Question about Broderbund PrintMaster Gold 16 for PC
I want to print a regular half fold greeting card, but the only instructions I see are for sending the card to a website for uploading to order. I want to print it myself. Please inform.
I am rying to make a birthday card but the verse and picture are not the same way up
If you are using a preloaded or downloaded template for the card, check the amounts of folds the card will print out with.  For example, at the bottom of the screen, you may see pages 1 thru 4, so this means you will have 4 folds when the page prints.
Each page represents what will be printed on each folded section, so you will be able to edit each area to suit your needs.
Here is a great little tutorial on eHow for you: http://www.ehow.com/how_2058679_use-microsoft-publisher-greeting-card.html
Jun 19, 2011 | Microsoft Publisher for PC
Prints wrong on windows Vista
That would point to either an incompatability with Vista or incorrect config settings.
Oct 03, 2009 | Microsoft Windows Vista Ultimate Edition
I am trying to figure out how to print a Half-Fold Greeting Card.
Check the cd that came with the printer, there should be a manual in it.
May 04, 2009 | Computers & Internet
Inside of greeting card.
Yes and no. Unless you have a printer that prints on two sides you will have to "trick" it and use the template for both. Make a front and a back. You will have to print one one side then inset it to print on the other side. Since all printers feed difrently you will have to play with this on scrap first before using your good card stock. For example I made invitations to a wedding. The couple wanted a pcture on the fornt. On my template I had to rotate the picture upside down so when it was folded in half the picture wa right side up. It also had a raised rose on the invitations so I had to adjust the image so it would print in the empty are on the front. I then had to do the inside text and makes sure the paper was inserted correctly as not to print upside down. You can do it but it is tricky, that is why I recommend some scrap paper first. Good Luck.
Apr 09, 2009 | Broderbund Print Shop Mac 2.0 for Mac
Need to print a half-fold card envelope with HP Photosmart C4480
I also contacted HP and they directed me to a workaround which I have not implemented yet!
Mar 07, 2009 | HP Photosmart C5280 InkJet Printer
I'm printing wedding invitation envelopes (or A6) and had to set both my C4480 and psc1315 to a regular size 8.5x11 letter size but changed my margins to reflect the smaller size for my envelope with the left side of the screen being the more narrow margin. After adjusting the top margin accordingly, I fed the envelopes, flap side down and straight into the printer and voila...envelope addresses are printed. Good luck. Blu
Feb 15, 2009 | HP Photosmart C4480 All-In-One InkJet...
INSIDE MESSAGE ON GREETING CARD
Your card will fold to make an inside and outside once folded, but is seen in a page layout app differently.
Take a sheet of paper and fold it in half to represent the card you will be making.
Now open it up and lay it down on a table, with the inside of the card face down.
The outside back of the card should now be on your left, and the front of the card is on the right. Use a pencil or pen to mark it as such, if you need to.
Now when you do your card layout, the cover art and text should be on the right side of the page you create in the application.
If you flip the card over, so that the inside is now facing you, you are looking at the inside of the card.
Usually, the text and signature areas would be on the right side of this page, as well.
Now, use that same guidance when you work on 'page 2' of your document. Add the text to the right side of your page, so it will be on the right inside panel after you print and fold the card.
The final step is to print it out so that the inside and outside are in the correct orientation to each other.
Be sure to feed the paper such that the top of the card is facing the same side of the paper tray when you prnt both sides. (I sometimes make a light mark in pencil which can be erasd, to be sure it goes in the right direction, since this step is easily messed up.)
Good luck.
DigiChick
Jun 09, 2008 | Cosmi Print Perfect Platinum
HP psc 1315 all in one-printing cards
Make sure you check the settings in the print driver. Sounds like your paper size settings do not match the size of the paper that you are printing onto and you are actually getting a false jam because the machine is seeing a different size paper then you ahve in it.
Dec 18, 2007 | HP PSC 1315 All-In-One InkJet Printer
Broderbund PrintMaster Gold 16 for PC Logo
29 people viewed this question
Top Broderbund Computers & Internet Experts
Martin Murray
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
