Question about ViewSonic NextVision N3260W 32 in. HD-Ready LCD Television
I have a n3260w lcd. when i plug it in the red light on the front flash's and the tv willnot turn on. i replaced all the blown caps on the psu. this made no difference. what else could be wrong?
  • 11,361 Answers
You need to measure the DC output of the power supply to make sure it is putting out all the voltages first. It may be almost the same as N3250W.
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Posted on Oct 07, 2010
How do I fix my LG 42PG25 plasma TV? The model number is 42PG60UA. What should I try next see details below?
It is 19 years old, and I would say beyond economical repair. You will be chasing blown components that were damaged when the power surge or brownout occurred. It is only a 42" set and it is plasma. Technology has moved on to 4K Ultra HD, LED and smart hubs. Treat yourself, it's Christmas :>)
Dec 19, 2017 | LG Televison & Video
Polaroid tlx-03210b no power to backlight
I have the exact tv model and the exact problem.. replaced bad caps and still the same problem. no voltage on the backlight plug. and the blinking red led on the board.
Aug 07, 2012 | Televison & Video
Tv does not swich on. The red led light plinks 5 times.
5 flashes, bad lamp and/or lamp driver
4 flashes, bad or stuck fan
There is a chance that the bulbs are not bad, but you will need a small fan to test this. Place a small fan blowing directly behind the set and run it for several minuts before turning the set on. This may help clear the code and allow you to watch tv if not then your lamp or driver has gone bad and needs replaced.
Jul 02, 2011 | Sony Bravia KDL40HX800 40 in. LCD 3D HDTV
I have a Viewsonic N3260w TV, the Power Indicator light is flashing red continually, but the remote wont start the tv, I have changed the batteries, turned the tv on and off, but the tv still wont...
The problem of your tv is in the power supply. In order to find the power supply of your tv ,you should follow the ac cord. But first you should unplug the unit and open the back cover of your tv there you will find the power supply, try to check the capacitors, it is cylindrical shape and has a plastic cover. Try to observed if their is a wet mark or oil mark that spread in to the pcb then replace it. But when replacing the capacitor you should observed the polarity of the capacitor and replace it exactly the way you pulled it out.
Jun 06, 2011 | ViewSonic NextVision N3260W 32 in....
Ilo tv will not turn
The red light flashing means protection mode because an internal fault had been detected.
If the TV does not even start after unplugging power cord for a while, then the defective part must be replaced.
Parts that are commonly faulty are PSU, Inverter , and LCD control board.
Parts must be tested before replacement.
Sep 05, 2009 | iLO V27DMBX Television
TV won't turn on
Count the flashes. Then we can help.
May 21, 2009 | Sony 40 in. LCD HDTV
Long wait when cold for tv to actually switch on
bad capacitors unplug the tv and let it sit for a day. Lay the tv flat and take all the screws out the back you want to look at the top right corner of the pcb ( power board you cant miss it ) you will probably notice 4 swollen / leaking caps replace these and the tv should work fine. The tvs protection circuit is stopping it from starting your straining the PSU by using it with the caps blown if your not comfy soldering phone a local electronics company im sure they can help you out. you can easily disconnect the headers from the psu board and take that for repair.
i used 35v 1000u caps the caps i removed were 10v 1000u
Apr 23, 2009 | Samsung LE40R73BD 40 in. HD-Ready LCD...
The green light comes on then turns to yellow.
if you look at the capacitors on the boards you will find several of them that are domed or blown, these are the most likely cause of the problem. you can find replacements for any capacitor online at electronics supply stores, like radio shack but don't try them they don't supply enough different types. you can also find examples of blown capacitors by doing a search for "blown capacitor image" on any web search. unsoldering these bad caps and replacing them with identical values like 220uf (microfarradys) and say 25 v(volts). these caps have a + side and a - side the caps are marked and so is the board. hope this helps.
Mar 20, 2009 | Proview PL926WBi 19" LCD Monitor
Viewsonic N3260W made loud pop and will not turn on.
We got the part in today and the hubby fixed the tv. It is as good as new. We are very happy with our $62 purchase.
Go to http://store.ramplus.com/fsfspopfrpos.html
FSP228-3F01, FSP Open Frame Power Supply Replacement for Viewsonic N3260W - 32" LCD TV
It worked like a charm and took about 10 minutes to put in new part and put tv back together.
Jan 04, 2009 | ViewSonic NextVision N3260W 32 in....
ViewSonic NextVision N3260W 32 in. HD-Ready LCD Television Logo
168 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
