Question about Onkyo TX-SR502 Receiver
I have the onkyo tx sr502, onkyo dv sp402e with the speakers..etc.. i'm trying to set up the whole thing to a normal television. that is, what cables go from what components, out/inputs..etc..and which ones go from receiver to dvd player and to the television? not sure what the best way is to explain, whether diagrams..etc..? thanks, troy
    Scholar:
  • 82 Answers
Hi troy my names Josh i would be glad to be able to help you with your setup. First things first some people have a preference with they way they like things and for one do myself. I set up and intstalled my home theatre. I have receiver much like yours. On the back of your reciever you should have multiple inputs of coarse some for sound some for video. Your sound inputs would include digital optical, digital coax, standard analog which of coarse is the red and white RCA inputs and then a multi in which i doubt you have. So lets start simple If you have satalite or some form of cable i would assume you have your reciever box feeding a signal to your tv and the same for your DVD. I would recommend for your sat. that you connect your picture and sound strait to the tv rather it be component video or s video or standard video source or connect then for your sound strait analog to your tv thats just Red and White RCAs which will give you your sound to your tv. Repeat the same for your DVD depending on the kind of inputs and number of inputs you have on your TV. Now for the sound to your reciever. I ran digital sound from both my DVD and my Satilite to the reciever which means on the back of your recievers providing you have a similar configuration you would look for a plug on your dvd player that says optical thats your digital to run sound to your onkyo and the same for your sat or cable if you have a box look for either digital optical or a single digtal coax output that will also be ran to the onkyo for sound. You should only have two cables running to the onkyo one fiber optic from your dvd to the onkyo and one digital coax or fiber optic to your onkyo depending on the number of those inputs you have on the back of the onkyo you can run it how ever you want.
Posted on Oct 07, 2010
Can you use an Onkyo RC-771M remote control to operate Onkyo receiver TX-SR502 ?
Unfortunately, the RC-771M remote doesn't control the TX-SR502. It will only work with these Onkyo models: TX-NR1008 and TX-NR808. The RC-567M is the one for the TX-SR502; replacement remotes that are exact replacements are still available from various places including Amazon.com .
Since the TX-SR502 was released in ~2004, that replacement remote probably won't control other devices that were released in 2004 or later. Onkyo changed its IR code programming before the TX-NR1008 was released in ~2010 and the RC-771M can't communicate with the older receiver. The manuals for the receivers listed above are still available from Onkyo on the product page under the Downloads tab.
I wish that I had better news for you.
Jan 31, 2016 | Onkyo TX-SR502 Receiver
When connecting optical inputs there is no audio output
You have to assign each digital input.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Onkyo-TX-SR502-Receivers-manual/id/365ag217/t/2/
Search the document for "assign".
Mar 27, 2011 | Onkyo TX-SR502 Receiver
Onkyo tx sr502, sounds coming from all speakers except sub. in test sub works
hi,
Try the following setup to activate the sub
1.Press the [AMP] button on the remote and then press [SETUP] button.
2. Use the Up and Down arrow buttons to select "1. SP Config," and then press the [ENTER] button.
3. use up and down arrow to select subwoofer setting.
3. While the subwoofer setting is selected, use the Left and Right arrow buttons to select Yes .
you will surly get the audio from the subwoofer.
ok
Feb 19, 2011 | Onkyo TX-SR503 Receiver
I have an audio problem with my TX-SR502.
If your remote also controls the Cable Box you might want to look at its audio settings. Maybe you muted it.
BTW: it would be a good idea to also run video and analog audio from the cable box directly to the TV if it has speakers so you can watch and listen independent of the Onkyo.
Mar 11, 2010 | Onkyo TX-SR502 Receiver
Central chanel no works
Hi on Onkyo receivers you must go into the speaker setup and select YES for center channel, I've on occasion turned a setting to no when I wasn't paying attention.
If that doesn't work check to see if your unit has PRE inputs and outputs
if so there should be a jumper pin that connects the two.
Dec 31, 2009 | Onkyo TX-SR502 Receiver
My TX-SR502 AV receiver has no output sound in any mode but CD. Thsi has been a progressivly deterioration from sometimes sound to finally no sound.
sounds like the receiver input mode may be in the wrong setting. or check the 'direct' button. turn it off
Nov 03, 2009 | Onkyo TX-SR502 Receiver
My Onkyo tx sr502 quit producing sound?
I have the same problem.It's definitely the pre-amplifier board (board with speaker terminals).I did not quite nail the exact component yet but I replaced with a working one and got back sound output.
Jan 06, 2009 | Onkyo TX-SR502 Receiver
Onkyo receiver question
One of the speaker maybe are in bad conditions and that burn out the audio amplifier IC you need to change it or send the device to a repair center.Good luck
Apr 28, 2008 | Onkyo TX-SR502 Receiver
Onkyo TX-SR502 - o Sound!
pls make it reset at factory level ,but pls note that you have to keep it in aauto mode
Mar 12, 2007 | Onkyo TX-SR502 Receiver
Onkyo TX-SR502 Receiver Logo
211 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
