Question about Garden
How do I remove the clutch assembly on a toro proline 30157? It won't clear the axle.
5 Suggested Answers
SOURCE: removing the assembly from the trans-axle
I decided to call the local/regional non-official Toyota repair business on the off-chance that they would tell me how and why. They were very kind and obliged me. There is a serious amount of resistance on the driver-side axle due to a 'round' wire circlip embedded in a groove in the spline-end that is in the transaxle. It will release if enough prying/wedging effort is applied to the black cv housing...with care not to damage the aluminum transaxle case. I used any convienent bolt-head in the case as a fulcrum, and a stout prybar/flat-blade screwdriver as a lever. With a flushed-red face, a deep gutteral grunt, and a mighty heave, the axle gave up the fight and slid out like a good bowel movement. I regret that I could not use your services, but I have no credit cards. And the fact that $9 at this time is about enough gas for me to run for a week. Every penny counts out here in the wilds of western Montana. Thanks for being there, regardless. I will refer to you in the future when I am back on my feet. Warm regards. Michael aka peterjmoose.
Posted on Sep 30, 2009
harlan301
  • 205 Answers
SOURCE: Toro Proline 400 blades fall out of engage
if your unit desengages have the clutch gap checked. also you should check for shorts in your safty wiring. the other would be a bad switch. finely your under warranty this my be warranted.take it to a toro dealer or call one to make sure
Posted on Oct 13, 2009
  • 111 Answers
SOURCE: I have a 2002 toro
It is an overflow tube. If the carburetor gets turned upside down the fuel will drain out of it. Also if the carburetor is flooding it will run out of this tube as well. It is a safety feature on certain engines.
I hope this answers your question.
Posted on Apr 05, 2011
  • 6468 Answers
SOURCE: proline toro commercial 32 inch won't run
try starting fluid that will see if its a fuel problem then check for spark
Posted on Apr 21, 2012
Wheel came off. Can I replace just axel instead of hydro transaxle?
The hydro Transmisson Is not the easyest to repair. That is probably way they said that. plus the labor whould have been $350 to $500. So most shop won't repair them.
Find A break down on line so you can see what your getting into.
Aug 04, 2012 | Toro Garden
Toro 8-32 riding mower
there is a retaining ring that holds it but you need to open the rear axle assembly to get to it
May 23, 2012 | Toro Garden
Proline toro commercial 32 inch won't run
Apr 19, 2012 | Toro Garden
Toro 52 inch walk behind blades won't engage
if it has a electric clutch check for power to the clutch if no check the safety switches
Apr 10, 2012 | Toro 52" Cut Wide Area Walk Behind Lawn...
I'm trying to remove the "hub" from the front axle because the rotor was rusted to it and a new one won't fit "true". I need a picture or exploded diagram to understand why it...
Your hub is a complete unit including wheel flange and bearing. Thje axle passes through the assembly. You will find three twelve point 13mm bolts that go into the rear of the hub through the steering knuckle.
To remove the assembly, Loosen those three bolts, run them out part way and use a socket you don't want (you will destroy it) Put the socket on each bolt and use a heavy hammer to drive the assembly out of the knuckle. Alternate sides so it does not bind. use lots of solvent on the hub parting surface.
One tip: Disconnect the tie rod end so the assembly is easy to turn from side to side.
The hub assembly is only rebuildable in a factory. It is replaced as a unit. While you have it apart, always check the axle universal for binding or play. If you remove the axle for any reason, when putting it back in don't drag it on the bottom of the tube, The seal is inside the tube next to the gear set. Dragging the axle will knock the seal out.
Jul 18, 2011 | 1992 Jeep Cherokee Sport
Remove a clutch assembly from a toro 264-6 mod. 72042 lawn tractor
Jump onto www.toro.com and download the free service manual for your machine. Note down all the details on the ID plate on the mower, you will need it to find the correct manual
May 31, 2011 | Toro Garden
I have a 2002 toro proline mower. There is a clear hose coming off the top of the carberator. does that hose connect somewhere or is it a breather hose?
Apr 03, 2011 | Toro Garden
Sep 07, 2009 | Toro Co M/R Blwr/Trmmr Rear Bag Kit
AUTOMATIC TRANSMISSION WON´T MOVE
That trans is an RE4FO2A or V and check the fluid level,if the fluid level is good,check the axles to make sure they are seated all the way in the trans,and that the axle's CV joints aren't broken.Other than that,likely an internal problem with the forward clutches,torque convertor,or pump assembly.
Jul 08, 2008 | 1992 Nissan Stanza
Can a shade tree mechanic change the clutch in '97 mitsubishi 3000?
Removal (3000GT AWD)
1. Remove air cleaner cover, air hoses and vacuum pipe. Remove air cleaner, intake hose, battery, battery
tray and washer tank.
2. Disconnect transaxle control cables and speedometer cable. Raise and support vehicle.
3. Remove both inner fender splash shields. Remove clutch tube bracket and disconnect clutch release
cylinder (including clutch damper assembly on FWD models) and wire aside. Support transaxle assembly
with jack and disconnect upper transaxle mount. Remove mount, bracket, plug and stoppers.
4. Remove transaxle assembly upper coupling bolts. Disconnect tie rod ends and lower arm ball joints.
Remove right support member, starter cover (if equipped) and starter.
5. Remove left side bearing bracket mounting bolts and pry left axle shaft from transaxle. Wire left axle
shaft and inner shaft assembly aside. Pry right axle shaft from transaxle and wire aside.
6. Remove front bank side and rear bank side transaxle stays. Support transaxle assembly with a
transmission jack. Remove transaxle assembly lower coupling bolts and lower transaxle from vehicle.
7. Insert a clutch alining tool to prevent pressure plate and clutch disc from falling. Loosen pressure plate
bolts gradually in a crisscross pattern to avoid warping pressure plate flange. Remove pressure plate and
clutch disc.
May 14, 2008 | 1999 Mitsubishi 3000GT
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
