I am trying to retore the factory settings on my eay note R1004 laptop, how do I do this?
  • 137 Answers
Insert the Recovery disc then restart and boot from the CD/DVD drive. Should get the prompt "Press any key to boot from disc". If not, change the boot order in BIOS.
Posted on May 29, 2008
How to retore factory settings
put in your operating system cd. If you have windows 8 you can fully refresh your computer by booting from the cd
Feb 15, 2014 | Hannspree Computers & Internet
Sony pcg-fxa63
You can buy recovery disks, here's just one place.
http://recovery-disks.com/sony-vaio-pcg-fxa63.html
$30.
Feb 11, 2012 | Sony VAIO FXA63 Notebook
The screen on my lap top has had 3 very thin lines across the screen but if you tilt it they go now sometimes they screen fades away and i have to move the screen again this is getting worse could it be...
I'm a laptop repair technician, and in my experience the very thin horizontal or vertical lines are usually caused by malfunction in the display panel and the entire screen has to be replaced. If might be worth a shot for you to try and reseat the LCD cable though, but I doubt that it will work.
Sep 23, 2011 | Packard Bell EASYNOTE R1004 COMPATIBLE...
HOW TO retore factory setting in a SAMSUNG E250?
try
Home > Menu > Settings > Privacy > Factory Data Reset > Reset Phone > Erase Everything.
Jun 05, 2011 | Samsung Lands Phones
How do you restore the factory settings on the acer aspire 5532?
Well, first acer brand is cheap, and they don't give you a factory restore disc or a restore partition drive like most other laptop. However they give you the option to make a factory restore disc yourself, there is a program in the laptop ( browsing through your start task bar) should be a program such as acer recovery management, from there on use that program and make a retore disc. Once disc is created, you can go ahead and procced to restore your laptop in which you need to change your boot option to disc during startup of the laptop in order to boot from the recovery disc you just made.
Apr 17, 2011 | Computers & Internet
Cant retore back to factory settings
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
Hope this helps
Jan 29, 2011 | ASUS Eee PC 900 PC Notebook
I have the "D" file with the information needed to
Here is the primary way to restore your notebook to factory setting:
1 Turn on the computer.
2 As the computer starts, press on the keyboard until the Advanced Boot Options menu appears on the screen.
new_note.jpg Note: You must press before the Windows logo appears on the screen. If you press after the Windows logo appears on the screen, the Advanced Boot Options menu will not appear on the screen. If you do not see the Advanced Boot Options menu, restart the computer, and then repeat this step until you see the menu on the screen.
3 Press the on the keyboard to select Repair Your Computer on the Advanced Boot Options menu, and then press .
4 Specify the language settings that you want, and then click Next.
5 Log in as a user who has administrative credentials, and then click OK.
6 Click Dell Factory Image Restore.
7 In the Dell Factory Image Restore window, click Next.
8 Click to select the Yes, reformat hard drive and restore system software to factory condition check box.
9 Click Next.
The computer is restored to the default factory configuration.
10 When the restore operation is completed, click Finish to restart the computer.
The software is now installed as it was when the computer was first received.
If you have tried this and you still can get your system to restore, your may restore partition may be corrupt, you may also have a virus that is preventing you access to the restore files. Run an AV agent and retry your retore. If you still have the system disc that came with your notebook, you should be able to use them to restore the unit back to factory setting. Good Luck C2Solutions
Jan 24, 2011 | Dell Vostro A860 Notebook
Easynote r1004 wont power on
The battery is too low and the power supply can't charge the battery and also power the laptop at the same time.
Try this:
1. Remove the battery from the laptop
2. Plug in the power cord and turn ON the laptop.
3. It should work ok.
4. After the laptop is "stable" (what 5 minutes?), you can put the battery back into the laptop while it is ON.
5. Leave the laptop ON so the battery can get charged.
6. Lower / close the lid so that the screen will turn OFFand not take up power from recharging the battery.
If this doesn't work for you, try these steps again, maybe wait a few minutes between steps.
This WILL work!
Hope this helps!
Sep 03, 2009 | Toshiba A15-S1292 Notebook
Bring to factory settings
Thanks for using FixYa!
You can always reinstall the operating system but you need to buy the software. Then download the device drivers for the laptop. The Toshiba website has all the drivers for your laptop. Another possible solution is for you guys to contact toshiba and ask if they can provide the factory restore CD for your laptop.
Have a nice day.
- HotRatchet
Jul 29, 2009 | Toshiba Satellite L25-S119 Notebook
Toshiba laptop hard reset needed
check in your my computer
see its there will say restore or recovery
can also right click my computer properties
you'll see retore in there
Jan 17, 2009 | Toshiba Satellite A135-S4527 Notebook
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
