected
this will depend on which operating system you have
click start control panel view devices and printers you should see your mouse and keyboard right click on either select properties then hardware make sure you have the correct one selected in W 7
make sure you have the right mouse selected click start control panel mouse hardware you will see which mouse is selected
this will apply to keyboard to in XP
make sure the battery is good ((has full charge))also you might test the usb device for the mouse is inserted correctly into the usb port ((if applicable))
click start control panel administrive tools computer management device manager scroll to mice and other pointing devices you might see a yellow exclamation mark ! or question mark ? or a red x
right click you will need to update the driver
hope this helps you
Aug 30, 2010 | Computers & Internet
I have a Lynksys wrt54g router. I had to reload my operation system completely due to a software issue. I can't get onto the internet system without being plugged into the router. I had wireless access...
Check in device manager to see if you have the drivers installed for your network adapter (look for yellow exclamation marks).
If they are all ok, have you put your password in for your wifi security
Jul 19, 2010 | Linksys Wireless-G WRT54GS Router...
Anybody there ? i m having problem in installing drivers after formatting the computer. I downloaded the drivers and installed but they are not working. please tell me exact name/location of drivesr....
What drivers arent working exactly? Each hardware component on your computer comes with its own drivers, one thing you might want to do is access your device manager [right click 'my computer' and click 'manage', then click 'device manager' in the console tree]. expand each the devices that either have a yellow exclamation or question mark next to them. The yellow exclamation mark implies a conflict while the yellow question mark implies that the drivers are missing, you could right click the device and click on 'properties' then click 'update drivers' and the OS will do the update for you automatically, or you'll have to manually download them from the manufacturers websites. In this case you'll need to know the Model number of your computer, the kind pf processor and chipset you have and the name of the Operating System. Good luck
Jun 20, 2009 | Lenovo ThinkPad R60 with Wireless Wide...
Sir my windows media player is not running , it shows sound divice is not installed so how can i install sound divice
Check for the sound driver on ur system... see if the same is installed or not... To acess device manager in windows system... u need to click on Start-> then go to Run -> in the run box just type devmgmt.msc & u'll get th device manager to show up... In the device manager just check for sound video & games controller... If there is a yellow ? mark then u need to reinstall the drivers or else if there is a yellow exclamation mark then there is a driver conflict for the audio device on ur system...
Jan 29, 2009 | Computers & Internet
Wi Fi
the wifi driver has malfunctioned reinstall the driver to find the appropriate driver for that by right clicking on the yellow exclamation then copy the details of the driver then you can search the driver in the manufacturers site or in drivercollection.com
thanks for posting
Sep 20, 2008 | Gateway MX3560 Notebook
Synaptics TouchPad wont work
touchpad is not working because the driver not installed properly just check in device manager that will be located in controlpanel ,system properties and select hardware tab see if u have any question mark or else exclamation mark in yellow colour in device manager option that means the driver not installed properly
Aug 02, 2008 | Gateway MT3705 Notebook
Installed the drivers from the Gateway Web
i have a suggestion:
right click on the yellow exclamation mark then update driver then search for driver automatically if nothing happens go to manufacturers site and try downloading the driver to them directly.
May 29, 2008 | Gateway MX3560 Notebook
Open Questions:
Motherboard Repalcement I have a laptop - Details of the laptop: Gateway MX3560(model) serial # N625AC1052628 ( on the back of the laptop) Motherboard part number # 103501(required item) The motherboard of this got damaged and is not available.So, i wanna know, can i replace it with any other motheboard type - if there is any other motherboard which is compatible with this type.IF yes, please inform me as i am really worried about it. Other details are as follows - Processor Intel® Centrino? Mobile Technology with Intel® Pentium® M Processor 735 (2 MB L2 Cache | 1.70 GHz | 400 MHz FSB) Chipset Intel® 855GM Screen 14-inch Widescreen Ultrabright WXGA TFT Memory 512 MB DDR (1 × 512 MB) SODIMM (PC2700) Expandable to 1.5 GB Video Intel® Extreme 2 Graphics 32 MB Shared Video Memory Audio AC '97 2.3 Compliant Audio Built-in Stereo Speakers Hard Drive 80 GB HDD (4200 RPM) Optical Drive DVD +/- RW Multi-Format Double Layer Write maximum: 8X DVD +/-R, 4X DVD +/- RW, 2.4X DVD+R DL, 24X CD-R and 10X CD-RW disks Reads maximum: 8X DVD-ROM, 8X DL/+RW, 24X CD-ROM disks Media Reader 4-in-1 Digital Media Manager Secure Digital, Memory Stick, Memory Stick-Pro, and MMC Modem 56K ITU V.90 Fax/Modem Network Intel® PRO/Wireless LAN 802.11g SecureEasySetup? 10/100Mbps built-in Ethernet Pointing Device Touchpad with Vertical Scroll Zone PCMCIA 1 - Type I or Type II; Card Bus Interfaces 3 - USB 2.0 Ports 1 - IEEE 1394 port 1 - VGA External Connector 1 - RJ11 1 - RJ45 Microphone In Headphone / Audio Out Battery 6-cell Lithium-ion Dimensions 1.24-inches H × 13-inches W × 9.7-inches D Weight 5.24 pounds
Jan 07, 2009 | Gateway MX3560 Notebook
Gateway MX3560 Notebook Logo
776 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
