Question about LG WM2688HWM TROMM SteamWasher
I have a LG WM2688H and I believe that I clogged the drain hose somewhere. I washed a throw carpet and the rubber backing fell apart, needless to say I will not be doing that again, instead I will throw the stupid thing away! I'm flat broke right now and cannot afford to call a repair man, I would like to fix the problem myself, but I need help. I already cleaned the filter in the front of the machine. How do I access the drain hose inide the machine? Or is it not possible to do that.
Clogged Drain Hose
There should be a spring clamp of some kind,use a pair of pliers to squeeze the clamp open and slide it off the hose.
Apr 23, 2012 | LG WM2688H Front Load Washer
Water won't drain and it says oe
Hello & Welcome to FixYa
OE is a drain error and is displayed when the washer is unable to drain water. Please check the drain hose and drain pump filter for any clogs to clean the error. Please get back to me if you have any other questions.
Kevin
Aug 10, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
The washer will not drain I cleaned the bottom drain out and it was full of something that felt like kitty litter (it was not kitty litter) something fell apart when I was washing. I attempted to run a...
Your drain system is clogged with debris. Remove the filter from the bottom left door and look straight back inside the drain system, you will see more debris inside. Do not use a sharp object to remove the debris or you will puncture the rubber bellows. From the back of the machine, remove the back cover. At the bottom of the tub you will find a rubber drain hose that leads from the bottom the tank to the drain filter. Using your hand, gently squeeze the rubber drain hose to "massage" the leftover debris inside. This should help clean out the debris. WARNING: This will cause a major rush of water to come out so be prepared. Good luck
Jun 18, 2011 | LG WM2016C
LG washer getting an OE error. I have opened the pump and drained the water as well as ckeaned the filter...still not working propperly.
OE means your machine has failed to drain within 10 minutes. There are a few posibilities. Your drain hose could be kinked or clogged causing the machine not to drain. Try using a shop vac to remove the water from the end of the drain hose. If a shop vac won't **** out the water either, you have a clog somewhere ing the drain hose, of the hose from the tub to the pump. If it will drain the water you need a new pump. If there is no water in the machine then the problem is either the pressure switch, the hose going to the pressure switch, of the control board. The pressure switch is on the back by the control board. You will see a black rubber hose going attached to it. Remove it and see if you can blow through it. If you cant it is clogged somewhere. If it is not clogged then the most likely cause is your pressure switch and next the control board.
Jan 30, 2011 | LG WM2101HW 4.0 cu.ft. Washer
IT DON'T GO THROUGH CYCLES COME UP WITH A CODE OE
Kevin
Jan 06, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG washer won't drain
you probably didnt get it all may need to clean it out 3 or 4 x
Apr 16, 2010 | Washing Machines
Wm2688h will not drain anymore.
You need to take a flashlight and look into the suction port on the pump. Make sure the pump is not clogged and check the pump impeller. Make sure that no blades are broken or missing and the impeller should spin freely. If any blades are missing or broken on the impeller or if it will not turn freely, the pump will have to be replaced. Hopefully, it is just a clogged pump. Hope this helps and best wishes.
Aug 08, 2009 | LG WM2688HWM TROMM SteamWasher
Kenmore Front loader clogged up
open the back panel to access the hoses. look for the largest-diameter round hose and disconnect it. this should be the drain hose. it also should lead to a vertical-rising pipe or hose that then dumps downward (U-tube at top) into your house piping outside the washer. My hunch is the clog is somewhere before the area where you disconnected and may need to remove all hoses from the pump and also clean pump's impeller.
May 30, 2007 | Kenmore 46462 Front Load Washer
Washing Machines Logo
198 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
