Server vfy-rx-100s3 FujitsuSiemens
After I have installed Vist on the server, with 2 harddisk WD. and updates.
all of sudden the server stoped no reaction no respond. I put it on nothing is on the screen. it gos laud and then gos down but not off. please help.
    Problem Solver:
  • 17 Answers
Albert,
I don't really understand what you have installed.
If Vist is Vista , then you should do it on a PC, not a server.
When we install new servers with many patches , service packs , applications etc., we make ASR after each path , pack , app. This way if anything happens , we just use the ASR to put back to last wotking install. Please try that method .
Good luck ,
David
Posted on May 30, 2008
ASUS RS120-E4/PA2 SATA harddisk drive
IT is Mandatory that ALL The HARD DRIVES Should Match the Specifications Provided according to Server Specs.
Mar 02, 2012 | ASUS RS120-E4/PA2 Server
Help! I have a Fujixerox DocuColor 1256GA Printer running in Apple G5, The harddisk of that computer died and had to be replaced, my problem is the EFI Splash G640 color server installer is missing, I...
I have DC1256 GA machine, but i need ibt belt cleaning blade. in india it is not available. Can anybody help for the purchase of this blade. my email id is : revatheecolourprints@gmail.com
Apr 25, 2011 | Xerox DocuColor 12 Color Copier
"Harddisk not found" error during
If the computer is telling you that the hard disk is not found, then either it is not hooked up correctly, is set to "disabled" in the BIOS setup, or the hard drive is bad.
Check those things in that order.
Apr 16, 2011 | IBM x3400 Server
I install windows 2003 server but req. harddisk drivers
You should be ableto get the drivers from Microsoft and from IBM support site. If you are unable to do so from the x3400, you can download the drivers to a usb or cd-rom and install from there.
Good Luck
C2Solutions
Dec 27, 2010 | IBM x3400 Server
What hard drives can I use as replacements?
Call Dell with your Service Tag.
Lifetime support is included on all Dell servers.
Last time I called them I dialed (800) 945-3355
They can sell you the hardware you need and guarantee it will work with your server. They might even be able to help explain the process of installing the drives.
I recommend that you use Acronis' Imaging software (www.acronis.com) so that you can make an exact copy of your data and apply it to the replacement volumes. If you are using a RAID1 array make sure the new array is completely built before applying your image. Builds can take a long time. I created a RAID1 array with 2-320GB disks and it took 3.5 hours to build the RAID1 array.
I hope this helps.
Please vote for my solution if it helps.
Apr 19, 2010 | Dell PowerEdge 2500 Server
Problems with booting
for any new hard disk first you have to create a partition table. Usually this is done when installing the OS. eg: for win98 you have to first create the partition in dos, format it, then run win98 setup. Now in WinXP this can be done when installing the OS. Similarly you may have to create the partition before runing UNIX setup. I Dont know the installation for UNIX. Usually the hard disk manufacturer supplies with some utility to do the partition. Like Disk Manager from Seagate.
Sep 06, 2007 | Compaq AlphaServer DS10
Computers & Internet Logo
73 people viewed this question
David Payne
David Payne
