Question about Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
When i did y= and put in -x+3 for Y1 and (x-1) divided by -3 and hit graph, it says ERR:SYNTAX please help. im trying to solve linear systems by graphing.
  • kakima Oct 07, 2010
    When you put in -x+3 for Y1, did you use the (-) key or the - key?
  • Texas Instru... Master
  • 8,073 Answers
Try rewriting your equations in the equivalent forms that follow.
Y1=3-X
Y2=(1-X)/3
If you do not get a syntax error it means that you were not using the correct minus sign.
If the - is the first symbol after the equal sign you must use negation (-) or change sign key.
Similarly, after the division / key you must use the negation or change sign (-)
Posted on Oct 10, 2010
When I try to enter a simple equation and graph it, I get error 07 message instead of graph.
Error 07 Syntax
Means you made a typing error while entering the equation. Using the minus sign instead of the negation sign (change sign) (-), can produce a syntax error. Maybe you need to explicitly type the multiplication sign
y= (-) 1.5*x +3
Try entering it as 3 - 1.5*x
c3b67db6-adc8-4b0c-8e71-dc94a9bdbeb0.png eb28a330-c2e9-4879-857f-1e41bfe8515a.png
Jun 11, 2014 | Texas Instruments TI-86 Calculator
Err syntax pops up when trying to graph
You have a syntax error in the function you're trying to graph. Could you post the function in question?
Jan 17, 2013 | Texas Instruments TI-84 Plus Calculator
My calculator won't let me graph or find the linear regression.
You have attempted to use, edit, or delete an archived variable. For example, the expression dim(L1) produces an error if L1 is archived
Nov 03, 2017 | Texas Instruments TI-83 Plus Calculator
When trying to write simple graph lie Y=x+3 i get err: DIM MISMATCH QUIT
Dimension mismatch error occurs when arguments are not with same dimensions. Two or more arguments must be of the same dimension. For example, [1,2]+[1,2,3] is a dimension mismatch because the matrices contain a different number of elements. By the way, it it very easy to resolving your problem with graphing linear function. See captured image
Sep 22, 2011 | Texas Instruments TI-82 Calculator
My TI 84 plus silver: whenever I push the graph button the message ERR: Syntax 1:quit 2: goto appear on screen please help
Press the Y= button.
There are several possibilities:
1) Scroll through all equations, Y1 through Y9 and Y0. Make sure they are cleared.
2) The equation you typed in is not entered correctly.
3) Make sure Plot 1, Plot 2, and Plot 3 are NOT highlighted.
Feb 01, 2011 | Texas Instruments TI-84 Plus Calculator
I also have Err: Syntax when i try to graph and i think thats because i use the regular MINUS but how do i use this '(-)' minus??
Simply press the (-) key before entering a negative number, in the same place you see the negative sign in print.
For example, to multiply 3 by -4, press 3 x (-) 4 ENTER
Nov 08, 2010 | Texas Instruments TI-83 Plus Calculator
My Graphing calculator has no x or y axis. Its all Blank.
Press the 2nd Button then the ZOOM button. Make sure that AxesOn is highlighted. If not, move your cursor down until you on AxesOn and press ENTER.
If AxesOn is highlighted, then it is probably your window. Press ZOOM, then 6.
Jun 03, 2009 | Texas Instruments TI-84 Plus Calculator
ERR:SYNTAX
try to change the mode to function otherwise im stumped
Feb 04, 2009 | Texas Instruments TI-84 Plus Calculator
ERR: SYNTAX
Ok i had the same problem- If i remember correctly my "window" was messed up. Check it out... If not i always pull the "take batteries out while on" trick which resets the ram.
Sep 01, 2008 | Texas Instruments TI-84 Plus Silver...
Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
246 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
