Question about Haier HGRA241AA Gas Kitchen Range
Trying to turn oven on is not working everything else does
  • Haier Master
  • 43,501 Answers
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Posted on Oct 07, 2010
Oven won't turn on because someone played with timer
Try turning the mains supply off and it will probably reset everything.
Feb 01, 2018 | Moffat Ovens
When you turn it on,only the fan works but no heat.why is that?this problem started when the electricit was cut off.have tried to everything,but no result.
If the fan and everything else works, then I would suspect the element has failed.
This is located at the rear of the oven compartment behind a removeable cover.
A fairly easy job to replace the element.
Jan 21, 2011 | Bosch Ovens
No heat, but everything else works ??? Model 363.62709200 . I tried turning off the power to reset it, but still no heat.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Oct 07, 2010 | Kenmore 62702 Microwave Oven
My microwave oven isn't heating my food. Everything else works, the fan, the lights and the keypad. The microwave turns and sounds like everything is working but the food won't get hot. It is only 6 months...
Small component called a diode. Open up the microwave and try to find a black (usually) component that is most often connected between the magnetron (the thing that heats the food) and the chassis of the microwave oven (ground). I used to make a fortune replacing these! Costs about 5 bucks most appliance supply stores. Make darn sure you get one of the same value.
Apr 06, 2010 | Maytag MMC5000 Microwave Oven
My Maytag Performa oven and stove top will not turn on (heat up)
When I turn on my Maytag performa using the "bake" function, everything looks ok on the display, however the temp. never rises above 100. I've tried "bake" and "convect", and neither one work. "Clean" doesn't work either. The oven will lock, and display shows that it's heating up, but temp. never rises.
However....."broil" feature works just fine.
Please help.
Mar 09, 2010 | Maytag 30" Built-In Single Electric Wall...
I have a baumatic bc3510ss double oven. everything works fine except the large oven. you can turn on the grill or oven but when you turn on the temperature the rcb blows on the fuse box.
Tthere are a couple of possibilities for your prob, the thermostat, or the oven element is faulty.
Disconnect the oven element, and try it again, if it does not trip, replace the element, if it still trips, replace the stat.
Please rate my solution.
Thanks.
Nov 01, 2009 | Baumatic Ovens
Gas oven wont turn on
my brother stopped by last night and undid the lower fire cover , fiddled with something (we don't know the name) , now the oven will heat up and life is calm.
thanx for having this site to help calm us silly homemakers who aren't DIY.
aloha, teri
Aug 21, 2009 | Maytag Gemini 30" Self-Cleaning...
I JUST GOT A NEW HOTPOINT STOVE MODEL RGB530DETWW AND CHANGE TO LP BUT THE OVEN IS NOT WORKING THE FLAME IS ALL OVER THE PLACE I TRIED EVERYTHING ON THE MANUAL ALL THE PARTS THAT CAME WITH IT EVERYTHING...
You flipped the valve nut and turned down the orfice in the oven? How many turns did the orfice go around. If not at least 2 it is still too high. Some of these are very tight and do not like to move. Some have been cross threaded at the factory and require replacement. open the air shutters also. Eric
Aug 08, 2009 | Kitchen Ranges
GE Oven won't stay lit
gas ovens have fail safe device known as a ffd flame failure device sounds like you will need a new one fitted by corgi registered fitter
Jan 11, 2009 | Kitchen Ranges
Everything works except the cooking part/no heating/turntable not turning, help!
you may have gotten a power surge and that can cause some funny things to happen, 1st is there power to the oven, 2nd if so there may be an internal fuse protector built in to the oven, check with the manual for anything of that sort listed. if not you may have to take it in and have it repaired by a pro. there is a lot of voltage in these ovens and unless you know what you are doing a person could get hurt
Jan 03, 2009 | Whirlpool GH4155XP Microwave Oven
Haier HGRA241AA Gas Kitchen Range Logo
57 people viewed this question
Top Haier Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Haier Kitchen Range Expert? Answer questions, earn points and help others
