Question about Sony Walkman NWZ-S616F MP3 Player
I have an NWZ-S736F that has a dying battery. I've removed the two screws on the bottom-back but don't know how to open it.
2 Suggested Answers
SOURCE: Sony Walkman NWZ-S736F MP3 wont connect
Uninstall problem MTP device in device manager. Reinstall it as a USB mass storage device. It should connect to the USB port. Unintall that USB mass storage device. Scan for hardware changes. It will find your mp3 player and install it. In the window to choose what action to take, choose sync music. Media player will open and connect. So then, will your other apps.
Posted on Jul 21, 2009
Wheres the battery
Remove the bottom screw. Next, the on/off slide switch has to be lifted off carefully with a small flat screw driver. Its kept in place with a small spring steel clamp. After you've removed it lift off the steel clamp and remove the slide mechanism by carefully twisting it out of position. Once that's done it will twist open easily.
Oct 17, 2012 | Norelco G270 Beard Trimmer
I don't have any screws on the bottom of my MAS830B multimeter. How do I get the case open to install the battery
there should be a little slot at the end this model you just prise the meter in two to replace batrery
Nov 21, 2011 | Mastech 19-range Digital Multimeter Dmm...
I have a 2 cycle Troy-Bilt TB90BC line trimmer. Won't idle. I've had the carburetor dipped, installed a new carb kit, replace the gas lines, but will only run at full speeds. Dies out easily....
One of three things is occuring here. The IDLE SPEED SCREW (Phillips head) on the throttle plate is screwed in way too far. The L and H mixture screws are open way too much allowing the carb to use excessive fuel, even on startup. Those 2 screws may need adjusting. The metering lever in your carb is not adjusted flush with the carb body flange and is holding the gas needle open constantly. Check these things and post back.
Sep 09, 2011 | Troy Garden
How do I open the housing to rplace the drive? Many thanks.
If you don't see any screw holes, look around for some rubber feet, chances are the rubber feet are hiding some screws. If you remove those carefully enough, you can easily put them back in. Once all the the screws are removed carefully pry open the case and remove/replace the hard drive inside.
May 08, 2011 | Acomdata (HD080U2FE-72) 80 GB Hard Drive
How to download the usb to mp3 ?
Transfer first your usb files to computer then have your computer transfer them into your mp3 player.
Regards, jay
Feb 21, 2011 | Sony NWZ-S736F (8 GB) Digital Media Player
Walkman NWZ-S615F How do you change the battery on this walkman? We've had it 3 years, but hardly used. Will work when plugged in to pc, but will not charge battery. I see on ebay I can purchase new...
Yes.
You can change the batteries easily.
First, remove the screws at the backside, near the bottom.
Then flap open the front, starting from the top.
battery is glued to the back cover.
Remove the connector, remove the battery.
Stick new battery to the back cover, connect the connector.
Fit both the covers together. Power on the player.
If there is no problem, put back the screws.
thats it.
Jan 22, 2011 | Sony Walkman Video NWZS615F MP3 Player
Are replacement batteries for sony nwz a829 easy to change mine is not holding charge now and would i lose all my stored items on said device
Replacement batteries are available on Amazon. Turn the A829 over and remove the one recessed screw at the top centre of the back case. You will then be able to slide this part off. Careful not to lose the shield that may fall off underneath this cover.
You will now find two screws underneath holding the rest of the back cover on and also two at bottom. A set of philips watchmaker's screwdrivers plus tweezers will be helpful. Put screws in safe place.
Fully remove the back and you will find the battery which has a small connector on the lead held in place by a strip of adhesive tape. Remove connector and battery and replace with the new battery. Put tape back on the connector and then replace back of MP3 player in the reverse order that you took it off. The shield that fell off on mine fits in top centre of device - mine fell off and I had to work out where it came from!
Hopefully these directions will help you
Jan 08, 2011 | Sony Walkman NWZ-A829 Digital Media Player
How i can mount a new battery cover on Olympus SP-560 UZ
i just purchased a new cover for $33 from uscamera. part#omp vg4293. You will need a jewlers philips screw driver. Make sure you lay out screws where they came out. They're different. Looking at the bottom,Remove 1 screw under battery door. Two screws on bottom my mount. Open little door on left for mem card and remove 2 screws. Open little door on right side where cable goes, remove 2 screws. Then gently on end wher door goes, pull back cover back just enough to remove old door and reinstall new door. Press back together and install screws.
Jun 18, 2010 | Olympus SP-560 UZ Digital Camera
Sony Walkman NWZ-S736F MP3 wont connect it charges but dosent show up on the content transfer
Jul 11, 2009 | Sony Electronics - Others
Removin CR1220 battery
There is the battery paned on the opposite side of data cable ......Remove the battery....you can take the help of manual too...its fully illustrated there..
Apr 11, 2008 | Canon PowerShot SX100 IS Digital Camera
Sony Walkman NWZ-S616F MP3 Player Logo
60 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
