Question about Protron PLTV3250 32 in. LCD Television
My tv will not turn on. It is not the outlet.
  • 11,361 Answers
Check the power supply; look for bad caps with leaking/bulging tops, check to see if you have standby +5vdc at the power supply connector, the front red indicator will not be on if you do not have this +5vdc standby voltage due to shorted out Q7 and ZD4.
http://s807.photobucket.com/albums/yy352/budm/Protron%20PLTV%203250/
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Power supply: http://www.google.com/products?rlz=1T4GGIH_enUS282US283&q=pltv+3250+power+supply&um=1&ie=UTF-8&ei=9lIDTL7XO4fcM7HA-Ds&sa=X&oi=product_result_group&ct=title&resnum=1&ved=0CCgQrQQwAA
Posted on Oct 07, 2010
Tv won't switch on following power being turned off/on by electrician installing external light
Have you tried different electrical outlets? Maybe the circuit breaker for your particular outlet blew when the electrician turned the power back on. Or maybe the electrician disconnected power to that particular outlet.
Also try leaving tv unplugged for 30 minutes or so, then plugging back in [to a known good outlet] to see if it will turn on.
Apr 27, 2016 | Televison & Video
Tv in bedroom not working but tv in living room working any suggestions
I am assuming it does not turn on. Did you try a different outlet that you know is working? If you know the outlet is working and the tv does not turn on or tries to turn on but does not then I believe the tv's power board has failed. If you use a remote, is the remote working? How old is the tv?
Jan 05, 2016 | Televison & Video
42 inch plasma screen tv Panasonic was working fine then turned it off and now won't turn back on. Any ideas? Can't tell if it's getting powered and none of the caps are bulged
Did you try the outlet that your TV is plug into. or get a extention cordand try your TV in other outlet.Then you know if it's the TV or the outlet.
Jan 14, 2013 | Televison & Video
My tv wont turn on
Look for power outlet and ensure there is power. Check TV on other power outlets. Ensure required voltage is there on the power outlet. Even then, if you notice that the TV does not work, it might be attended to by a skilled and qualifies service technician.
Jul 28, 2012 | Sanyo Televison & Video
My tv won t turn on i just purchased it today i plugged it in and it won t turn on
Check the electrical outlet which the tv is plugged into. Make sure nothing is loose at the outlet as well as on the back of the tv where the power cable plugs in. Another thing to try is plug a different device into that same electrical outlet and see if it turns on. If it doesn't turn on, it could be a faulty electrical outlet. If you've tried both the remote & the power button on the tv, a shot in the dark would be to change the batteries in the remote.
You could always try calling their tech support at 1-800-256-2487. A last resort would be to return the tv from where you purchased it.
Mar 09, 2011 | Emerson Televison & Video
My tv has a problem staying on and sometimes it turns it self off and turns it self back on and has become more frequent with turning it self off
Another thing to try is plug a different device into that same electrical outlet and see if it turns on/off as well. If that device also turns on/off by itself, it could be a faulty outlet.
Mar 09, 2011 | Samsung SlimFit TX-S3082WH 30" TV
My tv turn on for a second and after turn off. it is hitachi 52" old brand.
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 24, 2010 | Sony KV-27V10 27" TV
Tv won't turn on
Try plugging something else (a lamp?) into the power-outlet, to see if the wall-outlet is providing power.
Try plugging the TV into some other "known-good" wall-outlet.
Take the TV to a repair shop, and have them trouble-shoot.
Nov 09, 2009 | Soyo Televison & Video
Rca f36650yx01 will not turn on
I feel foolish asking this but have you plugged it in? If you have it plugged in are you trying to turn it on with the remote? Have you tried to turn it on by pressing the on switch on the tv? Does the outlet work?
There could be any number of reasons for this. If the outlet has power (you can check this with any electrical device you have, plug it in and turn it on). So if the outlet has power AND the remote has fresh batteries AND the tv is plugged in to the outlet but still will not turn on even after pressing the switch on the tv...then you may have a blown fuse on the power input line into the tv. Take the tv to your local repair shop and ask them to look, if the fuse is blown they'll replace it and voila, your tv is fixed!
Please do not try to do this yourself, there is over 10,000 volts available at the flyback transformer even with the tv not plugged in.
Sep 07, 2009 | RCA F36650 36" TV
We have a Ilo flatscreen tv and it wont turn on
First, I would leave it unplugged overnight.
Second, test the outlet with a standard light lamp to make sure the outlet works.
Third, if the outlet still works, use a good surge protector and plug your TV in the morning.
If the TV problem still ocurring, you might have to take your TV to a repair shop to diagnose the problem. The sad news is it might cost more that $100.00 for someone to look at it. You'll have to figure out if it worth repairing.
Good Luck
Rate me if I answered your questions
Feb 02, 2009 | iLO 2600 Television
Protron PLTV3250 32 in. LCD Television Logo
82 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
