Question about Mtd Heavy Machinery
I have a Briggs & Stratton 5HP Engine (Horizontal shaft) And it has the diaphragm carb on it. The last person to own it messed with the carb adjustments and it'll have trouble starting and idling sometimes. I was wondering how to adjust the screw on this type. For example, do I turn it out like 2 1/2 turns and adjust from there or what? I can't find repair info in my manuals for some reason. I've adjusted hundreds of carbs but just don't know it's specs. the model number is 135212 and the type number is 0140 01 code number is 93031127. it's mounted on a MTD chipper. And also the carb might need rebuilt which is why the person was attempting to adjust. I just want to get it all right before I tinker with it.
    Scholar:
  • 150 Answers
2 turns out should get ya started adjust from there. If adjusting doesn't help you may need a new diaphragm. While you have diaphragm out blow through the 2 holes you'll see under diaphragm with air to hopefully avoid pulling carb off to clear screens on pick up tubes. Also check carb mounting screws through carb into tank. They frequently come loose on chippers and log splitters because of hard mount.
Posted on Oct 07, 2010
Testimonial: "Awesome! Thank you very much!!"
Shredder won't stay running without starting fluid
Water being heavier than gasoline is likely to be in the carburetor. If a bowl type carburetor, remove the bowl and clean. Allow the fuel to run for a few seconds to clear the water from the lines.
If a diaphragm type carburetor, remove the diaphragms and allow the fuel to clean the lines.
Jan 23, 2017 | Briggs Garden
Briggs Stratton 5hp I/C starts ok, runs, but will not rev
My money is on a partial blockage of the main jet or the passageway to it. You're having to force it to run through the idle jet by fully choking the incoming air. There's not enough gas coming in with the choke open to allow it to run.
I'm thiniking total carb disassembly, carb cleaner and an air compressor combined with a ton of patience will take care of the issue.
Mar 31, 2015 | Briggs & Stratton Briggs Stratton...
Will not start. but if I pour gas in carburetor it will. stop after the gas is burn of carburetor
Could be that the needle is stuck in carb, or else the fuel pump diaphragm is bad. Check the pump, thats what I would check first.
Jan 24, 2013 | Briggs & Stratton Briggs Stratton Vanguard...
Briggs & stratton v-twin engine cuts out
acid dip rebuild carb make sure fuel selinoid on bottom of carb moves freely
Sep 07, 2012 | Briggs & Stratton Briggs Stratton Intek V...
I have Poulan tiller with Briggs & Stratton 5.5 hp engine. It runs only on full choke. Doesn't go to higher RPM. What may be the problem?
you have a gloged carb try takeing it off and blowing out the carb with a compressor
take the bowl apart its on the bottom of the carb you will find a float and needle seet
blow all of that clear and make sure the fuel line is clear
hope this helps you
bob
May 14, 2011 | Briggs Stratton IC Horizontal OHV Engine ...
18 hp v twin will not run. It is gettng fuel to carb but will not run. It will run when you spray starter fuel in carb but does not continue to run.
There is a solonoid valve in the carburator that shuts off fuel to meet emissions standards. Be sure it is wired to be powered when key is in run position. You can hear a "click" at the carb. when the solonoid powers up.
Jan 08, 2011 | Briggs & Stratton Briggs Stratton Vanguard...
I have a morrison classic 35 that is surging while its running, it runs well except for the surging. am guessing plug gap is 20thou and have cleaned everything. it seems to be the arm that comes off the...
Your Briggs & Stratton Classic engine uses a diaphragm to pump fuel. Yours has deformed and needs to be replaced. It is a very easy repair. Remove the air filter. There is a bolt on the end of the fuel tank nearest the spark plug. Remove this bolt. There is another bolt just behind the carburetor that holds the tank to the engine. Remove this bolt also. Now you should be able to gently pull the tank away from the engine. After the carb clears the intake tube, you can tilt the tank enough to remove the governor linkage from the carb butterfly shaft. Now the tank/carb assembly is loose and in your hand. Go to the workbench. There are 5 screws that hold the carb to the tank. Remove these 5 screws. When you lift the carb from the tank, you will see the diaphragm gaskets. Remove the old and install the new set. The 2 part diaphragm set consists of a rubber diaphragm and a paper gasket. The rubber part goes against the tank, then the paper gasket, then the carb. Leave the screws in the carb as you reinstall it, and the screw tips will align all parts during reassembly.
The diaphragm set is readily available at any Briggs parts dealer or online. Make sure you take the Model, Type, & Code numbers with you when you go for parts. These numbers are stamped into the metal fan shroud just above the spark plug.
Dec 31, 2010 | Briggs & Stratton Garden
How to drain carb
if its a vertical shaft as in the shaft points down,its a 6 sided bolt nexr to the shaft/if its a horizontal shaft its right at the base just above where it bolts to the machine usually below the oil fill cap
Aug 01, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Engine starts but won't stay running
an easy way to know that is to start engine and give it a shot of starting fluid ,if you can keep it running by this method I would replace diaphragm.
Jun 18, 2009 | Briggs & Stratton Briggs Stratton Intek V...
5hp Briggs & Stratton lawnmower starts but stop running?
Try cleaning the air filter, and check fuel tank for any debris.
Replace fuel filter if there is, and give the fueltank a good cleanout.
Use fresh fuel to refill.
May 17, 2009 | Craftsman 16" High Garden Tractor Snow and...
Heavy Machinery Logo
1,206 people viewed this question
Top Mtd Heavy Machinery Experts
rjivaro
Roland W VanLue
Roland W VanLue
obsteiner
Are you a Mtd Heavy Machinery Expert? Answer questions, earn points and help others
